Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:46 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
Post Carburation questions.
I have a 390 in my '76 F-350 2WD.
I had a Holley Rebuilt 4-Barrel Double-Pumper,Auto Choke I had my dad rebuild.
Well anyways,We pulled the Holley off and got a Edlebrock-1407-4-Barrel,Manual Choke.
I want to put the Edlebrock on,But,there are no Choke switches in my cab or anything...
So would this carburetor bolt right up and then what do I do?
Here are some pictures... (I need to try and get some of The Edlebrock.)
I will keep ya updated,so thanks in advance.
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #2 (permalink)
Old 07-03-2009, 10:56 PM
1969Highboy 1969Highboy is offline
1969 Ford F-250
1969Highboy is starting off with a positive reputation.
should bolt right up, just make sure you use new gaskets so there's no vaccumm leaks, and make sure you know which ones the pcv port, gas port, distributor port-if have a vaccum advanced distributor otherwise it should be plugged. But the edelbrocks and holleys are a bit different so the ports aren't in the same spots. also with the manual choke, you should just be able to run a cable into the cab and hook it up right under the dash, some dashes have holes for the choke since that's how they usually came stock. the throttle linkage might also have to be modified a bit.
  #3 (permalink)
Old 07-04-2009, 03:59 PM
1976 Ford F-350
My Garage
OK got some more pictures.
These are of the Edlebrock I wanna put on the truck.
__________________
  #4 (permalink)
Old 07-06-2009, 03:39 PM
65f100_352 65f100_352 is offline
65f100_352 is gaining momentum as a positive member of FTE.
It'll bolt right up, and as far as the manual choke, Napa or a parts store should have a kit, real simple to install. BTW that's not a double pumper, but whats wrong with the holley?
__________________
1965 F100 Custom Cab 390,NP435 "GoldRush"
1978 F250 Ranger XLT 460,C6,NP203 "Big Ugly"
1976 F250 Custom 3?? FE, NP435 NP205 "Frankenstein"
Non Ford:
1986 Nissan 300zx (daily driver) "Miami Vice"
  #5 (permalink)
Old 07-06-2009, 07:16 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is online now
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
Quote:
Originally Posted by 65f100_352 View Post
......................BTW that's not a double pumper, but whats wrong with the holley?
That's what I was wondering. Going from a KISS to tune carb to pull your hair out to tune carb makes no sense to me.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #6 (permalink)
Old 07-06-2009, 07:19 PM
1976 Ford F-350
My Garage
it leaks around the floats.
some-one told me that Holley are notorious for leaking.
I thought it was a Double Pumper...
Now to go to Napa's web-site and find the kit...
Thanks for the help.
__________________
  #7 (permalink)
Old 07-06-2009, 07:30 PM
Bear 45/70's Avatar
New gaskets have always cured this problem for me and I wasn't aware that it was a chronic problem, but then what do I know, I've only been running Holley carbs since 1960.
__________________
  #8 (permalink)
Old 07-06-2009, 07:36 PM
1976 Ford F-350
My Garage
Well my dad rebuilt that thing,replaced everything...and it still leaked.
__________________
  #9 (permalink)
Old 07-06-2009, 10:35 PM
Madathlon's Avatar
Madathlon Madathlon is offline
Madathlon is starting off with a positive reputation.
I run that same Edlebrock on my 427, it was a very easy set up and install, you will need to get the ford arms to correctly fit, I can get pics if you want to see it fully install and what hose goes where.
__________________
If it ante broken dont fix it.. If it is.. hit it with the biggest hammer U can find :P
  #10 (permalink)
Old 07-06-2009, 10:44 PM
1976 Ford F-350
My Garage
That would help a-lot.
On a un-related note,if you look closely in the background of my pics you might notice something about my truck.
__________________
  #11 (permalink)
Old 07-06-2009, 11:03 PM
Madathlon's Avatar
ok You asked for them
Edlebrock Hidden from sight, And Yes I run with no Hood
Edlebrock ID
Edlebrock close up of hoses, Big one PVC, small one Dist.
Edlebrock Right Side
Edlebrock Close up of Linkage
Edlebrock Left Side
Edlebrock front
Hope this helps.
__________________
  #12 (permalink)
Old 07-06-2009, 11:24 PM
1976 Ford F-350
My Garage
Thanks for the pictures!
The weather has gotten to your engine...
He/She needs a bath.
What was going in those holes of your fire-wall?
I see your truck is an automatic.
__________________
  #13 (permalink)
Old 07-06-2009, 11:27 PM
Madathlon's Avatar
The weather here been over 100*F and will be that way till winter. Shockenly this engine just went thru a full rebuild about 2000m ago. LOL
__________________
  #14 (permalink)
Old 07-07-2009, 01:56 PM
1969 Ford F-250
That holley was a double pumper dont worry, as you can see that thin pipe along the side carries fuel to the secondaries. alot easier set up than having to fuel ports and its less likely to leak. its a double pumper whether some people think so or not.
  #15 (permalink)
Old 07-07-2009, 03:18 PM
Bear 45/70's Avatar
Quote:
Can't be a double pumper, it has the vacuum secondary unit on the right rear of the carb. Which is where the second pump would have to be and can't be because of the vacuum unit. All the pipe on the left side does is feed fuel from the inlet to the rear float and needle and seat and then to the fuel bowl.
__________________
Tags
360 , 390 , 4150 , carb , carburation , choke , e350 , fix , ford , gaskets , holley , kit , manual , napa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
