Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 09:41 PM
Sawsall Sawsall is offline
Sawsall is starting off with a positive reputation.
Tranny Choices for a 400M
The C6 is in need of replacing... any overdrive tranny's bolt up, preferably non electric?
Thanks
  #2 (permalink)
Old 07-04-2009, 01:07 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
ZF 5spd from a 460 will bolt up.
-Johnboy
__________________
-1979 F-250 4X4 351 Cleveland 4spd
-1982 F-150 Short bed 300 six 4spd
  #3 (permalink)
Old 07-04-2009, 01:10 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Unless you have the one year (1973) with the SBF pattern, you have the 385 pattern, same as 429/460. Thus, the only OD is the E4OD, an electronic trans. You can buy an AOD with an adaptor, but the adaptor alone is $700 or so, and a beefed AOD is $2000. You can buy a controller for the E4OD for about $500.
A Gear Vendor unit for the tail of the C6 is about $3000.
I expect $4 gas again soon, but even at that, you'll have to run many a mile to realize a savings here methinks.....
What truck is it in? What rear axle? You can get a lower first and second for the C6 and run a taller axle in SOME cases....
  #4 (permalink)
Old 07-04-2009, 09:51 PM
motor and tranny is from a 78 F150. all the above is too rich for me
It is in my 66 Funhundred, I don't think it has stock gearing in it? I've been going to check it out... I have the rear end from the 78 F150 which is wider, going to see if it is taller geared and same spline count so I don't have to reset everything... if not, I'll change the ring & pinion...
I'll probably go for the lower 1st & 2nd option and rebuild the C6
Thanks for the replies
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
