Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-04-2009, 12:23 AM
adam83 adam83 is online now
adam83 is starting off with a positive reputation.
that cleared some things up for me thanks. Where is the gvw located? is it a sticker on the body or a tag on the door or is it indicated by numbers or letters in the vin?
  #32 (permalink)
Old 07-04-2009, 12:26 AM
oh, and I live in Tacoma WA.
  #33 (permalink)
Old 07-04-2009, 03:26 AM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
Quote:
The GVW (which stands for Gross Vechile Weight.) Is located on the little Warrenty Plate on the driver side door,along with the VIN and other info.(paint codes,etc...)
And you can also tell the GVW by looking at the VIN (which has the truck series in the first 3 letters.
Examples:
F35= F-350 (1 ton)
F25= F-250 (3/4 ton.)
F15= F-150 (first year for F-150 was 1975,due to smog emsions) (heavier half ton)
F10= F-100 (half ton)
If you see X instead of F that truck is a Super-Cab.
Like X25= F-250 Super-Cab.(first year for Super-Cab is '74,a Super-Cab is what Ford Calls their extened cab trucks.)
I'M not home right now,Other-wise I would link you to pictures for reference,if ya want when I get home I will get you the GVW of each seires.
Also,GVW is the combined weight you can haul and or tow (meaning like my trucks GVW is 10K so I can't hual or tow anything that makes the truck and what I'M haulin' more than 10K,Basiclly combined vechile wieght of the truck,and anything your hauling,towing,etc....
Hope you understand what I'M saying.
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #34 (permalink)
Old 07-04-2009, 04:45 AM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
Examples:
F35= F-350 (1 ton)
It would also help if you posted 4x4 GVW codes instead of 4x2 codes like you did above.
  #35 (permalink)
Old 07-04-2009, 06:23 AM
Grantman Grantman is offline
Grantman is starting off with a positive reputation.
Yeah and you would have different options available on different years.
it also depends on what trim package you have...(Interior options,I mean) (And outside trim)
The trim packages where:
Custom
Explorer
Ranger
Ranger-XLT (Top of the line from '70-'77)
Then in '78 The Lariat Ranger Came out...
But enough on trim lines,so tell us what your dream truck would have on it,and where your at,and I can help ya look online.
That's correct,except I believe the 351M (M stands for Modified,which I have been told was for smog equipment) Someone told me the 351M/400s where the same block.
I was told that same thing and believed it for years until a retirement dinner for the best Ford Mechanic I ever met. Since he worked as a Ford mechanic for over 40 years I tend to believe almost everything he told me. According to him the M is for Midland Texas where it was made. The 351M is the truck version of a 351, as such it is taller and will NOT fit in most cars (I wanted to put one I got cheap in a Mustang). The 351W was made in Windsor Ontario Canada, and the 351C was made in Cleveland Ohio, Both were made for cars and will not last as long in a truck. I believe him because I got 350K out of a 351M in a bronco, but the 351C I replaced it with only lasted about 60K. I don't know if the 351 and the 400 are exactly the same block but MOST parts will interchange.
  #36 (permalink)
Old 07-04-2009, 06:35 AM
montana_highboy's Avatar
montana_highboy montana_highboy is offline
montana_highboy is gaining momentum as a positive member of FTE.
If you want an "off the shelf" rugged 4x4 just get a 73-77.5 f250 4x4 i.e. highboy, it already sits up high (can run 35's with no problem) has a virtually bullet proof drivetrain and can take almost any abuse you through its way.
__________________
75 Highboy 390 4spd
  #37 (permalink)
Old 07-04-2009, 10:05 AM
bicyclemonkey's Avatar
bicyclemonkey bicyclemonkey is offline
bicyclemonkey is starting off with a positive reputation.
Quote:
Case closed!
  #38 (permalink)
Old 07-04-2009, 01:23 PM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
Quote:
first off, 351m's most certainly DO FIT IN CARS. ltds got them. amoungst others. second the M stands for MODIFIED, as in it is a DE-stroked 400, EVERY THING is the same as the 400 EXCEPT the Pistons And Crankshaft.
__________________
Untill next time, I leave you with these words of wisdom...
NOTE TO ALL PREVIOUS OWNERS: STOP IT!!!
  #39 (permalink)
Old 07-04-2009, 07:18 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
The same could be said for the later 4x4s minus the ground clearance advantage. Drivetrain options barely changed throughout the series. So a 'bulletproof' drivetrain could be said for any 1973/79 truck, 4x4 or 2WD. Pretty much a moot point, really.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #40 (permalink)
Old 07-04-2009, 09:43 PM
Quote:
I just don't like the reverse arched springs on the 77.5 - 79's and they sit to low for my taste, and the the 77.5 - 79's have a weaker frame so my point is not "moot".
__________________
75 Highboy 390 4spd
  #41 (permalink)
Old 07-04-2009, 10:01 PM
Weaker frame? What on Earth made you say that?
__________________
Chad
  #42 (permalink)
Old 07-05-2009, 12:22 AM
classictrucknut's Avatar
classictrucknut classictrucknut is offline
1979 Ford F-250
classictrucknut is starting off with a positive reputation.
compared to the crap on the road today any dentside can be considered bullet proof i hav been hit by a 2008 toyota camry, a 2007 chevy cobalt and an 80's civic and the civic did the most damage. it took 2 whacks with a hammer to get that dent out. the camry and the chevy pos both shattered their front ends apparently there is a something about my truck that makes people run red lights as that was how all three happened. none was over 15 mph and to give credit the civic and the camry were in the winter but the chevy guy was just an idiot. anyway my truck stiil drove away fine i wish i could say i have 4 wheel but sadly that dream has yet to come true
__________________
"Brutus" 79 f250 ranger
It ain't always pretty, But it's real"
  #43 (permalink)
Old 07-05-2009, 12:44 AM
That's hilarious! I've also learned from experience that you should always drive with your hitch installed in the receiver in the case of getting rear ended. lol
  #44 (permalink)
Old 07-05-2009, 12:50 AM
1979 Ford F-250
i have a really big hitch too so i feel sorry for the dipstick that rear ends me will upload pic to album in just a sec
__________________
  #45 (permalink)
Old 07-05-2009, 10:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
I was told that same thing and believed it for years until a retirement dinner for the best Ford Mechanic I ever met. Since he worked as a Ford mechanic for over 40 years I tend to believe almost everything he told me. According to him the M is for Midland Texas where it was made. That's a load of crap! The 351M is the truck version of a 351, as such it is taller and will NOT fit in most cars (I wanted to put one I got cheap in a Mustang). The 351W was made in Windsor Ontario Canada, and the 351C was made in Cleveland Ohio, Both were made for cars and will not last as long in a truck. I believe him because I got 350K out of a 351M in a bronco, but the 351C I replaced it with only lasted about 60K. I don't know if the 351 and the 400 are exactly the same block but MOST parts will interchange.
What a load of CACA del TORO!
That so called mechanic doesn't know his *** from a hole in the ground!
There is NO SUCH THING as Midland inre to the 351M...PERIOD!
Where exactly in Midland TX is there any Ford assembly plant? There is exactly N-O-N-E = NONE!
The M stands for MODIFIED, and has since the engine debuted in the following 1975 passenger cars: LTD, Torino, Mercury Marquis, Cougar.
The 351W was used in 1975 and later Econolines, 1981 and later F150/350's and Bronco's.
The 351M used in 1975/78 was very prone to cracking cylinder heads.
Many were replaced under warranty. I'm very surprised that a mechanic that supposedly worked for Ford for 40 years wouldn't know that.
If this is the best Ford mechanic you ever met...I'd hate to see the worst one!
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
Tags
1973 , 1979 , 390 , 400 , 4x4 , casting , differences , f150 , f250 , fit , ford , frames , gvw , increasing , midland , modified , reliability
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
