Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:16 PM
00blkexplorer 00blkexplorer is offline
00blkexplorer is starting off with a positive reputation.
Just got my Bronco! Got some questions...
For a while now, I was doing a lot of reseach on these trucks, and I finally bought mine! And I think I made a great purchase!
It's a 1992 Ford Bronco with 266k on it. Recent engine rebuild. Good paint and interior. For only $500! I drove 100 miles just to go get it.
Now I got some things that i'm hoping you guys can help me with. First of all, the rear driveshaft wobbles going 50MPH and it has a clicking noise when I first accelerate. I think they are the u-joints, am I wrong? Are those hard to replace?
Next, the turn signal lever broke off, are those expensive? Do I have to replace the whole steering column or can I just buy the lever?
The ignition key ring (the chrome thing where you put the key in) moves without the key, it spins freely, can that be fixed?
I need a front driveshaft, are those expensive? Does anybody on this forum have a extra one?
And I never had this happen before, when I brake, the pedal pulses. But not like when the brakes are warped, but a steady pulse at any speed, what can that be?
The rear window switch ain't working, is that expensive and easy to fix?
And last, I want to give it a real nice detail and scrub down since the interior needs to be cleaned, what do you guys use to clean the carpet and seats?
Any help I can get will be greatly appriciated! I'll post some pics of my new truck later on, just had a long day driving the truck down. Thanks!
  #2 (permalink)
Old 07-03-2009, 10:25 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
Check out the FAQ link in my signature. As for the front driveshaft, send me a PM. I've got at least one floating around.
Does the t-gate glass move with either switch (key in the gate or dashboard switch)?
If it works one place and not the other you may be in luck and just dealing with a dead circuit breaker (dashboard fuse block positions 13 and 14 are the auto resetting CB's for the tailgate window). If it works with one and not the other, try swapping the CBs and see if the working switch changes.
The multi-function switch in the column can be replaced you just have to dig into the column a little. and you will have to replace the whole switch not just the lever.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #3 (permalink)
Old 07-03-2009, 11:14 PM
Great! Thanks! I think my only concern is the brakes. There is a constant pulse at any speed. Could it be the master cylinder that needs to be replaced?
  #4 (permalink)
Old 07-03-2009, 11:21 PM
Aciancio's Avatar
Aciancio Aciancio is offline
Aciancio is starting off with a positive reputation.
do you hear any strange noise when you brake? it sounds a little like the ABS is kicking in
  #5 (permalink)
Old 07-03-2009, 11:34 PM
McLeod's Avatar
McLeod McLeod is offline
McLeod is gaining momentum as a positive member of FTE.
My first thought was ABS also.
I just disconnected mine.
IMO, it drives much better in the ice this way.
__________________
Just Say No!
'93 F 150 - 5.0, E4OD, 4.56, 33" & 4" Rancho lift
'95 Bronco - 5.8, E4OD, 3.55, 265/75 15 Goodyear Wrangler SilentArmor (excellent tire)
'67 Bronco Roadster, 351w, 4.11's, 5 inch Skyjacker lift
  #6 (permalink)
Old 07-04-2009, 12:10 AM
I know when the ABS kicks in. Its a faster pulse with ABS. This is a slow pulse.
Also, i've been trying to find out how to change out the rear driveshaft u-joints. I wanna take care of it tomorrow morning, but I can't find any how-to's..
  #7 (permalink)
Old 07-04-2009, 10:24 AM
jcee jcee is offline
jcee is starting off with a positive reputation.
When you go to replace the turn signal switch remember there's an airbag that must be removed first. Please use caution and disconnect both battery leads and let it sit that way for a while. Remove the 4 nuts from the back of the steering wheel that hold it in place, while you are either under or beside the steering wheel. Not sitting on the seat. Carefully remove the airbag assembly, unplug it and lay it aside. Far aside. Use the same caution on reinstalling it. These can be dangerous if mishandled.
Not trying to scare you away from working on your Bronco, which is half the fun of owning one, but do be careful. If you have any questions ask them here. This is the BEST place for answers. If it's on a Bronco someone here has fixed, replaced, repaired, painted, adjusted, tweaked, upgraded, improved, or removed it 'cause it wasn't original and didn't belong there.
  #8 (permalink)
Old 07-04-2009, 10:28 AM
1992 Ford Bronco
Warped rotors? While hard to believe, still a possibility.
Nice thing about the rear DS U-joints is that you can remove the driveshaft from the truck without having to remove the u-joints. Some prefer to leave the driveshaft in the truck when doing this, personally, I find it much easier to work with the driveshaft on a bench. Mark the relative position of the flanges BEFORE you remove it. Its not always critical but some have installed the shaft clocked differently than it had been and experienced vibrations. If you disassemble the slip-shaft to lube it (recommended while its out of the truck) DEFINITELY mark the two halves so as to get the splines back exactly as they were because this WILL cause balance issues and vibration if mis-assembled.
If your u-joints have no metal retaining clips, you are dealing with the OEM u-joints and the nylon retaining ring will have to be broken to remove them. This involves setting the yoke in a vice and either pressing (preferred) or pounding one bearing cup until the retainers break and the cup on the opposite side of the yoke pops out far enough to grab it and pull it out of the yoke. Not to worry the replacement u-joints will have typical metal retainers that are installed after the u-joint is installed. Make certain you lube the u-joints before reinstalling the driveshaft. If anything is still vague, let me know.
__________________
  #9 (permalink)
Old 07-04-2009, 11:09 AM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Is it a carpet interior? I have vinyl flooring in my 1990 Bronco, it's a mixture of alittle blue a little grey and a little dirty.
I found that "scrubbing bubbles" works good on carpet to clean it.
On vinyl I'm going to use soapy water, a stiff brush, (plastic not wire) and some of that good ole elbow grease and sweat.
  #10 (permalink)
Old 07-05-2009, 02:54 AM
Now I got a problem. I took out the u-joints and there is a ball between two u-joints that is messed up. What is that part called? Can only the metal ball surrounded in rubber be replaced?
Also, since i took apart the u-joints, I don't remember which way it went? Is there anyway I can tell to do it correctly so I don't affect the balance?
  #11 (permalink)
Old 07-05-2009, 08:38 AM
You completely disassembled the CV joint? Were both U joints loose? Did you mark any positions prior to taking everything apart? This must be reassembled correctly. To attempt this yourself get a Chiltons manual and follow it to the letter to rebuild this joint. You can rebuild it if you take your time but since this is your first time my recommendation is you take all the pieces to a driveline shop and get it rebuilt. Hopefully they'll let you hang out and watch the process and ask questions. An incorrect rebuild will cause vibration and excessive wear. You don't need the aggravation of pulling this every few months and rebuilding it. The part you question is called a centering ball and yes all parts are replaceable but don't mix used and new. All new parts guarantee a reliable rebuild.
  #12 (permalink)
Old 07-10-2009, 10:06 PM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
Bad CV joints rarely show themselves by being loose (like conventional u-joints will). Far more common is a worn CV joint binding. In this case the joints wil appear to be fine if you check them on the vehicle in the same way as you check a conventional u-joint for play. The only way to find out if your cv joints are binding is to remove the driveshaft and rotate the cv joints around in every direction; if they are binding you will be able to feel it.
A binding cv joint can also give you noises that sound similar to what a conventional u-joint sounds like when it's bad, but in this case the noise is caused by the binding and not by looseness. Vibration is also a symptom of bad joints but in this case it's for both cv joints and u-joints.
I strongly advise you to get your driveshaft rebuilt and balanced by a professional. I paid $400 to have mine done and it was worth every penny. If you want to save a few bucks it's easy enough to put the shaft on yourself, they only charged me $50 for labor so I let them put it on for me!
So to those in Bronco land who have these symptoms but thought that the joints were fine because they checked them for play while on the truck, pull the shaft and check for binding of the cv joints.
__________________
1990 Bronco XLT two-tone grey and black.
351 5.8 liter, E4OD automatic trans.
Loaded. Most, if not all, XLT options.
146K miles and counting!
  #13 (permalink)
Old 07-11-2009, 12:16 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 is starting off with a positive reputation.
brakes sound like parrallism, which is when the rotors get thiinner and thicker, and can be checked with a micrometer. if they still have enough meat on them any good shop could check, and turn them if possible.
i got the shaft in my bronco out of phase once, before i knew better. I know better now...
and it sounds like you will need a new ignition switch.
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
  #14 (permalink)
Old 07-11-2009, 01:22 AM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is starting off with a positive reputation.
Congrats on getting that Bronco.
We'll have the issues sorted out quick enough..
The brake issue has me puzzled though.
A steady pulsating that doesn't change with speed...hmmmmm
Let us know what you find there.
Regardless....all the issues are relatively small and will be worked out quick enough.
Good luck!
__________________
Dave
1994 F-150 XL Supercab 4x2 300CID-I6
1994 Bronco XLT 4X4 302CID-V8
  #15 (permalink)
Old 07-11-2009, 11:01 AM
helirich helirich is offline
helirich is starting off with a positive reputation.
The ball in the middle of the u-joints is a carden joint. I may be in the mynority, but I have replaced all the u-joints (including the carden) without marking anything and they ran fine. I have done this many times on many vihicals.
The u-joints are made very percision. The driveshaft is balanced at the factory to account for it's lack of percision. If the weight is still on it, it should be fine when you put new joints on.
I will say you should mark the slip sleeve if you take it apart. This is not so important when the shaft has a carden. (Upmost importants if there is no carden) But I dont see the need to dissasemble this anyways. (pump some new greese in if needed.)
I have not heard of balance issues when installing a shaft clocked differnt. I'm refuring to clocked differnt between the transfercase and the diff. (not the slip sleeve) They dont balance the shaft on the truck, so its just luck if it runs better at a perticular clocking. It really shouldnt run any differnt at any spot.
I deffiantlly would recomend taking the shaft off the truck and putting it in a vise. I have never seen the nylon retaining ring that Greystreak spoke of. (I guess my trucks are to old.) You learn something new everyday.
I got to believe the brakes are ABS. IS it possible the brake light is shorted and making the ABS pulse slowly? When you step on the brakes, is the volt meter going down excessivly?
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
