Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 10:35 AM
Steelheader87 Steelheader87 is offline
Steelheader87 is starting off with a positive reputation.
My radiator seems to be low on fluid
It seems that my fluid level is low, I add up to a gallon of water about once a month. Should I be worried? I don't see antifreeze in the cab or anywhere for that matter. At times, I can hear a boiling noise which I assume is the radiator, temp gauge never gets too hot. Any thoughts. At times, after a long haul I can smell the sweet smell of antifreeze, but not all the time. Should I be concerned about head gasket. The oil is not milky, so none getting there. Been thinking about flushing my radiator and adding good clean antifreeze. What are some thoughts?
  #2 (permalink)
Old 07-03-2009, 11:47 AM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
Definitely flush and fill, add some SCA's and check all fittings, hoses, and all over the radiator for rot, pinhole leaks etc etc. When you are driving the truck down the road and smell the sweet smell, pull over to see if you can spot a small leak, it may only present with high pressure/high heat. Best luck bro and find it now! I had a 93 bronco that started steaming really bad one hot day and so i pulled over, popped the hood and found a sprinkler, the main top hose had sprung about 20 leaks and it was shooting everywhere. limped it to autozone and replace the hose, then on the way back to the house the bottom hose did the same thing, so i bought all new hoses all around and fittings and did a flush and fill, better to do them all when one goes.
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #3 (permalink)
Old 07-03-2009, 05:03 PM
tbone91 tbone91 is offline
tbone91 is starting off with a positive reputation.
Look real closely at the overflow tank. It could be cracked...
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #4 (permalink)
Old 07-03-2009, 07:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Look at the rear two glow plugs.
As my original engine got up in miles sometimes it would leak a little and fill the rear intake web around the glow plug.
Mine was always on the passenger side.
If enough gets in there to go through the valley pan drain, it will wind up on the exhaust and result in the sweet smell.
Also inspect the area around every hose connection.
More than once I have found leaks that were big enough to loose a bit of coolant, but never show up on the ground around the hose clamps.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
