Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 01:11 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has a good reputation on FTE. ford2go has a good reputation on FTE. ford2go has a good reputation on FTE.
Left hand thread lug nuts
Just saw a random comment about LH thread lug nuts on one of the larger F series -- possibly a 350.
Seems to me that there was a theory that they'd self tighten -- when they were on the driver's side ( I believe).
Thought I'd ask who knows what vehicles used them and when they quit.
Mopar used them into the late 60's. I actually don't think that they changed until 1970. ( Most of the time they were kind enough to put an L in the wheel stud. )
Anybody know about some others.
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
  #2 (permalink)
Old 07-03-2009, 07:30 AM
cjben cjben is offline
1995 Ford F-150
cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold cjben is a splendid one to behold
my grandma's 78 volare had them,as I found out the hard way when I was changing a flat tire and couldn't get the lug nuts off
__________________
I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
1995 f150 xlt extended cab flareside 5.0 33" tires 3" body lift
  #3 (permalink)
Old 07-03-2009, 04:33 PM
petes79f150 petes79f150 is offline
Social Outcast
petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all
The only ones I have ever run across, were the police-issue Dodge Polara's back in the mid to late 60's and was a special-order item from the CHP, passenger side only. That was one sure tip-off to a true non-emmissions Cali big block Chrysler product. When you think about it, it really does make sense, until you try to do a resto on one.
I'm sure there were others, but I'd have to dig deep into my books. I bet NumberDummy could tell ya a lot more than us mere mortals. Didn't the Hudson Hornets have the left hand threads on the pass. side?
Pete
__________________
The Hurrier I Go, The Behinder I Get.
  #4 (permalink)
Old 07-03-2009, 04:54 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
My 73 F-350 Tow truck has left hand threads on the drivers side.
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #5 (permalink)
Old 07-03-2009, 05:15 PM
Social Outcast
Quote:
Having no experience with the heavy Fords, I still just don't get it. Wouldn't you want the lugs to tighten in the opposite direction that the wheels roll? Left hand threads just happen to make sense to me on the pass. side only. I had to pound it into my crew that there was a reason why my knock off hubs were theaded opposite on the sprint car.
Pete
__________________
  #6 (permalink)
Old 07-03-2009, 05:21 PM
Biodiesel Guru
All the left hand lug nuts I've ever seen were on the left, or drivers side.....................
__________________
FABMANDELUX.
Don.
  #7 (permalink)
Old 07-03-2009, 07:16 PM
galaxie641 galaxie641 is offline
galaxie641 is gaining momentum as a positive member of FTE.
My '56 F350 has them on the Drivers side.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #8 (permalink)
Old 07-03-2009, 11:37 PM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
yep, i got those stupid left hand ones on my 68 coronet. i think it started as a chrysler thing. i had no idea when i first got it, whent to pull the tire and couldnt brake them loose. i had my longest breaker bar on them pullin as hard as i could, then my old man says "dont ya know yourt goin the wrong way".. i still forget half the time when i'm workin on it...
  #9 (permalink)
Old 07-04-2009, 10:30 AM
fellro86's Avatar
fellro86 fellro86 is online now
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
Some 80's 250's and 350's had them as well. My dad's 84 had them from factory, but the replacement rotors are not.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #10 (permalink)
Old 07-04-2009, 11:54 AM
19704X4F250's Avatar
19704X4F250 19704X4F250 is online now
19704X4F250 has a good reputation on FTE. 19704X4F250 has a good reputation on FTE.
I had a 1941 Oldsmobile and it had left hand threads but I can't remember which side.
__________________
Dan
Ignorance makes you start over!
IF IT IS MADE IN CHINA, YOU DON'T NEED IT!
Torque it down till it breaks off, then back it off 1/4 turn.
  #11 (permalink)
Old 07-05-2009, 12:38 AM
ford2go's Avatar
Did a little more surfing. Apparently, GM had them on some cars (Ponitac among others), through the 60's.
I guess there really was an issue with lug nuts loosening up. Don't know if the LH threads worked or not, but it was one attempt at a solution.
The 'fix' is the conical nuts that they use these days. The tapered part at the end of the nut must jam into the wheel so that the nut won't loosen.
__________________
ford2go (hj)
Have E350 RV
  #12 (permalink)
Old 07-05-2009, 02:30 PM
Chugalug Chugalug is offline
Chugalug is starting off with a positive reputation.
We had a 55 Desoto that had the left hand thread. I don't remember which side it was on.
  #13 (permalink)
Old 07-05-2009, 06:41 PM
rebocardo rebocardo is online now
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
I drove a 1980 F-350 and it had left hand threads (driver's side if I remember correctly).
I remember them on the bigger vans too.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #14 (permalink)
Old 07-06-2009, 04:51 PM
spikedog's Avatar
spikedog spikedog is offline
spikedog is gaining momentum as a positive member of FTE.
Yup, got em on the driver's side of my '82 E-350 dually motorhome. The L is there on the end of the stud, just hard to see with all the paint and rust. I hope I never lose the lug nuts.
__________________
“If a tie is like kissing your sister, losing is like kissing your grandmother with her teeth out.”
- George Brett -
  #15 (permalink)
Old 07-06-2009, 05:17 PM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
I have never run into a left handed wheel stud on the passenger side of a vehicle. I ain't saying they didn't make any, I just never saw any. That would defeat the theory behind it though by putting them on the right side (passenger side) of the vehicle. The theory was, I believe, that the rotation of the wheels could loosen up the lug nuts on the drivers side, so they went with left handed lug nuts.
As for other vehicles, semi-trucks and dump trucks have been doing that for a long time too on their bud wheels. Bud wheels, AKA stud piloted wheels, have left handed studs on the left side. In fact, their duals have 20 lug nuts holding the wheels on. You have a thimble that goes on the stud holding the inner wheel on that has threads on the outside of it for the outer lug nut. The inner thimble is recognized by a 13/16ths square on the end for a 4 point socket. They do have an L or R stamped in the end to know the difference. These were used fairly regularly up until about 10 years ago. You can still get them that way if ordered. The main reason for doing that would be so you can use the same truck rims you already have without having to stock 2 different types of rims. What's fun is changing a tire and someone put a right handed stud in a hub on the left side and you don't know it until you break it off.
As for big trucks, the most common by far is the hub-piloted wheel today. The rim makes contact with the hub and carries the weight at that point. The 8 or 10 wheel studs only have to hold the wheel on. There are some out there that actually put bud studs in a uni-mount hub, there by getting the best of both worlds I guess. Since the hole in the center of the rims are the same, the bud wheels will fit on a uni-mount hub. But don't try putting uni-mount wheels on a bud wheel hub. That won't work.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
Tags
2002 , dodge , f350 , ford , handed , left , lug , nut , replacing , rethread , stud , studs , threading , threads , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
