My 96 F350 4x4 with the 460/C6/BW4406 combo gets terrible mpg. I have 33" tires on it and still at 55mph I am at 2200rpm. I also want more low end grunt for pulling my trailer. I have an NP435 tranny with the 351m/400/460 bolt pattern and would like to put it in my truck. I also have the transmission to t-case adapter as well as an NP205 to use. The only thing I really need is a new flywheel and I'm set. I was just wondering what you guys would do if you were me? Would you do the tranny swap or keep the C6 and do something to boost power like a chip? I already have long-tube headers and a cat-back dual exhaust on it. I still need more power and I think the C6 is robbing too much off the line. I can't go smaller on the tires because I need the clearance and my highway rpms are too high already. I need help.....
A NP435 is a great tranny, but like the C-6 it only has a 1:1 final gear ratio out to the axle. You wont be gaining anything on the highway, also if the NP435 came from a 351M/400 you will need to increase the distance between the tranny and the motor due to the input shaft. 460's flywheels are further into the bell housing than the 351M/400 even though they both share the same bell housing. If you want to go manual and get a tranny that is a bolt in for the 460 as well as has a high gear to reduce the highway RPMS a ZF5 would be the way to go.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
Not to be rude but I have the np435 and not a zf5 so that is not one of my options. I also know that the c6 and 435 have the same final ratio but I want more low end grunt. Would you guys take the c6 or np435?
C6. Just get you a custom torque converter built that can make all the difference in the world. This could save you the trouble of converting tranny's
__________________
1996 F-250 XLT 460 Super Cab 4x4 4 inch lift 33x12.5 Tarra Grappler's on Pacer alloy's. Rebuilt motor, comp cam, ported heads and intake, hedman headers, wide band AFR, mass air and anderson PMS
1986 stang 351W, TFW heads, big roller cam, TKO 600 tranny + 7 yrs of my life and every pay check.
Its all prefference. Do YOU like to shift? If not use the C6. If you like shifting use the 435.
As for the zf i know more than 20 ZF5 transmissions w more than 200k+ miles without one problem. Most behind diesel and big blocks. The BBF gasser pattern ones go for cheap
Personally, I would take a NP-435 over a C-6 anyday. I am biased because I learned to drive the NP-435 first, and it just has more gears than a C-6. I also just like shifting gears and working the clutch.
__________________
If you are looking for brute stump pulling low end torque, the NP435 is king it has a super low 6.69 to 1 ratio first gear. That is much lower than the C6 (not sure what ratio) and still lower yet than a ZF (5.72 to 1). For straight up bulletproof reliability you just can't beat the old granny 4 speeds. I broke the pos M5OD in my 96 F150 (formerly 4x2 now 4x4) and swapped in a ZF 5 speed I absolutely love it. It still has the same ratio OD as the M5OD, but has that nice deep first gear for towing and 4 wheeling. So you have the perfect combination of good low end grunt for work, and a nice tall overdrive for cruising on the interstate. To answer your question, I would say go with the NP435.
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ 4 spd
1984 Ford F150 4wd/ 300 six/ 4spd
1996 Ford F150 XLT 4wd/ 300 six/ ZF5
1984 Ford F250 XL 4wd/ 6.9 IDI/ C6
G.Fs. Trucks: 1977 Ford F150 4wd/ 351m/ C6 1990 Ford Ranger 4wd/ 4.0/ A4LD
If you've GOT the NP435 I would go for it, I prefer manuals in my trucks, I love my 73, but wish it were the NP435 also... that is ALSO the reason I just bought my 96!
__________________
SEMPER FI
02/Ex/4x/7.3
96/350/CC/4x/7.3/ZF5
77/150/SB/4x/NP435
63/250/Flatbed/4x/T-18
Using a manual tranny will give little better MPG as you don't have the "frictional losses" with a automatic transmission. I heard the C6 eats up some HP to operate.
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
I swapped a T18 in place of my 91's C6 and couldn't be happier. It's very nice being able to use gearing to slow you while towing, and driving it how you want to. I usually skip 3rd unloaded and the 460 does not care at all. Even with 3.55's it does leave overdrive to be wanted. I am looking for a ZF5, but will miss the T18 when it goes.
__________________
1991 F150 XLT Lariat... Sold
1991 F350 Custom
460, T18, soon to be ZF5, Tow rig for the Jeep.
I have (4) C6's, (3) NP435's, (1) T-18, and (1) SM465. What do you guys like the best and would you use? I know the SM is GM but I thought I would throw that in there in case one of yall wants it...haha.
