Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 11:44 AM
adam83 adam83 is offline
adam83 is starting off with a positive reputation.
f100 f150 or f250
Hi, I am looking to buy my first 4x4 ford. I am interested in the 73 to 79 f series models. my question is, what is a better platform for a 4wheel drive truck? an f100, 150, 250 or 350? The differences that I know about are that the axles are different and so are other suspension parts like the springs. A lot of people have f100's or f150's, but from all the posts I read it is usually recommended that they use bigger axles like the dana 60. why not start off with the truck that already comes with the bigger axles?
  #2 (permalink)
Old 07-03-2009, 12:23 PM
Sayer Lane's Avatar
Sayer Lane Sayer Lane is offline
Sayer Lane is starting off with a positive reputation.
what kind of stuff are you planning on doing with the truck? bogging, hauling, pulling, what? that would help us out a lot
  #3 (permalink)
Old 07-03-2009, 12:36 PM
bicyclemonkey's Avatar
bicyclemonkey bicyclemonkey is offline
bicyclemonkey is starting off with a positive reputation.
If you knew you were going to be hauling some heavy loads you may want to go with at least the F-250. Other than than the load/hauling/towing factor, it's whatever you find out there that you like for the price you want to spend.
  #4 (permalink)
Old 07-03-2009, 01:20 PM
The truck will be used for work, hauling a large trailor, daily driving, and fun. The work wont be more than moving logs or furniture and yard waste, but I will be towing a large trailor full of garbage. I want the truck to be bullit proof, and I will be putting money in it from paycheck to paycheck. From everything I've read and researched, Im pretty sure I want 1 ton axles front and back, but that is really all I know. I want to be able to climb hills and go in the mud.
  #5 (permalink)
Old 07-03-2009, 01:30 PM
Sayer Lane's Avatar
well since you are doing all the hauling and pulling and you want it to go through mud. then i would get a 250 high boy or 350 (which will probably be hard to find) high boy is your best best
  #6 (permalink)
Old 07-03-2009, 01:38 PM
Ok. Eventually though I want to put a high suspension lift on it and upgrade the running gear, so should I go with a highboy or regular?
  #7 (permalink)
Old 07-03-2009, 01:41 PM
Sayer Lane's Avatar
well with high boy you will already have quite a bit of lift on it stock. but if you don't like the idea of leaf springs all around then go with regular f250. but i think you will be much more satisfied with the high boy
  #8 (permalink)
Old 07-03-2009, 01:46 PM
This is a very different topic, but Im curious now, whats the pros/cons of leaf springs all around?
  #9 (permalink)
Old 07-03-2009, 01:50 PM
Sayer Lane's Avatar
well if you know trucks then you know a 4wd and 2wd drive alot different. the 4wd is a lot stiffer and heavier suspension. but the high boy 4wd suspension is heavier duty than most and will be a rougher ride but it wont sag much with that heavy trailer
  #10 (permalink)
Old 07-03-2009, 01:54 PM
garlindethfury's Avatar
garlindethfury garlindethfury is offline
1973 Ford F-250
garlindethfury is starting off with a positive reputation.
Sounds like you need to go with the Highboy... They have a towing a hauling capability that is up there with the newer trucks... I have a fifthwheel plate in mine so I can pull trailers for friends of mine... and hauling I hauled a 4600 lb gun safe...
But this is just my opinion...
__________________
'73 High Boy 390, 4 speed
Mods: Mild Cam, Hevy duty vavle springs, Edelbrock Performer 390 Intake, Edelbrock Performer 600 cfm carb, 3" strait pipes w/glass packs, and custom bull bar.
  #11 (permalink)
Old 07-03-2009, 02:01 PM
I meant a regular 4x4 or highboy.. but I believe I understand what you are saying. So the an f250 4x4 highboy has even more rugged suspension then an regular f250 4x4?
  #12 (permalink)
Old 07-03-2009, 02:05 PM
1973 Ford F-250
They are a lot more rugged...
__________________
  #13 (permalink)
Old 07-03-2009, 02:10 PM
What is the largest engine that came in a 4x4 in the 73 to 79 fords? Was it the 390? what engine should I be looking for?
  #14 (permalink)
Old 07-03-2009, 02:17 PM
1973 Ford F-250
there are a lot of engines that came in that truck... I personally recomend the 390 It is my fav... but it is not the most fuel efficent motor in the world... the 400 is a nice solid motor and gets slightly better fuel mileage than the 390... or you can go with the big boy of the 460... but that is a little overkill in my mind...
__________________
  #15 (permalink)
Old 07-03-2009, 02:24 PM
Wink
I didnt know the 460 came stock in the 4x4. Personally, I want a 79, and I dont think it came with a 390
Tags
1973 , 1979 , 390 , 400 , 4x4 , casting , differences , f150 , f250 , fit , ford , frames , gvw , increasing , midland , modified , reliability
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
