Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 07-05-2009, 11:04 AM
adam83 adam83 is offline
adam83 is starting off with a positive reputation.
[quote=NumberDummy;7681999]On 1973/79 F250's for example, there were FOUR different GVW's: 6100, 6900, 7500 and 8100 lbs.[quote]
Are these gvw numbers located on the door?
  #47 (permalink)
Old 07-05-2009, 11:11 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by adam83 View Post
The GVW is located on the Warranty Plate, which will be found on the left door face below the latch.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
2008 Fusion S // 2008 Edge SEL
  #48 (permalink)
Old 07-05-2009, 11:44 AM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
that is just some of the available gvws? or are those the base gvw and there were options to increase it?
one of my 77s has a gvw of 7700lbs the other 77 has a gvw of 8200lbs and my 78 has a gvw of 8400lbs. none of those numbers were litsed preiviously so i'm just curious how they got to those numbers.
__________________
Untill next time, I leave you with these words of wisdom...
NOTE TO ALL PREVIOUS OWNERS: STOP IT!!!
  #49 (permalink)
Old 07-05-2009, 12:08 PM
Ford Parts Guru
Those four GVW's (6100, 6900, 7500, 8100 lbs.) are what is listed in the 1973/79 Ford Light Truck Parts Catalog for F250's.
There could be more...these are the ones I'm most familiar with, as they are needed to get the correct "Brake Differential Proportioning Valve" for 1975/79 F250's.
You'll need this parts catalog to find all the various GVW's, as I do not know where else they can be found.
To find out what the correct GVW is, either look on the Warranty Plate, or post the MODEL code off the Warranty Plate. I can decode the MODEL code.
In fact, I can type all the GVW's for all the 1973/79's...but...I'd rather not, as there are myriad different ones.
The first three digits of the VIN itself doesn't tell much of anything when decoded.
__________________
  #50 (permalink)
Old 07-05-2009, 07:25 PM
montana_highboy's Avatar
montana_highboy montana_highboy is offline
montana_highboy is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Jermafenser View Post
Weaker frame? What on Earth made you say that?
The 73-77.5 F250 4x4's i.e. "highboys" have a ladder type frame and an additional crossmember under the front bumper which inherently makes them stronger by the very nature of their design when compared to the 77.5-79 F250 4x4's i.e "lowboy's" frame, it's just my opinion and others may disagree but i'm standing by it.
__________________
75 Highboy 390 4spd
  #51 (permalink)
Old 07-06-2009, 12:00 AM
Old Brown Truck's Avatar
Old Brown Truck Old Brown Truck is offline
Old Brown Truck is starting off with a positive reputation.
300,351M,400 are the stock engines from 77-79. Swapping in a 429/460 is a fairly well documented engine swap with aftermarket support. 351M/400 are identical blocks.
300 and 360 were pre-77 4x4 engines. 360 has identical block to a 390. Swapping in a 352,390,410,427,428 in place of a 360 is simple.
Stock differential gearing in F100(150) should be roughly 3:50 F250 would be 4:11. If you drive at Freeway speed, that makes for some high rpms.
__________________
76 F100 currently: 390 T18 2wd
79 F150 4x4 351M NP435 NP205
95 VW Passat VR6
97 Mustang GT 4.6L 5sp
  #52 (permalink)
Old 07-06-2009, 03:19 PM
im totally inexperienced with trucks. What does dentside mean?
  #53 (permalink)
Old 07-06-2009, 03:41 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Nickname for the 1973-79 trucks due to the character depression on the body.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #54 (permalink)
Old 07-06-2009, 03:59 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Ok, I have cleaned this thread up. Lets keep it technical and leave the petty bickering on the curb!!
Oh and the 351M is a modified version of the 400 that was introduced in 1970, I believe, in the LTD. The 351M came along in 75 as mentioned above.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #55 (permalink)
Old 07-06-2009, 04:42 PM
Is there much difference in performance and reliability between the 351M and the 400?
  #56 (permalink)
Old 07-06-2009, 04:51 PM
Ford Parts Guru
Quote:
That's all very well and good. However, do you honestly believe that a certain 14 year old smarmy kid can keep his opinions to himself?
The 400 introduced in 1971 in Galaxie/LTD's, Mercury Marquis, Torino's and Mercury Montego's.
The 390 was continued in Galaxie/LTD's only thru 1971.
__________________
  #57 (permalink)
Old 07-06-2009, 06:48 PM
monsterbaby's Avatar
monsterbaby monsterbaby is online now
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
What a load of CACA del TORO!
That so called mechanic doesn't know his *** from a hole in the ground!
There is NO SUCH THING as Midland inre to the 351M...PERIOD!
Where exactly in Midland TX is there any Ford assembly plant? There is exactly N-O-N-E = NONE!
The M stands for MODIFIED, and has since the engine debuted in the following 1975 passenger cars: LTD, Torino, Mercury Marquis, Cougar.
Since you have made this claim as an absolute would you please produce the Ford documentation PROVING it. because it's NOT true.
There is NOT a midland TX ford plant but there IS a midland MI, which did have the casting plant that DID cast the origninal 351m/400 blocks and if you follow most of fords engine designations for 351s basing it on the cities associated with the engine (iwndsor and cleveland to be exact) Midland actually makes a LOT more sense then modified. So without proof it's just an M, but I have known Ford engineers just like you have and they claim midland, others claim modified. The "experts" would say anyone making the claim of it standing for "modified" is a so called self proclaimed expert with no knowledge or proof.
This is one of those arguments that can not be won because there is no verifiable proof so anyone making a definitive claim of knowledge is wrong, no matter who or what their claim is.
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #58 (permalink)
Old 07-06-2009, 09:29 PM
That reminds me...the refs.
Parts catalogs state 351M as modified.
You do know at one time, the Windsor engine was NOT produced at the Windsor plant? And only the 351s had the plant designation. The rest didn't.
How does Midland makes more sense? Ford just took the 400, modified it into a 351 CID engine, and called it 351 modified.
__________________
Chad
  #59 (permalink)
Old 07-06-2009, 09:49 PM
so, is there much difference in performance between the 2 engines? is one 'better' than the other?
  #60 (permalink)
Old 07-06-2009, 09:58 PM
Holiver31's Avatar
Holiver31 Holiver31 is offline
Holiver31 is gaining momentum as a positive member of FTE.
Well the 400 of course has more CI so theoretically should have more hp. I think the 400 has higher compression as well. The compression is still pretty flippin low though.
__________________
It's an internet forum, get used to it. It's like having a drunk conversation with every single person in the bar minus the "I love you man". "I've seen far more abnormal and unexplainable things at Wal-Mart than I have out in the deep woods." "My drinking crew has a racing problem, or vice versa..."
Tags
1973 , 1979 , 390 , 400 , 4x4 , casting , differences , f150 , f250 , fit , ford , frames , gvw , increasing , midland , modified , reliability
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
