Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 04:29 PM
vmk vmk is offline
vmk is starting off with a positive reputation.
95 F250 shuts off while driving
Hello, I hope to hear some ideas of what to test/try and thank you for answering
95 F250 351 V8 Auto 4x4 123K Miles
The truck will run and then shut off intermittently. Second time this happened while driving. I replaced the fuel pump relay in distribution box under the hood since I thought it might be too warm and the culprit. It didn't solve the issue.
when the truck is in the dead mode, it will crank, but I don't hear the whine of the fuel pump like I do under normal operating conditions. It is a dual tank and this issue effects either tank.
Under dead condition, I still crank and have gauge powering up everything too.
Any advice on ignition module in distributor going, or other thoughts greatly appreciate.
Thank you
  #2 (permalink)
Old 07-03-2009, 06:51 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
I would guess that your PIP sensor in the distributor is bad.
So I would go ahead and read your CM codes and see if you have a code saying that also.
I take it you do here the fuel pumps run for one second when you first turn on the key and they do not run again while the engine is cranking when this happens.
__________________
95 F150 302 4R70W EB EX-CAB
95 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 07-04-2009, 04:06 PM
vmk vmk is offline
Codes 211 & 212
Thanks for the reply. Yesterday I got the PIP sensor code thrown from a guy down the street with a scanner. He showed me the ignition module on the driver's side inner fender wall, attached to the heat sink as the PIP sensor. I got a new ingition module, put it in and broke down on the road again. The scanner now reads 211 and 212, PIP sensor and cylinder indicator?
Is the PIP sensor actually inside the distributo? As I re read your advice you say "in" . Did I replace the wrong part? Is there another module in the distributor itself?
I'd appreciate any leads I can get as I keep reading the haynes manual for some clues.
Thank you very much in advance
  #4 (permalink)
Old 07-04-2009, 04:38 PM
subford's Avatar
Yes the PIP sensor is inside the distributor.
Yes you replaced the wrong part, you replaced the ICM not the PIP sensor.
__________________
subford@gmail.com
  #5 (permalink)
Old 07-04-2009, 05:17 PM
vmk vmk is offline
Thanks. He's a ford diesel guy. My haynes manual doesn't have a clear picture of it. Can I pull it out while keeping the distributor in or do I have to pull the distributor? Is it under that black metal plate in the distributor that I see?
Thank you
  #6 (permalink)
Old 07-04-2009, 06:21 PM
subford's Avatar
Most just replace the distributor.
You have to remove the distributor to replace it.
The distributor then has to be taken apart all the way to the last part to replace it.
The pip sensor is inside the Stator Assy.
This is the part (Stator Assy) that needs to be replaced:
__________________
subford@gmail.com
Tags
2005 , driving , f150 , ford , shuts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
