Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-09-2009, 08:52 AM
JRB65 JRB65 is offline
JRB65 is starting off with a positive reputation.
Quote:
Originally Posted by drof46 View Post
Don't forget to add the drain holes back unless you are in need of a pool.
drof46,
I thought about that and have tried to think of how I could incorporate a couple of drain holes short of drilling a couple of holes. Either way I should have probably done that before I lined the bed. Oh well I guess I will have to sidestep the clutch every once in a while and get the water out the back.
JRB65
  #17 (permalink)
Old 07-09-2009, 09:08 AM
Quote:
Originally Posted by psmith012 View Post
I have Qwikliner on my truck.The cost of bed liner is around $300. Extend the life of your vehicle and increase the NADA / Blue Book re-sale value with a real sprayed-on bedliner.QWIK Liner is a permanently bonded protective barrier between your vehicle and the outside environment, protecting your investment from rust, dents, scratches, and chemical corrosion.The cost of qwikliner varies dealer to dealer.It is 1/8" thickness , UV protected and available in 8 standard colours and 100 more.I have faced no problem at all .Qwikliner bedliner providing lifetime warranty against chipping ,peelingor cracking. >>
psmith012,
I talked with the Raptor Rep and he told me that a lot of companies that install these bedliners will mix silica (Sand) into the bedliner product to thicken and make more of a buildable coating process. The other thing I learned is that with different distances from the surface and pressures you can get different paterns of spray. When I look at the sides of my bed it looks different than the bottom of the bed. That is probably because I didn't keep the distance I was shooting constant but its all a learning process. The other thing I learned is that its important to pull your masking off as soon as possible as it will create fine hairs when you pull it off if its not wet enough. Also make sure you cover the outer surfaces of your truck because there is a fine mist that occurs when your spraying as I found out the next day when I started to buff my truck out. I used 1500 grit sandpaper and it took the small amount of overspray off the paint without much a problem but these are good things to know before you start spraying one of these into your truck. I hope some of the do it yourselfers will learn from my mistakes.
JRB65
Tags
65 , bed , f250 , fade , ford , long , problem , raptor , tintable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
