Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 09:11 PM
beersy50 beersy50 is offline
beersy50 is starting off with a positive reputation.
HELP Please!!
I just replaced my oil cooler on my truck (had a horrible time getting that to seal) and now its blowing the seal out of the side of the oil filter. I replaced the filter when I changed the oil w/ the cooler (a fram) and that leaked, that only had a cut seal so I stole the seal from the old filter and that worked for one trip to and from work (about 30 miles total). On the next trip it blew out the seal, just bought a new one from Advanced and it blew the seal instantly it actually made the flat bottom of the filter dome shaped. Oil pressure reads normal for the few seconds it runs.
__________________
Beersy50
'89 F-350 7.3 idi Dump Truck 5-speed 4x4
  #2 (permalink)
Old 07-03-2009, 10:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
I have never had good luck or been a fan of Fram filters.
My two filters of choice are either,
Motorcraft Power Stroke filter FL 1995
Fleetguard LF 3630
Both filters are the large two quart versions.
On a side note, the oil pressure regulator is in the rear oil cooler header and bleeds excess pressure to the crankcase.
Any chance you blocked that passage when you reinstalled the oil cooler?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 07-04-2009, 07:09 AM
I suppose thats possible, I guess I'll pull the cooler off and check. Two more quick questions: Do you have any pics of the regulator? And what do you think about using the tube gasket sealer stuff on the oil cooler? Thank you for your help, I was completely lost.
__________________
Beersy50
  #4 (permalink)
Old 07-04-2009, 12:21 PM
1986 Ford F-250
I used a bit of RTV on the gaskets when I installed mine.
But I am not a fan of very much RTV on anything.
I have a picture of the regulator, but I am having trouble uploading pictures to my gallery right now.
Well I have not tried for a couple days, I will try later today again.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #5 (permalink)
Old 07-04-2009, 02:12 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Dave,
I talked to Adrian about this, the gallery is broke, but the users Album works fine.
I also got the impression the Gallery is not going to be fixed, however he did not say that exactly.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #6 (permalink)
Old 07-04-2009, 09:01 PM
1986 Ford F-250
Yes I think the galleries will be fixed, just don't know when.
And there is a new thing, the garage which is another place for pictures.
I have not messed with it yet to figure out if it could replace the galleries.
As for the album's still need to check that out.
What I need to figure out is the tech pictures were hidden in the galleries, only truck pictures were visible.
Yes you could still view the tech albums after you went to the user gallery, but they were not displayed in the gallery list.
I just need to figure out which will work best for me, I have to many tech type pictures I use in my posts.
Trying to figure this all out back this winter when I was not working much would have been great, but not in the middle of my busiest work season.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #7 (permalink)
Old 07-04-2009, 09:09 PM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
so the oil filter seal is getting blow out? Damnit man now that is a new one to me!
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #8 (permalink)
Old 07-04-2009, 09:32 PM
I don't think the Garage would be the ticket for your techie images, though I have not played with it much.
I have only used the Album, Every since I joined the Gallery has been broke, the Albums let you make the image public or private and thats how I've done it.
Don't know how the broke .... Gallery works!
It's strange that they are upgrading a broken system, In my book thats poor admin.
-Enjoy
fh : )_~
__________________
  #9 (permalink)
Old 07-04-2009, 09:57 PM
1986 Ford F-250
I did here FTE was wanting to migrate from the Gallery to either the garage or albums in time.
But for those of us with many images in the galleries, it will be continued for an undetermined amount of time.
Basically the gallery was one of the first casualties of the forum software upgrade.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 07-04-2009, 10:38 PM
Thats strange Dave, I've been a member since March 09, It's been broke since before then, The upgrades were just done!
At least thats what I've seen, But I have no inside info as you do as a moderator.
No biggie, lets move on!
-Enjoy
fh : )_~
__________________
  #11 (permalink)
Old 07-05-2009, 08:12 AM
Quote:
Yeah! not only did it blow the seal out made the end of the filter dome shaped, cracked and flaked the paint off and everything!
__________________
Beersy50
  #12 (permalink)
Old 07-05-2009, 12:02 PM
1986 Ford F-250
As I read this again, how tight was the oil filter?
Minimum is 1.5 to 2 turns after the gasket contacts the filter adapter.
When I change mine, it goes on as tight as I can get it by hand, then 1.5 turns with the wrench.
Any less and I have a leak.
If the filter is not tight enough, the gasket will blow out.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 07-05-2009, 03:44 PM
my origional thought was the same as yours. The first filter was as tight as I could get it by hand the first time then I cranked it right down with a wrench and it held for one trip to and from work.
On a similar note, yesterday I took of the cooler and checked everything aginst the old one. Everything I could see looked fine, there was some gasket sealer in the main oil passage but it was far from being blocked, so we put it back together. I waited 24hrs for the gasket sealer to completely cure before trying to start it. Just started it, the oil filter held out fine for the 10 seconds it ran. Its leaking between the block and the cooler in the front mount again. Any suggestions?
__________________
Beersy50
  #14 (permalink)
Old 07-05-2009, 09:22 PM
1986 Ford F-250
When I do mine, I let the RTV set up rather well before I bolt the parts together.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 07-05-2009, 09:28 PM
oh. I bolted it togther imeediatly and just snuged the bolts up. then after 24hrs I retorqued them. Well I have to take it off again so I'll try it that way. Thanks for your help.
__________________
Beersy50
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
