I try to keep 2-3 extra (especially a left hand thread) in the glove box. That way if the lug gets messed up taking it off or you have to re thread a stud with a nut you can. Or double them up on a stripped lug.
PLUS, if you lose a wheel, if you have 2-3 nuts and can rob one from each remaining wheel you can usually limp home.
__________________ The Year 2009 Anno Domini - May it bring a great year of Revelations to you.
As for other vehicles, semi-trucks and dump trucks have been doing that for a long time too on their bud wheels. Bud wheels, AKA stud piloted wheels, have left handed studs on the left side.
yup, ihc too. left is always on the left unless someone put that hub on the wrong side. or got a left/right junkyard replacement, etc. in 40+ years of wrenching i've never figured out why. i've heard the self-tightening story. never sounded credible. i think they did it as a mechanic's intelligence test, do you notice the L or slash before you snap it off with the impact?
Welcome to FTE Tony! Well, perhaps you right on the intelligence test. I know I learned my lesson after breaking one off.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
I've worked on a '59 f350 and a '60 f350 and they both had reverse threads on the drivers side. First time I had ever heard of such a thing and belive me I broke quit a few studs before realizing what was going on.
__________________
Colin
1959 F-250 Longbed 292 V8. Four on the floor manual. 2wd Styleside
"The truck's a Ford and the tractor's green"
I may be wrong, but I believe my fathers old 84 f250 diesel had left hand nuts on the one side (front and rear). It was the first set of tires I ever changed (I couldn't have been 10 at the time), so it REALLY threw me for a loop.
GM used them on a number of models in the 50"s and 60"s. Had a 54 Buick with them. Also ran into a LH thread on a 300-6 fan nut. And it was on tight!
“The problem with Socialism is that you eventually run out of other people’s money.” Margaret Thatcher
__________________ TRITON V10 - THE BEST KEPT SECRET - (But word is getting out). '08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
Here's my stupid story---bought a 50' International Harvester pick-up back in the 70's. Wanted a spare tire--found a pick-up just like mine in an old-country junk yard. Studs and bolts were all rusted up, so not knowing any better spent 5-6 hours with hammer and chisels busting all the nuts off. Later had to change a tire at home, and finally figured it out.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
