Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 04:45 PM
nunya001 nunya001 is offline
nunya001 is starting off with a positive reputation.
ABS light on + flashing OD + AC doesn't work
Guys,
Need your expertise - I ran into this problem a couple weeks back and it seemed to be fixed by cleaning and tightening battery terminals. This morning I've got the same problem. Checked , cleaned and double checked my grounds - weird part is AC doesn't blow cold. What do you think?
J-
__________________
2001 CC, LB, 4x4, DP Tuner, CAI, 4inch exhaust, CCV mod, Vegistroke V3
  #2 (permalink)
Old 07-03-2009, 05:37 PM
ok - I went out and pulled each fuse one by one and they were all fine - started the truck and now everything is normal. I'm completely confused.
__________________
  #3 (permalink)
Old 07-03-2009, 06:08 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Having a code would help, but you might try taking out and cleaning the VSS (sensor on top of the rear diff). That might explain the ABS & OD part. I can't see the AC being related.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 07-03-2009, 08:16 PM
clintbonnie clintbonnie is offline
clintbonnie is gaining momentum as a positive member of FTE. clintbonnie is gaining momentum as a positive member of FTE.
Quote:
Just a tip.... you can check your fuses without pulling them.. but you need a ohm meter..( a cheap one will work, Harbor Freight sells a digital ohm mutimeter for about $4).. Just put the 2 probes on the 2 small exposed metal tabs on the top of the fuse... open circuit.. fuse is bad..
__________________
Clint... Early 99, F350, 4X4, Auto, DRW, S-Cab, Gauges, Diablosport 60 HP, OilGuard, Tru-Cool, 5% Biodiesel, Shell Synthetic 5w40, Western Diesel TurboRamAir, MagnaFlow Exhaust, SSHPX, CCV Mod, Fuel Line/Tank Mod., Speed Bleeders, Bilstiens....
  #5 (permalink)
Old 07-04-2009, 02:52 PM
Thanks guys - I pulled the VSS plug from the top of the diff - cleaned it and put it back in. Have a new one coming tomorrow. So far so good, but I think I have a ground problem somewhere else - otherwise why the AC issue? Any thoughts to help me chase this down are appreciated as I am heading cross country Monday morning.
Happy 4th of July and thank you to all who serve and protect our freedom.
J-
__________________
  #6 (permalink)
Old 08-20-2009, 02:22 PM
It's back. Crap. I've searched the forum and tried to re-secure every ground, checked and pulled all my fuses visually, pulled my VSS even though it is newish - now has 7-8K on it. Is there any way to focus on why the AC isn't working in tandem with the ABS light on, flashing OD light and no speedometer reading and no turn signals? Another thing I noticed yesterday is that the truck is downshifting and not just coasting with the TC unlocked? Any help is always appreciated.
__________________
  #7 (permalink)
Old 08-23-2009, 05:00 PM
Sounds like the VSS is acting up.. maybe a bad connection at the plug.. Might consider replacing the VSS again.. try Napa.. P/N 530780..($11). Also, it read a post awhile back where the rearend fluild had metal particles and had to be changed before the VSS would work right.. I can understand the trans not acting right but don't understand the turning signals problems..
__________________
Tags
02 , 2001 , 73l , abs , ac , f350 , flashing , ford , fte , ground , light , powerstroke , sensor , signals , speed , speedo , turn , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
