Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 11:29 PM
davelance01 davelance01 is offline
davelance01 is starting off with a positive reputation.
turbo
I have a banks turbo and I hate the thing. It adds hours and hours to every job I have to do on the truck. I have to have had an extra day or so removing the transmission because of the way banks routed the exhaust. Is there any other turbo that can be removed when needed so I can maintain the truck and still have the extra power or should I just start looking to retrofit a different turbo on the truck?
  #2 (permalink)
Old 07-04-2009, 12:40 AM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
dakotajeep is starting off with a positive reputation.
I am in the same boat. I wish a thousand times over I would have gotten a Hypermax since its much less intrusive!
I might get around to doing it one day. More likely I will wait until this engine goes and I get a 6.9 and mount it in there instead.....
__________________
1994 F350 XL Crewcab 4x4 SRW 7.3 E4OD Banks Turbo & "Custom" Exhaust
Dana 60 Sterling 10.25 3.55 285/75 16 Treadwright Retreads MTG's (love these tires), Pyro Install and Tekonsha Voyager Brake controller!
A little rough but its a truck not a show car!!!
In its former life it worked for the US GOVT
  #3 (permalink)
Old 07-04-2009, 11:45 AM
I think it would be ok if I could figure out a way of pulling the thing out of there fairly quickly. I put studs in the exhaust chamber to make it easier to put on the exhaust flange. I'm going to put clamps on the exhaust pipes but, I still have the problem of the exhaust pipe that feeds the turbo, I have to come up with a good way of getting that out of there. Any suggestions?
  #4 (permalink)
Old 07-04-2009, 11:52 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
davelance01,
Welcome to FTE and the IDI diesel forum.
Given the limited amount of space under the hood and the plumbing a turbo requires, you will find some jobs will take longer on a turbo motor.
This model is in the way for one job, that model is in the way for another job.
I am running an ATS 093 turbo, and it makes changing the glow plug on #7 cylinder a real pain.
Removing the IP is also a lot harder since the injection lines must be removed from the IP before it can be removed.
But other than that it is rather out of the way.
But I also have a T 19 transmission, so the bell housing is seperate from the transmission which makes that job easier.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
