Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:48 AM
2005V10F250CC's Avatar
2005V10F250CC 2005V10F250CC is offline
2005V10F250CC is starting off with a positive reputation.
Unhappy Torqshift gushed fluid from overflow
We were towing our 9000lb camp trailer home from camping in the redwoods. I waited until I got to flat land in Redding, CA on I-5 south to turn on the A/C. Drove about 30 miles on I-5 at 55mph with the tranny in tow haul mode. We took an off ramp with a stop sign at the top. When I stopped fluid gushed out of the overflow onto the exhaust pipe. An observer said it flashed to flames, when I jumped out and looked I only saw fluid dripping off the exhaust and a cross member. I had towed about 200 miles in the coastal mountains prior to the 30 mile stretch on I-5 with no issues.
Took it into the dealer and they found nothing wrong. They did suggest that I had overfilled it, but I have never put tranny fluid in the truck in the 36K miles since new. As a matter of fact they are the only ones who dealt with transmission fluid when this happened once before a little over a year ago. Anyway they flushed the tranny, replaced the external filter, and flashed TCM. They didn't mention the PCM. The rep said there were 8 updates newer than the version my truck was running.
So anyone seen anything like this? Does what they say make sense? Do you really think this is the fix?
__________________
2005 F250 XLT CC
V10,4.10:1,Auto,FX4,TowCommand,
Transferflow 46ga tank,Line-X,
toolbox,Husky liners and Mud flaps,
Stainless fender liners
2007 29ft Keystone Springdale Travel Trailer
  #2 (permalink)
Old 07-03-2009, 11:33 AM
Oh yeah, one more thing, the dealer suggested that I change the tranny fluid every 20K miles. Funny they act like pulling a 9000lb trailer 3-4 times a year 400-600 miles is some sort of extreme case. From what I've read on this forum I'm pretty easy on my truck...
__________________
2005 F250 XLT CC
  #3 (permalink)
Old 07-03-2009, 11:47 AM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
The only thing I know that will cause that would be overheating.
What did the trans. guage read?(realizing it's not the best, but was it pegged?)
  #4 (permalink)
Old 07-03-2009, 11:54 AM
Sorry forgot that info. I routinely check the temp guages, and they were in the mid range. I looked at the transmission temp guage immediately after it happened and it was where it always is just below middle of the guage. The only time I ever see that guage anywhere besides just below half is when I start it up cold. While I'm filling in the blanks, I checked the fluid level after I let it cool a bit and it was full, and the fluid didn't smell burnt or look discolored.
__________________
2005 F250 XLT CC
  #5 (permalink)
Old 07-03-2009, 11:48 PM
racinghoss's Avatar
racinghoss racinghoss is offline
racinghoss is starting off with a positive reputation.
Do you have the snow plow prep?
Read this: http://www.ford-trucks.com/forums/84...hift-case.html
It is a thread I posted where I had a very similar issue to yours.
__________________
2005 F-250 XLT CC SB, 5.4, TQShift, Man. 4x4, 3.73
2008 Expedition EL Eddie Bauer 4x4
2005 Keystone Springdale 27' Bunkhouse 5th Wheel
2000 Jeep Wrangler, built for trails
Gone: 1976 F-250 4x4 HighBoy, 390, 4sp
(2) 1990 F-150's, 300/6, 5 sp, (1 4x4 and 1 4x2)
  #6 (permalink)
Old 07-03-2009, 11:49 PM
racinghoss's Avatar
lol...after reading your sig line, maybe ford should put out a tsb on pulling springdale trailers...
__________________
  #7 (permalink)
Old 07-04-2009, 10:27 AM
I don't have the snow plow prep. I wish I knew about this about this before I took it in so I could have suggested it to the service manager to make him rule it out. I really think my issue is heat related as it only happened after I started running the AC.
I don't think I'm asking too much of the truck running the AC while towing my trailer on flat land at 55 am I?
__________________
2005 F250 XLT CC
  #8 (permalink)
Old 07-04-2009, 12:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
Snow plow prep doesn't have anything to do with the trans. Snow plow and non-snow plow use EXACTLY the same transmissions.
The only way fluid is going to come out of the vent (there is no overflow on any automatic transmission) is if it is overfilled.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #9 (permalink)
Old 07-04-2009, 12:22 PM
mmmmm...beeer
What about overheating ?
  #10 (permalink)
Old 07-04-2009, 01:47 PM
Only if it's overfilled.
During testing I've had TorqShifts up to 250F in the pan and over 300F in the line to the cooler. The fluid level was correct before starting the test and the trans never lost any fluid.
__________________
Mark
  #11 (permalink)
Old 07-04-2009, 07:14 PM
racinghoss's Avatar
I must have misunderstood what I read then; thanks for the clarification.
At any rate, you may have still encountered the same problem. It was hard for the techs to find on mine. It took them several days. Finally they pumped the dye through it and put it under a stressful load to find a tiny bit of seepage on top of the case. Then they pulled the tranny to find the crack and the mark left by the piston that went haywire after the snap ring let go.
Since FORD is well aware of the problem, you might take it back. You may not notice the problem until next time you are towing (with your truck under a load) and the things starts to spew fluid again. BTW, mine did not lose much fluid either and it was not hot at all.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
