Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:52 AM
BarnieTrk BarnieTrk is offline
BarnieTrk is starting off with a positive reputation.
More Warranty Plate Questions...
Well Fellas,
I've had this SWB, 2WD, '65, F-100, 390" to a T-18 to a 9" rear for over 25 years. It appeared to me that a previous owner must have attached a '63 front clip, because it had a '63 front-end, yet still had the Twin I-beam front suspension. All in all, I never took the time to look up each data point on the Warranty Tag located on the door. Well, I wrote them down and tried looking them up --- and now I'm confused.
The VIN# is: F10DD673615.
Ok, according to the info I have, this VIN indicates:
F10 = 2WD F100,
D = in '65 a D indicates it should have a 352 V8, 2bbl, 208Hp @ 4400rpms
D = indicates the assembly plant at Dallas, TX
673615 = indicates the build date of April 11965.
HOWEVER the remaining data indicates:
WB: is stamped 115 ; Now I thought the wheelbase should be 120 or 121?
Color code is: W; Fine, it is Marlin Blue.
Body code: B81; Ok, so they got the stamping backwards & transposed the normal 81B. It would indicate a '61-'66 Custom Cab, ok, the front clip does indicate traces of CC trim.
Model code: F100; correct.
Trans code: N; Ahhhh,,, what is this??? I would of expected a ' F ' for a 4-speed Manual.
Axle code: 07; I think this is correct for a 9" rearend...
GVW: 5000 ; which seems correct for a 1/2 ton with a 9" rear.
HP: 172 ; What?? I can't find this HP to match any engine in the '61 -'66 F100 truck lineup.
RPM: 4000 ; Well, from what I could determine, the only engine listed with a RPM at 4000 for '65 was the 240" 6-cylinder @ 150HP...?
DSO: Houston, TX. This makes sense.... years ago I bought it in Houston.
So -- if anyone would shed some light on my confusion regarding the WB, TRANS, HP and RPM codes, I'd be very thankful!
Thanks in Advance, Guys!
BarnieTrk
  #2 (permalink)
Old 07-03-2009, 12:56 PM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is offline
1963 Ford F-100
My Garage
gritsngumbo is starting off with a positive reputation.
I'll let someone else do the Warranty Tag decipher, but I was just curious as to why you thought the engine was a 390 all these years? It's my understanding from attending FTE University :-) that the 390 was never Factory installed in trucks.
__________________
64 Ford F100 Styleside Short Bed /223 "6" & 4 speed "Little Red"
63 Ford F100 Unibody Styleside Longbed w/292 V-8, 3 deuces, dual exhausts & 3 speed "Big Red"
63 Ford F250 Flareside Long Bed w/292 V-8, two barrel, dual exhausts & 4 speed "Big Un"
63 F100 "Stageway" Crew Cab Long (wrong) bed. 292 V-8 & 3 speed
  #3 (permalink)
Old 07-04-2009, 03:10 AM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a good reputation on FTE. garbz2 has a good reputation on FTE.
F10DD673615.
F10 F100 series truck
D 352 V8
D Dallas assembly
673615 Assembled in April of 1965
115" is a short beds wheel base for 65
W 1742A Medium Blue
B81 Blue woven plastic and blue vinyl with foam cushion A custom cab body 81 conventional gas.
N 4 speed new process 435.
07 3.25 ratio 3.3M open rear. (a 9 Inch)
5000 is the maximum weight of the vehicle allowed with cargo and passengers.
172 is the certified net horsepower... Not the 208 HP advertised onthe air cleaner.
172HP @ 4000 RPM
DSO Dallas is 61
This information is imported directly form the 1965 ford shop manual.
You may have 63 fenders and hood and lower valance but not the core support and inner aprons as they are specific to the 65 66 2 wheel drives and the eariler 2 wheel drive and later four wheel drive inner aprons will not fit the cowl of the 65 66.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive 410, C6.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #4 (permalink)
Old 07-04-2009, 03:44 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
B81 is correct!
B = Medium Blue Crush Vinyl & Medium Blue Ladder Pattern Woven Plastic.
81 = 81B Custom Cab
W = Marlin Blue is the promotional name, Medium Blue is the actual color.
The 1742A that Garbz2 refers to is the Ford part number for the paint.
AE60-1742-A = 3 ounce touch up can with brush.
AE60-1742-S = 10 ounce spray can.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #5 (permalink)
Old 07-04-2009, 08:22 AM
Thanks Guys for all the research assistance!
(Have I mentioned lately there are a bunch of GREAT guys on this GREAT forum!?)
Quote:
Yep, I agree with you ..... a 390 was not an optional engine for a Slick.
However, when I bought the truck, the previous owner told me the engine was changed to a 390, then I confirmed it was a 390 when I rebuilt it 1997. I had hoped this issue would not cloud my Warranty Plate question, but because I list the truck in my Signature Header as having a 390, I mentioned in the post in order to match what it currently is - and to match my Sig Header - which is that it currently has a 390 mill.
Quote:
Originally Posted by garbz2 View Post
F10DD673615.
D 352 V8
D Dallas assembly
W 1742A Medium Blue
172HP @ 4000 RPM
DSO Dallas is 61
You may have 63 fenders and hood and lower valance but not the core support and inner aprons as they are specific to the 65 66 2 wheel drives and the eariler 2 wheel drive and later four wheel drive inner aprons will not fit the cowl of the 65 66. Garbz
VERY INTERESTING, GARBZ!!
So:
115" = wheelbase is correct.
N = a new process 435 4 speed. (Interesting.....So that too was changed prior to me; because I know it's a T-18 since I pulled it to get freshened back in '87 and ' T-18 ' was/is cast into the side of the case).
172 = is NET HP for the 352".
07 = is indeed the axle code for a 9" rear end housing.
Lastly, it's also interesting & good information regarding the specific inner body panels which must NOT have been changed when the outer sheet metal was changed.
Quote:
Originally Posted by NumberDummy View Post
B81 is correct!
81 = 81B Custom Cab
Thanks for the clarification on the Body code and color info, Bill!
I'm thinking the color part number and actual color name may be helpful when it comes time to color match the ol' Dude.
Well, Fellas,,,, I will take this all info and transfer it into my TRUCK Journal notes to have & to hold.
THANKS AGAIN FOR CLEARING UP THESE QUESTIONS FOR ME, GUYS!!!
BarnieTrk
__________________
- 2WD '65 F100 short box, 390" FE, T-18 4spd
- 2WD '65 F250 long box, 390" FE, T170FT 4spd OD
- 2WD '94 Ranger XLT, r/cab, 139" (2.3L) 4-cyl, 5spd
  #6 (permalink)
Old 07-04-2009, 08:45 AM
F10DD673615.
D 352 V8
D Dallas assembly
DSO Dallas is 61
- Garbz
,,,,Ok,,,,,We agree that the truck was assembled in Dallas, but are you saying DSO 62 ISN'T Houstion, TX ?
BarnieTrk
  #7 (permalink)
Old 07-04-2009, 03:23 PM
Ford Parts Guru
Quote:
BarnieTrk
You didn't type the DSO code, all you said was that the DSO code pointed to Houston.
DSO 62 = Houston TX Ford District Sales Zone Office.
DSO 61 = Dallas TX.
__________________
  #8 (permalink)
Old 07-05-2009, 08:43 AM
Ahhh,,,, and I'm probably out of range for your ESP reception, ay?
Yep, I see that now...I didn't mention it earlier.
Yep, the DSO on the Warranty Plate is 62. So, "Houston, we have confirmation." Cool.....
Thanks again, Fellas!!
BarnieTrk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
