Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-04-2009, 03:49 PM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
yeah, I did take the line off. I must've misunderstood what you meant, there was no fuel in the line or on top of the FPR itself. I thought you meant inside the FPR, so I took it off and gas came out the bottom. Go ahead and call me a dumba@#.
__________________
Frank
Stockbridge, Ga
  #17 (permalink)
Old 07-04-2009, 09:12 PM
Well Subford, I went ahead a replaced the FPR even though I may not have needed to and there is no change in the way it runs. It still acts as though it wants to stall, but when pressed to the floor it'll go. The backfiring I'm hearing I think may be detonation, but I'm not sure on that. I'm tired of throwing parts at it and I don't have the money, but I would like to get my truck back to working order. I guess I'll take it to the Goodyear place where my neighbor used to take it and have them look at it. I don't think it would be a good idea to drive it 20 miles to my brother-in-laws dealership. Thanks for the help though.
__________________
Frank
Stockbridge, Ga
  #18 (permalink)
Old 07-04-2009, 11:39 PM
Dre82s Dre82s is offline
Dre82s is starting off with a positive reputation.
get a bottle or started fluid and spray around you engine for vacuum leaks. check your distributor cap and rotor for damage. battery light coming on could be a bad ground somewhere... start small do not just go changing sensor, the economy is bad, but is it not up to you to keep the auto parts store open. good luck!
  #19 (permalink)
Old 07-05-2009, 09:32 AM
I'm just curious, but what does starting fluid do when I spray it around the engine? What do I need to be looking for? I've never done that before, I can do a few things to a truck or a car and can figure some stuff out on my own. Some of these tricks ya'll seem to know I'm still learning. The cap and rotor are basically new, but I will check it anyway. Now if that's it I going to shoot myself in the foot for not figuring that out. But thank you
__________________
Frank
Stockbridge, Ga
  #20 (permalink)
Old 07-05-2009, 09:54 AM
Well I sprayed starting fluid on the engine while it was running and I guess it's supposed to rev higher when a vacuum leak is present. Well it did around the TB the tube in the middle of the TB giong to the thing that sits beside the EGR. I have no idea what it's called and I wish I could get a picture of it, but I'm technologically challenged. Could this be my problem?
__________________
Frank
Stockbridge, Ga
  #21 (permalink)
Old 07-05-2009, 06:35 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is starting off with a positive reputation.
Not sure of the part name either, but I think this is the part you are referring to.
__________________
Dave
1994 F-150 XL Supercab 4x2 300CID-I6
1994 Bronco XLT 4X4 302CID-V8
  #22 (permalink)
Old 07-06-2009, 08:17 AM
Thanks Ottawaguy, Subford told me it was the cannister purge solenoid or the fuel vapor solenoid valve.
__________________
Frank
Stockbridge, Ga
Tags
350 , 460 , bogging , rv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
