Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 11:05 AM
paddler paddler is offline
paddler is starting off with a positive reputation.
Snow Performance Boost Cooler, rear disc questions
Does anyone have any experience with the Snow Performance Boost Cooler water / methanol injection system? I'm considering this system:
http://www.snowperformance.net/product.php?pk=65
to keep EGTs down. I've got plenty of power for me from my Banks system, but I'm real close to the listed EGT limits on slow curvy climbs at moderate throttle and no to low boost. Downshifting usually help EGTs a bit, even though I've got plenty of torque and adequate RPMs in a higher gear. EGTs are much better on main highways, likely because I can keep speed, boost, and thus airflow up.
On rear disc conversion, it looks like most of the folks who rave about their brakes are using non-e-brake front calipers, which should provide more stopping power than rear e-brake calipers. I'm interested in folks experience with braking improvements using rear e-brake calipers.
Thanks for any insight.
__________________
97 F-350 PSD E4OD 4x4, Crew Cab, 8'... Banks Power Pack, 6637 air filter, ARB air lockers front & rear, PIAA 959 fog & 1100 driving lights, 12" VisionX X-Mitter LED bar
  #2 (permalink)
Old 07-03-2009, 11:55 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
I didn't know the non-e-brake calipers provided more stopping power? I have the e-brake calipers and like them a lot. With my heavy loads on a hill I need the e-brakes but I also would like more stopping power. Considered snow but never went through with it.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #3 (permalink)
Old 07-04-2009, 10:28 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Fisher of Men
tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE.
Those two calipers should provide the same stopping power as dimensionally they are the same. Just the rear calipers have parking brakes design as well.
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
I will keep My Money, My Guns, My home and My Family. YOU KEEP YOUR CHANGE!!
  #4 (permalink)
Old 07-04-2009, 05:34 PM
Clarification: braking improvement using rear vs front calipers
Most of the testimonials for rear disc conversion seem to be about great stopping power using front calipers (from a Chevy 1/2 ton?) From what I've seen, the front calipers have larger total piston area than either variety of rear calipers, and larger piston area should translate to more braking force.
For braking improvement, I think the question is does using rear calipers with a disc conversion provide a notable stopping power improvement over stock drums. Since I need a parking brake and don't want to mess with driveshaft brakes or auxiliary calipers, my options are rear calipers with parking brake or staying stock.
After some more thinking, I'm leaning towards not doing anything until my rear drums need servicing, then doing a disc conversion.
__________________
  #5 (permalink)
Old 07-08-2009, 11:14 AM
bud48fla bud48fla is offline
bud48fla is starting off with a positive reputation.
http://www.fordmann.com/F350.rear_disc_brakes.htm Work's very good Larry
  #6 (permalink)
Old 07-08-2009, 01:00 PM
rideracelivemx7 rideracelivemx7 is offline
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
theres guys over at PSN that swear by the water meth kit, 30% meth and 70 water seems to be key over there, they have reported amazing results with the kit and its very easy to install, i will eventually be doing that kit later on down the road.
http://powerstrokenation.com/forums/...ow+performance
this is pretty good evidence that it works
  #7 (permalink)
Old 07-08-2009, 02:43 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
When doing the rear disc brake conversion do the disc brake cylinders have a larger fluid capacity than that of the shoe style cylinders?
In other words does the stock OBS master cylinder have enough capacity to adequately supply all of the wheel cylinders with pressure/fluid?
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #8 (permalink)
Old 07-08-2009, 04:58 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
I run the Snow Performance Boost Cooler and love it. I was pretty skeptical at first but the huge drop in EGT's won me over. I would suggest just running 100% water if you are just looking for EGT numbers. There is mixed feelings on the meth usage. IMO, small percentages are ok, but I would rather go with what Jody at DP told me. He advises just running straight water so that the meth doesn't affect the timing.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #9 (permalink)
Old 07-08-2009, 05:38 PM
Yes, the master cylinder in our trucks does work fine. If you wanted to go bigger, our year of Super Duty does have bigger pistons. I also have a 88' F350 DRW with rear disc on it also and put the Super Duty master cylinder on it, with a hydroboost. My 97' F350 SRW with rear disc, with vacuum booster and stock master cylinder works just as well.
  #10 (permalink)
Old 07-08-2009, 11:48 PM
I've considered snow's performance for a few years now but I can never get a honest answer of how much water you have to carry. Would a 55 gallon drum be enough?
__________________
Glenn
  #11 (permalink)
Old 07-09-2009, 12:03 AM
1995 Ford F-250
holy crap lol, the kit only comes with a small 3 gallon or so, 55 gallon drum, your in the game to drop egts, not look like a hick haha
  #12 (permalink)
Old 07-09-2009, 12:48 AM
Platinum Sponsor
Quote:
Unless your running a 80,000 over the road truck you won't need that much. I run the Snow MPG MAXX Stage 3 and it comes with a 7 gallon. Even running it constantly it doesn't run out in between fill ups when towing. Great thing about water is its free
__________________
Clay
  #13 (permalink)
Old 07-09-2009, 09:41 AM
Clay, I'll have to go back to snow's website but what is the mpg maxx and how does it compare to just the stage 3? The way we waste water, hopefully it will stay free!
__________________
Glenn
  #14 (permalink)
Old 07-09-2009, 09:53 AM
Platinum Sponsor
Basically the MPG MAX comes with a 7 gallon reservior and the controller is programmed for 2 modes, MPG for when you empty and TOW when you hauling. This way you get better mileage and lower egts.
__________________
Clay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
