Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 06:20 PM
JRB65 JRB65 is offline
JRB65 is starting off with a positive reputation.
Sprayed in the bed liner
Here are a few pictures of the bed
  #2 (permalink)
Old 07-03-2009, 06:21 PM
  #3 (permalink)
Old 07-03-2009, 06:22 PM
  #4 (permalink)
Old 07-04-2009, 11:46 PM
drof46's Avatar
drof46 drof46 is offline
drof46 is starting off with a positive reputation.
Don't forget to add the drain holes back unless you are in need of a pool.
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 4.11 trac loc
Ground up resto. Ground is done, ran out of money for the up.
  #5 (permalink)
Old 07-05-2009, 02:49 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab is gaining momentum as a positive member of FTE.
What type of bedliner spray you used?
__________________
Customcab 65 F100 SWB w/ 302cid & C6.
64 F100 SWB 223/3spd;
76 F100 LWB 300/C4
78 F100 LWB 302/C6 "Kids 1st Truck"
99 Pontiac GTP "Wife's other Ride"
03 Mountainer "Family Wagon"
  #6 (permalink)
Old 07-06-2009, 05:31 AM
psmith012 psmith012 is offline
psmith012 is starting off with a positive reputation.
Smile spray on bedliner
I don't like the stuff .I used qwikliner on my truck providing lifetime warranty against cheeping,peeling or cracking.
http://www.ford-trucks.com/forums/pi...pictureid=8675
http://www.ford-trucks.com/forums/pi...pictureid=8674
http://www.ford-trucks.com/forums/pi...pictureid=8673
  #7 (permalink)
Old 07-06-2009, 07:50 AM
Customcab's Avatar
Psmith; explain more about "qwikliner". It looks great; and is it a DITY type spray in liner??
Mitch
__________________
76 F100 LWB 300/C4
  #8 (permalink)
Old 07-06-2009, 10:19 AM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is online now
1963 Ford F-100
My Garage
gritsngumbo is starting off with a positive reputation.
Looks good, but appears to be more of a "dealer installed" system, but it is mobile. No prices on the web site. http://www.qwikliner.com/index.htm
__________________
64 Ford F100 Styleside Short Bed /223 "6" & 4 speed "Little Red"
63 Ford F100 Unibody Styleside Longbed w/292 V-8, 3 deuces, dual exhausts & 3 speed "Big Red"
63 Ford F250 Flareside Long Bed w/292 V-8, two barrel, dual exhausts & 4 speed "Big Un"
63 F100 "Stageway" Crew Cab Long (wrong) bed. 292 V-8 & 3 speed
  #9 (permalink)
Old 07-06-2009, 05:04 PM
The Bedliner was called Rapter. Pour the Hardner into the bottle, shake well, screw bottle onto the gun, point and fire. It took longer to mask than it did to shoot. It looks 1000 times better than the beat up bed that it was. Covers multitudes of sins. Me and my two boys had it sprayed in before lunch and we started at 9AM. I get my seat back and the Trim back from the powder coater on Wed of this week and then I can complete putting it together (FINALLY).
JRB65
  #10 (permalink)
Old 07-06-2009, 05:40 PM
1963 Ford F-100
My Garage
I used Herculiner (because they were the only one with a red coating) when I did the bed on Little Red about 4 years ago. It turned out fine, a little rougher than I would have liked. I didn't use the UV coating after I did it so it has faded over the years. I painted over it this weekend with a roller (like the original coating process) using Massey Ferguson Red from Tractor Supply. Looks much better. $20 for two pints. I saw a bed at a car show last year and the guy used either Rubbermaid(?) or maybe it was Duplicolor. Not quite as rough as the Herculiner.
Note to JRB65: How much air (how large a compressor) is needed to power the sprayer with the Rapter system?
__________________
  #11 (permalink)
Old 07-06-2009, 08:38 PM
Hello gritsngumbo,
As far as the instructions went it said to use 50 to 70 PSI at the gun. I ran it at 60 PSI and I have a 60 Gallon 5 hp pump for the compressor. It seemed to do the job just fine. I think as long as your compressor can keep a sustained 60 PSI at the Gun you should be ok. I probably should have asked the question about the UV issue and if there is going to be fade. I just had one put in my 85 Toyota and it cost $400 over the lip of the bed and its. guarenteed not to fade and I can take it back for the life of the truck if it fades or wears or scratches through the liner. I just had my Son get the instruction sheet and it says that it has UV inhibitors in the mix so I would guess or hope it wont fade for a long time. The correct name for the Liner is Raptor and its made by U-POL. Raptor also makes a Tintable Bed Liner and the cost slightly higher but not much. I am going to use the TintableLiner on my sons truck, and when I do I will post pictures of it.
JRB65
  #12 (permalink)
Old 07-08-2009, 04:17 PM
Customcab's Avatar
JRB65
So what's the intial setup cost for gun & enough supplies to paint/ shoot one bed. The web site seems to sell as a dealer prep kit.
mitch
__________________
76 F100 LWB 300/C4
  #13 (permalink)
Old 07-08-2009, 04:24 PM
Quote:
Originally Posted by Customcab View Post
JRB65
mitch
Customcab,
The total cost including the roll of wire tape which I would recomend you get was $180. If you follow the instructions given with the product you cant go wrong. According to the guy I bought mine from if you play with the pressure to the gun and the distance you shoot from the surface you can very the apperence of the finish. I shot mine at 60 PSI and about a foot from the surface and I like the way mine turned out. Mine is kind of grainy but some people like the splatter apperance more. Either way it sure does cover up a multitude of sins and looks good in my opinion.
JRB65
  #14 (permalink)
Old 07-08-2009, 04:45 PM
1963 Ford F-100
My Garage
Thanks for the info. I happened to be by the local Dupont store yesterday and they had the Raptor kit in stock. Think it was about $150 plus they will tint it to match your color for $50 more. I asked them about the air pressure also, and they said absent a large air compressor (I'm still a couple of weeks away from my large a/c) they suggested using a roller. Said it would work just as well.
__________________
  #15 (permalink)
Old 07-09-2009, 07:15 AM
Smile spray on bedliner qwikliner
Mitch
I have Qwikliner on my truck.The cost of bed liner is around $300. Extend the life of your vehicle and increase the NADA / Blue Book re-sale value with a real sprayed-on bedliner.QWIK Liner is a permanently bonded protective barrier between your vehicle and the outside environment, protecting your investment from rust, dents, scratches, and chemical corrosion.The cost of qwikliner varies dealer to dealer.It is 1/8" thickness , UV protected and available in 8 standard colours and 100 more.I have faced no problem at all .Qwikliner bedliner providing lifetime warranty against chipping ,peelingor cracking. >>
Tags
65 , bed , f250 , fade , ford , long , problem , raptor , tintable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
