Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 08:56 PM
UaVaj UaVaj is offline
UaVaj is starting off with a positive reputation.
Tranny Slipping - Castrol ATF Fluid??
I recently change the tranny fluid with 6qt of castrol dosmestic multi-vehicle formula.
http://www.castrol.com/castrol/secti...tentId=7027043
The tranny is now slipping at higher rpm. Tranny is smooth and shifting normal through all gears including overdrive ONLY if I keep the rpm low below ~3000.
If I drive it like I stoled it or if I need to quick acclerate. Anything above ~3000rpm and it will slip completely (as in 100% slip). As soon as the rpm comes back down to ~2500 she lockup again.
I think it is the fluids. It was not slipping prior to the fluid change. Anyone experience this with Castrol ATF Domestic Fluid?
__________________
00 F250 SC XL LB V10 4x4
  #2 (permalink)
Old 07-03-2009, 09:04 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
Well I would start there. What you need to do is a complete flush of the system and then the correct type fluid in there.
I suggest that you take it in to a Ford quick lube place and get the trans flushed. They can heat the fluid and rinse it out. A little pricey but much better than where you are headed for right now.
Try not to drive it till you can get it done is my best advice.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #3 (permalink)
Old 07-04-2009, 08:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
I have no experience with that fluid, but it should not cause a problem. It meets the specs that your trans was designed for.
Check the fluid level with the trans warmed up and the engine idling in park. Low fluid could do this. So could a loose internal filter.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 07-04-2009, 10:59 AM
fluid level is good. I only put in as much as I sucked out. It is on the correct making on the stick while engine is idling in park.
as for the loser internal filter. I didn't take the pan off. I only sucked out the tranny fluid. I stick the tube in as far as it could go. Could it be possible that the tube knock the filter off it's installed position?
In your 9 year of ford auto tranny engineer. have you ever seen anything like what I just described?
__________________
  #5 (permalink)
Old 07-04-2009, 12:11 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
What I find weird is that from that web page: "Do not use this ATF in applications calling for MERCONŽ V "
Since Mercon V is now spec'd for EVERYTHING that ever used Mercon or Mercon V, I find it very strange they would say it's not Mercon V compatible.
HOWEVER, it still should be OK because your 4R100 called for plain Mercon to begin with.
I'm with Mark: Low fluid.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #6 (permalink)
Old 07-04-2009, 12:12 PM
Quote:
Yes, it's possible, but not too likely.
2007-1988 = 19.
Yes, I have, and it was due to low fluid or a loose/misinstalled filter.
__________________
Mark
  #7 (permalink)
Old 07-04-2009, 12:14 PM
Quote:
It makes sense to me. The biggest difference between MERCON and MERCON V is that V has anti-shudder additives. Running MERCON in a trans that requires MERCON V will usually result in torque converter and shifting shudder.
__________________
Mark
  #8 (permalink)
Old 07-04-2009, 12:40 PM
Krewat's Avatar
Quote:
Oh, it makes sense to me TOO... technically.
Marketing wise, and after Ford went all-Mercon V, it's just weird.
__________________
  #9 (permalink)
Old 07-04-2009, 01:46 PM
MERCON V can replace MERCON, but MERCON cannot replace MERCON V.
__________________
Mark
  #10 (permalink)
Old 07-04-2009, 04:03 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
The link for the tranny fluid also stated not to use in applications calling for Mercon V and Mercon SP. I would get that fluid out of there asap.
  #11 (permalink)
Old 07-04-2009, 04:09 PM
BMWM1 BMWM1 is offline
2003 Ford F-Super Duty
BMWM1 is starting off with a positive reputation.
Is there not a drain plug on the transmission ?
Did you have any trans issues before the change?
I would think the first thing to do is remove the fluid.
__________________
  #12 (permalink)
Old 07-04-2009, 04:31 PM
senix's Avatar
no drain plug, either remove the pan or go for a flush. In the ops case he needs a flush to get it out of the torque converter.
__________________
  #13 (permalink)
Old 07-04-2009, 04:44 PM
My 05 PSD SD had a drain plug on the tranny, but no way to drain the converter. A flush and filter change seems to be the best way to go and hope no damage is done.
  #14 (permalink)
Old 07-04-2009, 05:01 PM
From the owner's manual from ford official website.
Ensure the correct automatic transmission fluid is used. Transmission fluid requirements are indicated on the dipstick or on the dipstick
handle. MERCON and MERCON V are not interchangeable. DO NOT mix MERCON and MERCON V. Refer to your Scheduled Maintenance Guide to determine the correct service interval.
Some transmission fluids may be labeled as dual usage, such as MERCON and MERCON V. These dual usage fluids are not to be used in an automatic transmission that requires use of the MERCON type fluid. However, these dual usage fluids may be used in transmissions that require the MERCON V type fluid.
MERCON and MERCON V type fluids are not interchangeable. DO NOT mix MERCON and MERCON V. Use of a transmission fluid that indicates dual usage (MERCON and MERCON V) in an automatic transmission application requiring MERCON may cause transmission damage. Use of any fluid other than the recommended fluid may cause transmission damage.
https://www.flmowner.com/servlet/Con...OwnerGuidePage
http://www.motorcraftservice.com/pub.../00f23og3e.pdf
__________________
  #15 (permalink)
Old 07-04-2009, 05:58 PM
senix's Avatar
So let us know what you do the results.
__________________
Tags
4r100 , application , atf , castro , castrol , chart , compared , crown , fluid , good , licensed , mercon , motorcraft , transmission , vic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
