Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 11:02 AM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
dustybumpers is gaining momentum as a positive member of FTE.
2002 7.3 no fuel
I have a 2002 7.3 with 16,000 miles. it was idleing good, but had no power to try to drive, was sputtering and missing, so I brought it back home and changed the fuel filter. I removed what fuel was in the bowl, thought might be water in there , but wasn't.when I closed the houseing back up, and started it, I t ran out of fuel, and won't restart. with the filter cap back off, and key on fuel is not comeing out. I closed it back up again, and keep cycling the key to hear the fuel pump, but it is not running. there is power to the fuse on both sides.I know that I am trying to dianois like it is a gas truck, but I don't know any other way. the cel has not come on, nor water in fuel. new fuel pump is $440, and I want to be sure that is what it needs, as I don't have that kind of money to just throw at the truck unless that is what's wrong
__________________
Charlie
Join the Maryland Chapter click HERE
  #2 (permalink)
Old 07-03-2009, 11:07 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
Sounds like the pump, about all else you can do is bench test it. If you end up needing a pump get ahold of me. I can get you a better deal than that. Good Luck
__________________
Clay 541.879.1052 www.RiffraffDiesel.com
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #3 (permalink)
Old 07-03-2009, 11:20 AM
owned by fords
is this pump located in the tank, or on the rail? sorry to be so dumb about this truck, but it is the 1st power stroke we have ever owned.
__________________
Charlie
  #4 (permalink)
Old 07-03-2009, 11:34 AM
owned by fords
I found the fuel pump in the rail. I took a test light, and held it on the terminals, while some one turned on the key. test light lit, but pump did not come on. I guess this means fuel pump bad?
__________________
Charlie
  #5 (permalink)
Old 07-03-2009, 12:29 PM
pmasley's Avatar
pmasley pmasley is online now
I Be The Instigator
pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold
Charlie. I wish you were closer. I have a used pump that you could test with. Better than spending a bunch of bucks and not need it since they cannot be returned.
Crack the fuel line in front of the pump (towards engine), turn key in attempt to start and see if you have fuel. If not, pump may be gone. Before you buy one, disconnect the rear line, take it to the ground and give a little siphon and see if you can get the fuel to run. If not, the sock is plugged. If you can get fuel, then you are back at the pump. I know, been through the whole routine, still bought a pump and found out I did not need it.
__________________
Paul
West Virginia Chapter
2001 F-250 7.3 Powerstroke Super Duty XLT Extended Cab 4X4 6 Speed 3:73
Goodyear Wrangler 305/70R16 ATS Tires
Banks Intercooler, tubes and 1999 Turbo Wheel
Steel HPX and CCV Mod
Bully Dog 4" Exhaust and AIS II Air Filter
FTE TEAM MEMBER of 53449
Member "Boy you ain't right club#7"
  #6 (permalink)
Old 07-03-2009, 12:53 PM
owned by fords
thanks, I'm going to do that, but when under the truck, some one cycling key, test light shows power, fuel pump not running, think pump, but with the low mileage on the truck, something has to have caused it to go bad. fuel filter was really black, mabe picked up some bad fuel somewhere, and sock is full too. thanks
__________________
Charlie
  #7 (permalink)
Old 07-03-2009, 12:57 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
If you have power / ground at the pump and it does not work,you have a bad pump.
  #8 (permalink)
Old 07-03-2009, 04:47 PM
owned by fords
had the truck towed over to work, they put a new pump on at no cost to me, and told me that this is a common problem with this truck. I love my job!!! thanks are due to all who helped me... Charlie
__________________
Charlie
  #9 (permalink)
Old 07-03-2009, 05:00 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold Izzy351 is a splendid one to behold
I don't know if it's any more common that any other electric fuel pump failure. But hey, at least you got it up & running!! And it sounds like someone else did the work for nothing. NICE!!
__________________
Joe
02 F250 XLT CC SB 7.3L PSD 2WD Auto
It’s got some mods.
  #10 (permalink)
Old 07-03-2009, 06:56 PM
owned by fords
Quote:
yeah, and my wife owns the rollback, so the tow was free too!!!!
__________________
Charlie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
