I'm in need of some advice on how to replace the belt. I don't know which pulley to loosen to provide slack for removal and replacement. It's on an '03 6.0 diesel.
It's one of the pulleys on the belt path that isn't connected to an accessory but has an arm attached to it that it pivots on. Dunno which engine you have, but Ford has made it easy on their gas engines the past 10 yrs or so (and this fixes over/under tensioning nicely too). The tensioner has a recess for a 3/8" or 1/2" socket wrench, so you just snap that in and pull one way to release tension and pull the belt off. Pull again to get it back in place. Extra hands can help, and a long handled wrench/breaker bar also helps pull against the strong spring.
It should be obvious which pulley is the right one when you look at it.
-Dave
__________________
- Dave
2005 F250 Lariat SuperCab Long Box 5.4 Auto 4x4
1999 Explorer AWD 5.0 4-door
Owner manual should have a service schedule showing belt replacement. The service interval is conservative to ensure that most people do not have a failed or slipping belt. But that's the whole point right? Preventative maintenance.
brianlambert, when you try to loosen the tensioner pulley be prepared to put some muscle into it. Otherwise it won't move.
Somewhere in the 70-100k range is good, generally. I did our Exploder V8 at 100k after the belt had been making some noise. Never had a problem with it, but the noise stopped with a new one.
And yes, it is a strong spring, so a breaker bar is well advised rather than a short ratchet....or a length of pipe over the wrench. A helper is also advised as it can be hard to pull against the spring and still get the belt in place. It's fast with help.
__________________
- Dave
Well yeah - Like many things, getting it off isn't too bad - but getting it back on was the 4-handed operation. At least on the Exploder 5.0 it was. Haven't done the 5.4 yet, but I suspect it is similar.
__________________
- Dave
