Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 02:31 PM
drof46's Avatar
drof46 drof46 is offline
drof46 is starting off with a positive reputation.
Wiring diagram 1966 needed?
Can someone with a 1966 2wd diagram scan the dash light switch diagram and ignition switch for me and e-mail or PM it to me?
haus_von_stein@yahoo.com
Thanks
Ben
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 4.11 trac loc
Ground up resto. Ground is done, ran out of money for the up.
  #2 (permalink)
Old 07-03-2009, 04:24 PM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
If don't get a response have a 65 diag. can route to yu. The circuits should be same the difference may be with the wire color code. Source is the 65 Ford Truck Wiring Diag. Manual.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #3 (permalink)
Old 07-03-2009, 08:53 PM
drof46's Avatar
Please route to me when you get a chance. Wired up the engine sensors and routed the wires for the front lights and turns today. Plan to route the rear lights and fuel guage wire, then I'll be in real need of the diagram for in the cab wiring.
Thanks Dave!
If someone has the 66 manuel and cannot scan, if you can just tell me the different colors and what they are, I could go from there.
__________________
  #4 (permalink)
Old 07-03-2009, 09:35 PM
Erich.Vongeist's Avatar
Erich.Vongeist Erich.Vongeist is offline
1966 Ford F-600
Erich.Vongeist is starting off with a positive reputation.
Hey could you route that wiring diagram to me too? I need help with my dash lights.
Thanks,
Erich
  #5 (permalink)
Old 07-04-2009, 12:15 AM
Quote:
Thanks Dave!
Ben, Erich, email sent!.
__________________
dave
  #6 (permalink)
Old 07-04-2009, 12:07 PM
1966 Ford F-600
Hey Thanks,
That really helps!
Erich
  #7 (permalink)
Old 07-04-2009, 11:37 PM
drof46's Avatar
Thanks for the help today. Had a couple of e-mails that really helped. I believe I finished up my ignition switch tonight. Have the wires set aside and ready to hook up to the headlight switch in the morning. Now the steering column will be the next big battle. I have a 73-77 column with the e-flasher on the column. Folks in the 73-79 forum have not been as forthcoming with a diagram. I've done trial and error before and may have to do it again.
FYI, I'm putting in an EZ-Wiring harness. Most everything is straight forward, just slightly overwhelming with all the wires. Hooking it into the existing components is the fun part. As usual if you have a GM vehicle it plugs right in.
Thanks again!
__________________
  #8 (permalink)
Old 07-06-2009, 11:40 AM
Dauber Dauber is offline
Dauber is starting off with a positive reputation.
Could you please send a wiring diagram to me as well. ddubinsk@gmail.com
Thanks!
  #9 (permalink)
Old 07-06-2009, 12:18 PM
Blackwaterforge's Avatar
Blackwaterforge Blackwaterforge is offline
Blackwaterforge is starting off with a positive reputation.
Could I get a copy as well?
Thank You!
__________________
http://www.Blackwaterforge.com
All tools are hammers except screwdrivers and they are chisels.
  #10 (permalink)
Old 07-06-2009, 01:02 PM
drof46's Avatar
Looks like I started something. Thanks for all the help guys. Had some trouble getting my motor started yesterday. This AM was not any better, but whatever it was has resolved itself. New battery and high torque starter got her fired up today.
This is the best website for ford nuts like myself. Pictures to come later today on my frame swap thread. Need to tie up a few loose ends and see if I can't get my maiden voyage under way.
Thanks again!!!!
__________________
  #11 (permalink)
Old 07-06-2009, 01:29 PM
The manual consist about 10 diagrams of the various circuits, perhaps if there's a particular circuit you are intested in please email me. Ordinarily would not be a problem but seems my yaa hoo email will not accept my attachments, may have something to do with not being computer literate, seems I can post the diag. thru photobucket. May I suggest that if it appears there may be some electrical gremlins in your future you may want to consider purchasing the manual, bought mine directly from the source, Osborn Reproductions, best $7 I have spent. Extremely helpful when I rewired the 65. Understand the original wiring manuals are more correct but they are hard to come by, and costly. Figure if majority of the Ford truck parts suppliers offer the Osborn Reproduction is must be a suitable replacement.
__________________
dave
  #12 (permalink)
Old 07-06-2009, 03:10 PM
dman2008's Avatar
dman2008 dman2008 is offline
dman2008 is starting off with a positive reputation.
Hey Drof46 so you went with the EZ wire, overall pretty good harness I am really happy with mine. Glad to hear you got your truck running, if you get to take her for a spin if you can get a video for us.
D
Tags
1966 , ab , cab , column , complete , custom , diagram , diagrams , diffrence , f100 , f600 , flashers , ford , harness , regular , steering , whats , wire , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
