Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:56 AM
rangerfan's Avatar
rangerfan rangerfan is offline
rangerfan has a good reputation on FTE. rangerfan has a good reputation on FTE.
Does anybody run 40psi instead of the 35psi?
Does anyone run 40 psi in their tires instead of the recommended 35 psi? I'm just curious to see if there will be any consequences by running 5 psi over the recommended.
__________________
Duane
It's better to burn out... than to fade away - Joe Elliot
  #2 (permalink)
Old 07-03-2009, 11:16 AM
stu37d's Avatar
stu37d stu37d is online now
I love the holidays!!!
1994 Ford Ranger
stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of stu37d has much to be proud of
When I was spending 3.5 hours a day going to and from work, trying to squeeze a few extra miles out of a tank of gas, I would run a pound or 2 over the recommended. I also changed my oil about once a month and rotated the tires at every oil change. I didn't notice any extra wear on the tires- BTW, it was mostly highway miles to work, not too many curves and pretty good roads. I don't know if I would go 5 over, except maybe when you have a heavy load in the bed (only for a short time, though). Those limits were set for a reason.
__________________
Originally Posted by dono
I worry more about the world I leave my grandchildren than the fate of the polar bear.
" There are two ways to conquer a nation- one is by the sword and the other is by debt."-- John Adams
  #3 (permalink)
Old 07-03-2009, 01:58 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Obama runs 40 in his truck, he suggest you do too.
  #4 (permalink)
Old 07-03-2009, 02:49 PM
rangerfan's Avatar
Don't know what Obama has to do with this?
Will running 40 psi give me better MPG's?
__________________
Duane
  #5 (permalink)
Old 07-03-2009, 08:46 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
Obama suggested that in order to reduce our energy consumption we shoul make sure our tires are properly inflated.
Then I laughed.
It's funny because it's true.
  #6 (permalink)
Old 07-03-2009, 11:53 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE.
Quote:
lol, nice.
__________________
'94 Ranger XLT Ext. Cab 3.0L 5-speed
'97 Ranger XLT Ext. Cab 2.3L 5-speed
  #7 (permalink)
Old 07-03-2009, 11:57 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Don't run over the recommended pressure because tires must have the ability to expand and contract based on weather temperature. Don't mess with Mother Nature!
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #8 (permalink)
Old 07-04-2009, 01:08 AM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
The tires do have a margin of safety, and would be ok being slightly overfilled, but it may wear out he center of the tread more quickly. You are better off using a tire with lower rolling resistance than messing with tire pressures.
  #9 (permalink)
Old 07-04-2009, 03:48 AM
racsan's Avatar
racsan racsan is offline
1993 Ford Ranger
racsan is starting off with a positive reputation.
i run 44 in my uniroyal liberators (rated for 50 psi max) yes, it will wear the center faster, but its not extremely bad. thnk about riding a bike, if the tires are low or rock-hard, whats easier to pedal? i did lower them to 30 this week when my wife needed to have a cake trasported to the local fair, needed the smoothest ride i could get for the trip. havent aired back up yet, but i will. i'll sacrifice a little tire life and ride quality for fuel savings. my tires last quite awhile anyhow due to having 2 sets, one for summer and another set for winter. ive only ran at the max 50 psi once when i had the trailer on and heavily loaded with oak firewood. id ay the worst thing about running over 30-35 psi is braking ability, less contact with the road can equal less grip when coming to a stop. but i usually only have stopping issues when heavily loaded or on wet pavement. these tires just dont grip wet roads well, i was pulled over late one night after going around a corner and losing traction. i just let the tires spin until i shifted to the next gear. luckily i got off with a warning.
__________________
'93 Ranger Supercab,4.0L,4x4 5spd-hurst equipped. mile marker manual hubs. "the green machine" http://www.myspace.com/small_dog_trucking
http://www.cardomain.com/ride/3216869
  #10 (permalink)
Old 07-04-2009, 07:04 AM
smlford's Avatar
smlford smlford is offline
smlford is starting off with a positive reputation.
I usually run a few pounds higher in all my vehicles. It does help with improved mileage (~1 to 2 MPG)
The important thing is not to exceed the max pressure that is listed on the tire.
As stated above it could wear the center of your tires out faster if you have too much pressure. It will also increase the ride stiffness in the ranger. I didn't notive any ride difference in my F-350
On my Porsche, which already has a firm ride, it reduces understeer and tire roll in corners and actually improves the handling of the car. This is with a 2 PSI increase.
__________________
Eddie
2006 F-350 Larriat FX-4 CC PSD - OEM 20"wheels, Michelin LTX A/S, Spray in Bed Liner, Pace-Edwards Toneau, Fumoto valve, Coolant Bypass filter, Hidden Hitch
2007 Ranger XL 2.3 -2WD, Auto, Short Bed, The Beast !
Build Green ! www.PDandM.com
  #11 (permalink)
Old 07-04-2009, 10:22 AM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
Quote:
Originally Posted by racsan View Post
i run 44 in my Uniroyal liberators (rated for 50 psi max) yes, it will wear the center faster, but its not extremely bad. think about riding a bike, if the tires are low or rock-hard, whats easier to pedal? i did lower them to 30 this week when my wife needed to have a cake transported to the local fair, needed the smoothest ride i could get for the trip. haven't aired back up yet, but i will. I'll sacrifice a little tire life and ride quality for fuel savings. my tires last quite awhile anyhow due to having 2 sets, one for summer and another set for winter. I've only ran at the max 50 psi once when i had the trailer on and heavily loaded with oak firewood. id say the worst thing about running over 30-35 psi is braking ability, less contact with the road can equal less grip when coming to a stop. but i usually only have stopping issues when heavily loaded or on wet pavement. these tires just don't grip wet roads well, i was pulled over late one night after going around a corner and losing traction. i just let the tires spin until i shifted to the next gear. luckily i got off with a warning.
Not to sound like a wet blanket, but the first problem here is relying on the tire's sidewall marking instead of the using the pressure listed inside the door and in the owner's manual that was recommended by the engineering team at the factory. This is a common mistake, since many do not realize that the pressures listed on the side are a reference for "Max PSI @ Max load". IE - The tire is safe to use with an individual load of X lbs and inflated to Y PSI to handle that load. So if a tire said it could handle 1800 lbs then using the bed as an example: (1800 x 2) = 3600 - ~1500 (estimated weight over the rear axle) = 2100 lbs You would have to be hauling 1Ton+ in the bed to justify inflating tires to the Max PSI. Also 1800 lbs is just a rounded figure, most tires that fit our trucks will handle more 1600 to 2100 lbs depending on the tire you choose.
EDIT - Here is an example of this: http://www.tirerack.com/tires/tirete....jsp?techid=21
This may sound like a lot of technical garbage, but it is important to understand. The point of all this to the OP, and anyone else is there is a specific volume of air that is required to carry the load of the truck alone, and most daily light loads. That volume was calculated by the factory given a range of sizes and types of tires that come on the different model trucks. While it is true that this number has a lot of assumptions built into it, there are safety concerns, ride comfort, wear life, fuel economy, etc.. Sure tires differ in design, and deviating +/- 1-3 lbs from the factory recommended setting can be done to "tune" your truck for best wear, MPG, and braking. It may not sound like much, but 1 lbs of air can make a lot of difference in how a tire will perform. Not to pick on Racsan, but every problem he listed is a direct result of having that much air in a tire carrying a relatively light load.
Happy 4th everyone, be safe. That includes on the road, and in the back yard.
__________________
88' Ranger XLT Supercab, 4x2
2.3L, 5sp "dirt brown color"
In loving memory of Dr. Carl R. Swenson - R.I.P. Cigarettes DO kill.
In loving memory of Geordie - R.I.P. You are deeply missed each and every day.
  #12 (permalink)
Old 07-05-2009, 09:24 AM
pawpaw pawpaw is online now
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
Yup many things to consider when airing up above the specified figure on the door sticker.
As mentioned, ride, handeling, braking, traction & tire wear are affected, some more thigs to add to that list, internal & external tire impact damage, wheel bearings, brake, suspenaion, steering, running gear including wheel rims & body parts also take an additional beating from over aired up tires!!!!
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #13 (permalink)
Old 07-05-2009, 10:16 AM
Former Vendor
I agree, I have seen lots of premature wheel bearing failures that were the result of overly firm tires. And it does make the ride a lot rougher, especially if the roads aren't in good condition.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
