Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 04:25 PM
shark1979's Avatar
shark1979 shark1979 is offline
shark1979 is gaining momentum as a positive member of FTE.
|Need help!! 1316 code SES light on and off truck runs bad.
driving today SES light came on truck started to miss real bad, light went off truck ran fine. did that a couple more times. got home read code it was 1316. cleared it. went to pick up tractor got about 15 miles from home started again. only did it when i hit some bumps. and now it will not stop and light stays on. could it be my plug under the valve covers? now i am 20 miles from my tools will it make it home?
__________________
Josh PPA#83
No spark plugs here
01 F350 7.3psd 5" lift 35'' nitto,CCV,GTP38R,OBA,AHI delete,riffraff FRx kit, bellowed up pipes, DP tunes-60,80,120.AFe stage II intake, Pete's cover,4'' ss exhaust no muffler, 4 gauges, foil delete, tugger kit,6.0 trans cooler.08 diff cover. Riffraff IC boots.
  #2 (permalink)
Old 07-03-2009, 04:29 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
Quote:
That's exactly what it is.
Especially since you mentioned that it comes and goes, and that a bump triggered it again. Sounds like a loose UVC harness to me.
What did you use to retrieve the code? If you have something that can run a buzz test, you can find out which side is loose. Or you can pop off both valve covers and put updated clips in to keep them from coming loose again.
As for the question of will you make it home??? Well that might be iffy. Depends on how many bumps are on the road. LOL
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #3 (permalink)
Old 07-03-2009, 04:33 PM
shark1979's Avatar
how hard is it to upgrade clips can i get them from ford dealership. how hard is it to get the pass side valve cover off? can you reuse the gasket? i will take them bothoff and retighten everything. THANK you for the quick answer. i used an edge cant do a buzz test. i am looking at the termnator gauge/ code reader.
__________________
Josh PPA#83
No spark plugs here
  #4 (permalink)
Old 07-03-2009, 06:15 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Taking the valve covers off isn't too bad. I actually think the passenger side is easier. Valve cover gaskets are re-usable. You should be able to pick up some shims for the harness at Ford or International for not too much money. In a pinch you can even make your own shim to keep it from coming unhooked again.
I ground the edge off a quarter and used it as a shim when I did mine.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #5 (permalink)
Old 07-03-2009, 09:55 PM
shark1979's Avatar
i cant thank you guys enough. i put two new harnesses under both valve covers. the drivers side was half unpluged. while i was under there i retighten all the stuff you all said to tighten. along with the quater trick. so hopefuly i wont have to do this again. i would give you guys reps if i could figure out how.
__________________
Josh PPA#83
No spark plugs here
  #6 (permalink)
Old 07-03-2009, 10:07 PM
F350-6's Avatar
Slow Typing
Runs a lot better now doesn't it? It's scary how much a dealer would charge to do the same thing.
Hope you had something good to stand on. With your lift, you'd need to be about 8' tall to not use a stool.
__________________
Chris
  #7 (permalink)
Old 07-04-2009, 12:48 AM
shark1979's Avatar
yea i did use a 6' ladder haha. i dont want to think about how much a dealer would charge to do the same thing. Could not have done it with out the help of you guys.
__________________
Josh PPA#83
No spark plugs here
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
