Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 12:25 PM
nlfireblade's Avatar
nlfireblade nlfireblade is offline
nlfireblade is starting off with a positive reputation.
Wheel alignment/leveling kit/heavy steering
I had a 2007 F-150 SC and I put a leveling kit in it(2.5" front and 1.5" rear). After the install I had a wheel alignment and everything was great. I didn't notice a difference in the steering.
I now have a 2004 FX4 SC and I just put the exact same kit in it and had a wheel alignment and the steering is no better than before the alignment(after the leveling kit install) I think. It is definately not the same as it used to be. It's heavy feeling, almost like I only have half of my power steering. When turning a sharp corner I can let go of the wheel and it will stay in place. The wheels will not straighten out on their own as long as I am accelerating.
Is this normal? Why the difference in the two trucks? Should I have the alignment checked? I don't want to bring it back to the same place and I don't want to pay to have it done again!
Thanks
  #2 (permalink)
Old 07-03-2009, 06:37 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
sounds like something is hanging
any car with power steering or not will have the wheels straighten out with momentum applied.
since you are saying it holds the turn even when let go, I'm thinking something is getting bound up in there...or maybe even your Rack/Pinion is messed up
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #3 (permalink)
Old 07-04-2009, 07:27 AM
svt2205 svt2205 is offline
svt2205 is starting off with a positive reputation.
Sounds like you may have a binding issue with a ball joint. I've had trucks, without leveling kits, that ball joints caused the steering not to recenter (turn back). This binding issue may have been there before the leveling kit, which may be a factor on the heavy steering. For reference, adjustments to toe can significantly change the feel to steering. Find yourself a good front end person, one who knows what happens when you adjust caster, camber or toe. Too often today, the tech doing the alignment is only looking for each setting to fall within the green. While this will be "in spec" it might not be an optimal set of settings.
__________________
07 F150 Lariat Supercab, 6.5' 4x4, 5.4, 3.73LS, 7.5' Fisher SD Plow
  #4 (permalink)
Old 07-04-2009, 07:25 PM
Before the leveling kit install the steering was perfect. It's my third ford truck and my first used truck so I'm comparing it to new trucks with perfect steering as well. I'm wondering if there is an adjustment that may have been overlooked. After the leveling kit install and before the alignment the truck still drove straight and didn't pull to one side or the other so everything was still 'aligned' that way. The spacers affect camber? toe? Is there an adjustment that may be overlooked by a tech not familiar with lift spacers?
  #5 (permalink)
Old 07-05-2009, 10:52 PM
stronger stronger is offline
stronger is starting off with a positive reputation.
have a helper drive your truck forward, look to see if your front axles are turning. I had a 4x4 issue a few weeks ago that would not let the front end disengage from the wheels at the hubs like it should. I was not in 4wheel drive, the front shafts were just coasting along with the wheels and like this it steered a bit stiff while they were locked.
  #6 (permalink)
Old 07-06-2009, 02:25 AM
I can check it out but it would seem odd that everything is fine when I drop it off and then an issue when I pick it up. I have another appointment made to have everything rechecked.
  #7 (permalink)
Old 07-21-2009, 03:13 AM
I brought the truck back to the place that did the alignment and they checked it over. The mech said that the steering knuckles(u-joints?) had to be lubricated. I found this odd and I didn't really believe it when I left. My steering was perfect again. He said it would only last so long... and he was right. After a few days the steering began to get stiff again. I lubricated the joints myself and it was fine again. These parts are going to have to be replaced.
Is this a big job? I can see the problem areas(the joints) but I'm not sure how it's all put together or what to ask for at the dealer? Is this a part that could be bought used? Is it a common problem?
Thanks
Tags
2007 , alignment , f150 , rear , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
