Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 07:07 PM
kjf-250 kjf-250 is offline
kjf-250 is starting off with a positive reputation.
2007 F-150 Front Rotors
Hi,
My wife has an 07 F-150 2wd w/ 60,000 miles an the front rotors are warped. I'm planning on taking them off an gettin them turned an was wonderin if there is any trick to getting them off. Does the whole bearing have to be removed or will it come off if you take the brake caliper an bracket off?
Thanks,
Kjf-250
  #2 (permalink)
Old 07-03-2009, 07:22 PM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
I don't know for 100% sure, but I think you just need to move break caliper out of the way and the rotor should just come off. At least that's the way my wife's Subaru works and was told by a mechanic friend of mine that all the late 2wd vehicles are like that.
BTW, good luck on getting them turned. I'll bet you are told that they can't be.
__________________
2007 F150 XLT SCREW 4 X 4, 5.4, 3.73 LIMITED SLIP, TOW PACKAGE. CHROME DOOR HANDLES TRUXEDO TONNEAU COVER, TTT TOW MIRRORS.
"I would rather push a Ford than drive anything made by GM."
  #3 (permalink)
Old 07-03-2009, 08:00 PM
Thanks for the info. Why cant they be turned? I really hope I can get them turned b/c I dont have money right now to buy new ones.
  #4 (permalink)
Old 07-04-2009, 07:40 AM
svt2205 svt2205 is online now
svt2205 is starting off with a positive reputation.
If there's enough material left on your rotor, they can certainly be turned.
Most shops today, replace rotors vs turning, the charged labor vs actual labor is in their favor by replacing. Most shops no longer have a drum/rotor turning machine.
Find a local partstore that has an inhouse machine shop. They can turn your rotors for you. Just price it out first, as you may find you're not saving enough by going the turned rotor route. (quick look at rockauto.com, shows it's much cheaper to get them turned)
Two important things for you to be aware of. The spindle nut must be replaced, as it's a one time use item. And it needs to be torqued to 295 ft-lbs.
Looks like you can get the spindle nut thru sources other then the dealer. Rockauto has it listed as RAYBESTOS Part # 28492 {Professional Grade} Front; Two Wheel Drive (4x2) for $13.48
__________________
07 F150 Lariat Supercab, 6.5' 4x4, 5.4, 3.73LS, 7.5' Fisher SD Plow
  #5 (permalink)
Old 07-04-2009, 01:15 PM
GwarForAll1021's Avatar
GwarForAll1021 GwarForAll1021 is offline
GwarForAll1021 is starting off with a positive reputation.
this the same for a 4x4?
  #6 (permalink)
Old 07-04-2009, 02:15 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL BatteriesNotINCL is offline
USAFCombatControl Trainee
2004 Ford F-150
BatteriesNotINCL is starting off with a positive reputation.
GwarForAll1021,
It is not the same, 4x4's have floating discs and are much cheaper. To my recollection 4x2s have an all in one (hub&disc) unit. When I changed my brakes out they almost fell off when I took the caliper bracket off...
__________________
2004 SCAB FX4 3.55 R GEARS
Daystar Kit,325/65r18 Terra Grapplers, Edge Evo, Super40, AEM CAI, Poweraid TBS, Pioneer In-dash DVD Player, 2000w Audio 6 Speaker+2 Sub System, GPS Tracking, PIAA 4000K Bulbs
  #7 (permalink)
Old 07-04-2009, 02:16 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
No, I changed the rotors on my 04 4x4 and you don't have to take off the spindle nut. At least, I know I never replaced the nut.
But you probably won't be able to turn them. OEMs are making the original rotors to save cost and weight. So, they're pretty much disposable after one use. Unless you still have material on the pads, you might be lucky if you can find a shop to turn them. Good luck. I'm getting ready to do my brakes again at 112k.
__________________
2004 Black Lariat F150 Supercrew 4x4
Roush Suspension Kit, Mark LT bed rails, Truxedo Low Profile tonneau cover, Euro Tail lights, chrome handles, Edge, Volant CAI
Summer Wheels : NS Racing Black/Chrome, 20X8.5, Cooper Tires, 305/50R20s.
Project: 1950 F1
Previous:
89 Probe GT; 86 Bronco II (ex gave it away )
  #8 (permalink)
Old 07-10-2009, 01:43 PM
Maniac01 Maniac01 is offline
Maniac01 is starting off with a positive reputation.
Brake Rotor Swap
Quote:
Originally Posted by kjf-250 View Post
Hi,
Thanks,
Kjf-250
The link below is on changing your F150's Rotors. (front & back) Hope this helps!
http://www.rmftc.com/howtos/brakes/brakes.html
  #9 (permalink)
Old 07-10-2009, 02:17 PM
Fishin76 Fishin76 is offline
Fishin76 is starting off with a positive reputation.
NOPE!, That won't help him, He has a 2wd, that article shows a 4wd, and on a 1997-2003 truck.
__________________
These are not the Droids you are looking for.....
Current vehicles:
98 Contour 2.0L auto, my new DD 49K 30mpg
2009 Dodge Grand Caravan SXT 3.8L 6sp auto
1986 F250XL Diesel RC LB 4x4 T19 4spd 4.10's?
  #10 (permalink)
Old 07-10-2009, 02:24 PM
Hi,
Thanks,
Kjf-250
YES, you can have them turned. But to make it a DIY project, you will need the wheel nuts. Wheel nuts off, slide the whole hub assembly off the spindle. repeat for other side. Take it to local machine shop service and have them turned. put 'm back on and reassemble brakes OR, take the truck to a mieneke or Midas, and see if they have the ON-THE-CAR rotor turning machine. They should. They will just hook this on to the wheel studs and bolt it to the caliper bracket and cut the rotor right on the truck. No new wheel nuts.
Good luck..
__________________
Current vehicles:
Tags
2004 , 2007 , 2wd , assembly , bearing , brake , brakes , caliper , diy , f150 , ford , front , rotor , rotors , turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
