Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 09:36 PM
jpr0525 jpr0525 is offline
jpr0525 is starting off with a positive reputation.
02 f250 4wheel drive problems
front axle will not engage! thought it was the transfercase acuator for the shift on the fly replaced it. then thought it was the hubs ,wanted warn manuel hubs anyway, replaced them with the warns. still not working. recently changed all gear oil and inspected inside the pumpkins all looks really good. changed the vacuum actuator on the fender well still nothing! any ideas where to start next? its driving me nuts and hunting season will be here b4 you know it!
  #2 (permalink)
Old 07-03-2009, 11:24 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Welcome to FTE. So you've got warn hubs and switching them to lock still doesn't put you in 4wd? If you lock the hubs, can you spin the front drive shaft by hand with the truck in park?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 07-04-2009, 01:48 AM
never even thought about tryin to be honest! like i said this has been drivin me nuts!its a 6 speed manual so ill try that with it in gear and get back to ya. thanks for replyin. need all the help i can get! hope you keep helpin dont want to have to take it ford. for a month and a half now
  #4 (permalink)
Old 07-04-2009, 11:45 PM
im back! had time to check the driveline and it spins w/ hubs out of course, and spins w/with hubs locked and in 2 wheel drive of course, then locks up or doesnt spin when i engage the 4wheel drive just like its supposed to! im completly lost next step?
  #5 (permalink)
Old 07-04-2009, 11:52 PM
F350-6's Avatar
Slow Typing
I'm by no means a 4wd expert, but if it were me, my next step would be to jack up the front end, put it in 4wd, and spin a tire to see if the tire will spin or try and move the drive shaft. Or stick it in neutral and spin the front drive shaft and see if you can make the wheels turn.
__________________
Chris
  #6 (permalink)
Old 07-05-2009, 01:48 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
If you do a search you can read all night about 4wd engaging. Crawl under there and turn your front driveshaft by hand and then turn each front u-joint by hand. If you don't know if it is working, get on a gravel road and hit the gas hard from a stop and then look at your tracks on both front sides. Also; you should get that wiggly feel from the front u-joints because they speed up and slow down rapidly as they turn.
  #7 (permalink)
Old 07-05-2009, 12:18 PM
have done both exv10 ! after spending about 4 hours of time on the computer i had three diffrent people from tree diffrent web sites tell me to come here!they said this was the best website for my problem or any problem i have with my truck. the gravel road is where where i keep going to test it but thanks for the help! if you have any more ideas please let me know. im still lost! this is makin me feel stupid and ive been workin on my rigs 4 years!
  #8 (permalink)
Old 07-05-2009, 02:24 PM
FireMe FireMe is offline
FireMe is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by jpr0525 View Post
...and spins w/with hubs locked and in 2 wheel drive of course
If that isn't a typo, then you have a problem. The purpose of the hub locks is to connect the hubs to the front axle shafts. With the hubs locked and the front tires on the ground, none of the front axle components or the front drive shaft should spin with the t-case in 2wd.
With both hubs locked and the front tires on the ground, try to turn each axle shaft at the u-joint next to the steering knuckle (it takes some effort.) If either one turns, then your hub locks are not engaging or the splines on the stub shaft are stripped. You'll have to take it back apart and determine which one it is.
If neither shaft turns at the u-joints, but the driveshaft spins, there is a problem in the differential.
  #9 (permalink)
Old 07-05-2009, 03:39 PM
EXv10's Avatar
If everything is locked up it should work. Are you sure it's not working? I would say blown spider gears but you said you checked it. Next I would say an axle is twisted off at the splines.
  #10 (permalink)
Old 07-05-2009, 09:45 PM
ok checked it all out again! every thing spins when hubs are out and in 2 wheel drive. lock hubs and and in two wheel drive knuckles do not turn and either does the front drive shaft. hubs locked and in 4wheel drive knuckles lock and driveline does not turn.so what do you guys think? front driveline should spin when truck is in 2 wheel drive even if hubs are locked shouldnt it? it shouldnt it only lock the driveline lock when i engage the 4 wheel drive?still lookin for all help i can get! thanks for all your help keep it comin im gettin closer i think!
  #11 (permalink)
Old 07-05-2009, 10:30 PM
EXv10's Avatar
The front driveshaft shouldn't spin in 2WD with wheels on the ground and axles locked. That is why I think you might have a broken long axle near the splined end.
  #12 (permalink)
Old 07-05-2009, 10:38 PM
driveshaft doesnt spin when im in 2wheel drive and hubs locked ! im thinkin its my actuator on the back of the transfercase even thouhg its only six months old i dont think it engaging the transfercase all the way!
  #13 (permalink)
Old 07-05-2009, 10:42 PM
EXv10's Avatar
Lots of info in here on that if you do an advanced search.
  #14 (permalink)
Old 07-06-2009, 12:10 AM
Thanks ill give it a shot
  #15 (permalink)
Old 07-31-2009, 10:39 PM
well im back with the same problem! never got it fixed yet. i took it to the local transmission shop and they told me that it was the clip on the transfer case motor! say the see it alot, and with it not getting good connection it probably took out the motor. so i replaced both still not working> knuckles lock drivline locks up but dont turn wheels . im worried it the axles splines. anything else you guys can think of to check b4 i tear into it and check axles! also can any one tell me where the relays are? ive looked in my owners manuel nothing searched and searched under hood cant find.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
