Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 09:29 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
You don't want a 6.0L that has set lot either. It's hard on the Turbo. If you're driving is a lot of short hop (less than 20 miles at a time) then a 6.0L PSD probably isn't for you. They like to be worked and not idled a lot. I had an 05 from brand new and it was going to be problematic, so I got rid of it. I've been told by a lot of Ford diesel techs that they seem to start having major problems at around 70,000 miles if they are going to have them. They are much more expensive to repair than the 7.3 was and do require more attention. They tend to shear oil quicker than 7.3's and 6.4's so regular oil changes are important. Use only Motorcraft filters and change fuel filters religiously at the recommended 15k intervals. I probably would not buy another 6.0L, but they aren't all bad. But they do not hold up to abuse like the 7.3 did. Things that can go bad that are expensive to repair are fuel injectors, high pressure oil pumps, egr coolers, oil coolers, and Fuel injection control modules, head gaskets, and turbos. Once it does go out of warranty, they are expensive to repair.
  #17 (permalink)
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew is gaining momentum as a positive member of FTE.
Dang man, thanks for the info!! I wasnt aware I owned a POS, Im gonna go out and trade it for a cummins right now!!! Come on guys, if ATS cant fix it, who can? We all have junk trucks, guess we all will be spending our holiday weekend trading our trucks.
__________________
God is Great, Beer is good, people are crazy
'06 F250 PSD XLT, CC, SB, 4x4, SCT custom tune from eric, ARP studs, autometer gauges, 4'' MBRP turbo back, AFE stg II, EGR delete, Zoodad, Chrome step bars, '08 mirrors, viper Alarm, Rough Country 8'' Lift, MT MTZ 36-15.50-20, 20X10 Motometals.
ASE + GM Master Tech+ L1
  #18 (permalink)
Old 07-03-2009, 09:42 PM
Robrstopr's Avatar
Robrstopr Robrstopr is offline
Robrstopr is starting off with a positive reputation.
LOL.. I know right. forgot to mention crap mileage....13-14 MPG at best on this rig.
Some will say they get 18-20 plus, but do the research and see mine is the norm.
My truck is spotless. Motor everything looks bad a$$. if I knew how to post pics of all of it I would make your mouth druell, but truth is no mater how awesome it looks, the 6.0 sucks.
  #19 (permalink)
Old 07-03-2009, 09:52 PM
Robrstopr's Avatar
Forgot, I joined this site because I bought this 6.0. Once I've read all the threads I was scared, and wish I didn't buy it. I was hoping I got a great truck because everything you experts said to change out or delete was just done.
I was wrong... I'm on vacation for the next month and a half. Was to leave tuesday, but after changing the serpentine belt and having the AC re charged, I started blowing anti-freeze again. Boost is lifting my new heads and ARP studs.
Vacation is on hold. Sure wanted to show off my bad A$$ 6.0. worst part...I have about every recreation vehicle...atv's, snowmobiles, 5th wheel, dirt bikes, and a small boat. Never towed with this truck yet.
Sounds like they tow nice for those with a 6.0 that works.
I'm not happy, but maybe you could get one of the gooder ones.... If you spend enough time reading these threads you'll wonder who has the good ones.
  #20 (permalink)
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Tuners can be murder on our trucks. If you want a tuner, get one that is custom (ie programs written specifically for our engine and transmission). Most folks say the SCT is the only way to go.
ATS is not the "premier" place for mods that you make it out to be. At least not for the tuner and head work. Lots better places to go for that.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; Valvoline Premium Blue Extreme 5W40; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; DashDaq on deck; Line-X, CPOhighway Products tool box, tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox
  #21 (permalink)
Old 07-03-2009, 09:53 PM
MeyerzF350 MeyerzF350 is offline
MeyerzF350 is starting off with a positive reputation.
55,000 miles on mine. Oil leaks were an issue but very dry since they fixed the bed plate. I don't think the 6.0L is the way to go if you want to modify it. It's a great engine, but needs special attention in regards to regular services. My local diesel mod shop said they will not mod that engine. If you want lots more HP and torque go with the other guys.
I have a fleet (40) of the 6.0L in E350's and they are solid for 400,000+ miles and we have lots more "hours" than the normal 6.0 because we never turn them off on a 10-12 hour day. In a typical day we idle them for 15-20 minutes at 20-30 stops per day.
That being said we are moving to the detroit diesel (branded as Mercedes deisel in Sprinters) due to the increase in fuel mileage. Hoping to get 500,000 out of these.
__________________
2005 F350 Lariat CC 4x4 6.0L SRW
  #22 (permalink)
Old 07-03-2009, 09:58 PM
Robrstopr's Avatar
They may not be great, but you'd think for all the crap they make and sell they'd have it worked out.
Also, ATS and SCT tuners are the same. SCT makes the ATS E-Power. My tunes suck, and ATS for the past 2 moths have been giving me the run around saying SCT's tune site is down. Eric at Innovative is making my tunes now. Won't help much if I can't keep the heads strait and tight.
Sorry if I sound anti Ford....I'm not. Just Anti 6.0.
  #23 (permalink)
Old 07-03-2009, 10:05 PM
Quote:
Seems like the Cummins guys are much happier when they mod the truck. When I am done with the 6.0L in this truck, I will think about installing a different engine. Maybe CNG.....that would be cool.
__________________
  #24 (permalink)
Old 07-03-2009, 10:11 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
2003 Ford F-250
ljutic ss is gaining momentum as a positive member of FTE.
[quote=Robrstopr;7677691]Check out ATSDiesle.com. They are one of the most popular after market diesel companies around. If they can't get it to work.....its junk.
This truck has been twice since they redid the heads, gaskets, studs.....ect.
2004 Ford King Ranch 6.0 fficeffice" />>>
NADA $23,850.00>>
1. Road Amour Front Bumper: $2900.00
2. Road Amour Rear Bumper: $1800.00
3. Warn 16.5 Ton Titanium Winch: $2300.00
4. Warn 200,000 HID Spot Lights64560 : $1450.00
5. Warn 200,000 SDB Spot Lights 37609: $600.00
6. Pioneer AVIC –X910BT Stereo: $1200.00
7. Pro Comp MX6 Adjustable Shocks: $1800.00 ….6 X $300.00
8. Pro Comp Suspension 4’’ Lift: $1400.00
9. ATS E-Power Tuner: $550.00
10. ATS Aurora Turbo: $2700.00
11. Optima Yellow Top Batteries: $460.00…..2 X $230.00
12. Banks Monster Exhaust: $1175.00
13. Banks Intercooler: $1350.00
14. AFE Cold Air Intake: $300.00
15. Diamo Chrome Rims: $1100.00…….4 X $275.00
16. Mag-Hytec Diff Cover Front: $260.00
17. Mag-Hytec Diff Cover Rear: $240.00
18. Nitto Terra Grappler Tires: $1500.00
19. ATS Fire Rings: $1650.00
20. ATS Fire Ring Heads: $1750.00
21. Banks High Ram Air: $350.00
22. Mag-Hytec Transmission Pan: $350.00
23. Husky Floor Mats Front & Rear: $225.00
24. Brushwacker Fender Flares: $350.00
25. Bumper Coating: $450.00
26. Bed Liner: $600.00
27. Alpine 6 X 9 Speakers: $640.00……4 X $160.00
28. Alpine 10’’ Sub Woofer: $400.00
29. Kicker ZX-300: $440.00
30. APR Head Studs: $575.00
31. Reflection Hood Cowl Induction: 700.00
32. Putco Grill: $450.00
33. ffice:smarttags" />lace>Genevalace> Tool Boxes: $500.00………2 X $250.00
34. Quarter/Tail Gate Panel Liner: $800.00
35. Add Leaf Springs: $500.00…….2 X $250
TOTAL $56,615.00
This doesn't count labor or paint work. Make ya a good deal or Trade for a Dodge....I have all records of work.
Craig[/quote
Are you sure you really need a Diesel powered truck? sounds like your truck is a street cruiser.
  #25 (permalink)
Old 07-03-2009, 10:32 PM
Robrstopr's Avatar
Are you sure you really need a Diesel powered truck? sounds like your truck is a street cruiser.[/quote]
My last two trucks were 2002 2500 Dodge Diesel purchased new, gave it to my brother at 90k, only replaced one rear shock.
Bought a 2007 3500 Dodge Dielel purchased new. Never had any issues. Sold with 55k miles on it because the guy I got this truck from if a good friend and I knew about everything done to it. Figured after all his issues it was a perfect truck at a steal of a deal. He bought an 09 Dodge, and never used this truck for its Diesel capabilities. Basically a new truck with low mileage, and a crap loads of extras.
I tow about 80% of the time I'm operating my trucks. I haven't had a chance to tow with this one. My bros with new Dodge Diesels want to drive now. Better mileage and less wear and tear on my truck....who'c complaining.
  #26 (permalink)
powerstroke72's Avatar
powerstroke72 powerstroke72 is online now
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
If yours is the norm, I'm gonna keep mine forever. I get 15-17 daily in mixed driving and have gotten as much as 21.7 on a trip. 35k miles and not a problem at all.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #27 (permalink)
Old 07-03-2009, 11:35 PM
ljutic ss's Avatar
2003 Ford F-250
Speaking of mileage I get 16 suburban/rural driving in the summer, 14/15 winter. On the interstate at 65 19/20 empty.
  #28 (permalink)
Old 07-03-2009, 11:37 PM
Big J
2005 Ford F-250
Glad I'm not the only one with an abnormal truck there ss....LOL
__________________
John
  #29 (permalink)
Old 07-03-2009, 11:47 PM
saskdiesel saskdiesel is offline
saskdiesel is starting off with a positive reputation.
I had an 05.
Bed plate, EGR, 2 turbos, 4 injectors, head gaskets twice.
Since I like the SuperDuty platform I went to a gasser. After owning a 7.3 that gave me zero trouble I was very surprised and disappointed in my new diesel.
Needless to say the 6.4 isn't looking to good to me. Sometimes I find myself looking at 6.0's now and then and I suppose there are some good ones out there...
But why should I have to take a chance?
  #30 (permalink)
Old 07-04-2009, 12:38 AM
Robrstopr's Avatar
I guess my crap mileage can be because I live in CO. 7k elevation, but my other vehicles didn't have the issue.
Tags
12 , 60l , alpines , battery , comps , cost , diehard , epower , f150 , ficm , ford , install , marine , platinum , pm1 , pro , repair , subs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
