Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 04:43 PM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
dakotajeep is starting off with a positive reputation.
Radiator Boil or Trash
I just replaced my radiator with one from Auto Zone. It works great!
My question is whether I should have it boiled and keep it for a spare or just get rid of it? It has no leaks it just had reduced flow due to soder bloom or whatever its called. Can they be flow tested at a shop to see if its even worth it not?
Just wondering if its worth the hassle.....
__________________
1994 F350 XL Crewcab 4x4 SRW 7.3 E4OD Banks Turbo & "Custom" Exhaust
Dana 60 Sterling 10.25 3.55 285/75 16 Treadwright Retreads MTG's (love these tires), Pyro Install and Tekonsha Voyager Brake controller!
A little rough but its a truck not a show car!!!
In its former life it worked for the US GOVT
  #2 (permalink)
Old 07-03-2009, 04:54 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
What kind of shape is it in... If you run your fingers over the fins are they flimsy.
If it's solid, they can rod it out.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #3 (permalink)
Old 07-03-2009, 07:08 PM
dakotajeep's Avatar
They have to boil our radiators. They cant rod them out.
I was hoping it may worth it to keep since it is fine other than the internal corrosion....
__________________
  #4 (permalink)
Old 07-03-2009, 07:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
If you have the space, I would have it cooked out and save it for a spare.
But some call me a pack rat.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 07-03-2009, 07:27 PM
Why??
-Enjoy
fh : )_~
__________________
  #6 (permalink)
Old 07-03-2009, 09:49 PM
dakotajeep's Avatar
Dave
Thats what I was thinking. I might just have it cleaned and then one day someone may need one.....maybe me.
__________________
  #7 (permalink)
Old 07-03-2009, 10:41 PM
gatorman21218 gatorman21218 is offline
gatorman21218 is starting off with a positive reputation.
too bad you live in kansas or i could take it off your hands
  #8 (permalink)
Old 07-03-2009, 10:52 PM
tbone91 tbone91 is offline
tbone91 is starting off with a positive reputation.
At least save it until metal prices go sky high again someday
My truck is stored right now. I wish I'd sold the two full tanks during the oil futures speculation boom. When I get around to it, It'll probably be green gook anyway.
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #9 (permalink)
Old 07-03-2009, 11:30 PM
Again, Why???
-Enjoy
fh : )_~
__________________
  #10 (permalink)
Old 07-04-2009, 12:38 AM
dakotajeep's Avatar
Something to do with the design. Supposedly they will be ruined....its second hand info that I was given by several people on here....(most likely they are at the rally!)
__________________
  #11 (permalink)
Old 07-04-2009, 01:06 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
I do not know were the term "rod out" came from. It seems to say they take the tanks off, and poke some sort of "rod" down through the radiator. But over the years I have never seen a radiator shop do this. They sometimes call it "rodding" the radiator, but all they ever do is dip it in a acid bath after taking the tanks off, with a little bit of physical brushing on the ends to get rid of the "solder bloom".
__________________
Dave F
1989 F250 XLT Diesel
  #12 (permalink)
Old 07-04-2009, 01:29 AM
dakotajeep's Avatar
Hmmmm....glad you clarified that for me.....
I am thinking of just giving this on eot someone who wants to fuss with it....
__________________
  #13 (permalink)
Old 07-04-2009, 10:14 AM
galute's Avatar
galute galute is offline
galute is starting off with a positive reputation.
Quote:
Actually you are correct. That is what they do, remove the tanks and run a special made rod thru the flues. I've had it done to a few dump truck radiators over the years. How ever as someone said above. Not all radiators can have this done. Something to do with the design.
__________________
1990 F350 4X4 7.3 IDI N/A E4OD. "Bertha"
1999 F350 4X4 7.3 Stroke 6 speed.
Both of em flatbeds.
  #14 (permalink)
Old 07-17-2009, 04:34 AM
RLDSL RLDSL is offline
RLDSL is starting off with a positive reputation.
The factory radiators have turbulators cast internally into the tubes to make the coolant circulate better ( supposedly) . if they rod the things out like a normal rad, at best it flattens the turbulators, but at worst it rips a bunch of holes in the tubes , most down in the middle of the core where they can't be repaired after, so rodding is a major no-no. Going for a dip in the tank is another story that will usually do the trick, but the shop will have to go over the thing for weak spots after.
__________________
'92 F350 CC Dually, 5speed+3speed Spicer 5831 Brownie, 7.3 Ats Turbo,Hypermax Cowl induction, 4" exhaust, Custom Rodney Red aluminum radiator,MS Tech Fan Clutch, Solid Flywheel w/12 1/4 " Kevlar Clutch, 4.10 ,Western Hauler bed, Air seat,Warn M12000 winch, Bilsteins, Borgeson steering shaft, Aux rear air conditioner.
Tags
boil , radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
