Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 03:17 AM
xFordx78 xFordx78 is offline
xFordx78 is starting off with a positive reputation.
Door window problems
Ok I have a 1997 ford f-150 XL extended cab and the passanger side door window will not roll up without some help which is really annoying.So I removed the door panel and looked inside and the big metal thing that rolls the window up has some teeth that are worn and broke off causeing it not to roll up when it gets to a certain point can anyone tell me what this part is called so I can know what I need to buy to fix it and how hard it is to fix? these are manual windows no pwer.Thanks hope someone can help
  #2 (permalink)
Old 07-03-2009, 03:59 AM
Looks more like a flywheel the about 5 teeth are broke preventing window from functioning just dont know anything about replacing that part or what it is called.
  #3 (permalink)
Old 07-03-2009, 06:52 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero is gaining momentum as a positive member of FTE.
It's called a window regulator.
http://cgi.ebay.com/ebaymotors/97-98...%3A1|72%3A1171
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #4 (permalink)
Old 07-03-2009, 12:35 PM
I dont think that is it that part looks like what takes the window up and down.The part I need looks like a big flywheel with teeth like a sprocket the teeth are broken.
  #5 (permalink)
Old 07-04-2009, 03:18 PM
Nobody knows what that flywheel looking object inside the window is called or how to fix it?
  #6 (permalink)
Old 07-04-2009, 04:03 PM
ncranchero's Avatar
Quote:
Originally Posted by xFordx78 View Post
Ok I have a 1997 ford f-150 XL extended cab and the passenger side door window will not roll up without some help which is really annoying.So I removed the door panel and looked inside and the big metal thing that rolls the window up has some teeth that are worn and broke off causing it not to roll up when it gets to a certain point can anyone tell me what this part is called so I can know what I need to buy to fix it and how hard it is to fix? these are manual windows no power.Thanks hope someone can help
The photo in the link may not appear to be the same thing but the "thing" with "teeth" that looks like a "flywheel" , or should look like half of a flywheel, IS called a window regulator.
It will require drilling out 3 rivets, 1/4" dia. rivets, and you'll have to have access to a large rivet gun capable of replacing those 1/4" rivets. If you don't have or can't borrow a rivet gun of that size it would be best to see what a shop will charge to replace the WINDOW REGULATOR. Those rivet guns are well over $100.00 .
__________________
Steve,
  #7 (permalink)
Old 07-04-2009, 04:57 PM
Ahh so the big fly wheel looking thingy with the teeth is in fact a window regulator ok thanks a lot I will see how much a shop will charge.
  #8 (permalink)
Old 07-04-2009, 08:28 PM
westtexastiger westtexastiger is offline
westtexastiger is starting off with a positive reputation.
I thought that whole assembly was referred to as the window regulator, not just your part that the plastic teeth sheered off of. Sounds like what happened to an '02 Grand Am SE I used to own. I only had the car for three years, but I replaced the driver's side front window regulator FOUR *bleep*ing times. Replaced the passenger side from once, too.
  #9 (permalink)
Old 07-08-2009, 12:28 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
The teeth part and the arm is usually sold as a whole assembly. I just checked our site for you.I don't have one for this application.We carry a pile of these things too.
If you have anymore questions,feel free to pick our brains.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
Tags
97 , door , ebay , f150 , f350 , ford , pick , problem , regulator , regulators , window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
