Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 12:16 AM
Timba Timba is offline
Timba is starting off with a positive reputation.
Engine Busted, No Clue
I have a 2000 F150 (this is my first post by the way...my brother turned me on to this site tonight). Supercrew...Lariat...5.4 Triton with 188K miles. Engine is out of truck. Original symptoms...misfiring...loss of power. Computer says misfire on 1 and 5. Shop guys can't tell me what the problem is. #1 plug was covered in oil...porcelain on plug chipped. Tested 3 times with random misfire. Pulled manifolds...valve covers...no obvious problems. Any thoughts?
If replacement...suggestions? Short block...long block? Any suggestions on where I can get a good deal on replacement, if needed. Heard great things about this forum!
  #2 (permalink)
Old 07-03-2009, 12:47 AM
fordmerc fordmerc is offline
fordmerc is starting off with a positive reputation.
Before the engine was pulled, what were the codes pulled? Were the cops tested? What was done to assume the engine was bad?
__________________
1997 4.6 f150 lariat & 2002 4.6 mountaineer
4.10 gears, torsion crank, add-a-leaf, 305/70/16 nitto terra grapplers on 16x10 eagle alloys, white face gauges, trans temp gauge, straight dual exhaust, chrome rear diff cover, steering stabilizer, rancho rs5000 shocks, 15% tint, billit grille, "do it yourself" intake mods and more
  #3 (permalink)
Old 07-03-2009, 12:49 PM
spoogie spoogie is offline
spoogie is starting off with a positive reputation.
www.powertrainproducts.net
Best place ever. My engine came with most sensors, bolts, nick-nacs.
give them a call.
  #4 (permalink)
Old 07-04-2009, 04:53 AM
piston busted
pulled head found chunk of piston missing so any idea's on whats the best way to go?longblock, short, crate,used trucks a 2000 very clean inside and out and where to go to get it
  #5 (permalink)
Old 07-04-2009, 07:33 AM
vze2sgxa vze2sgxa is offline
vze2sgxa is starting off with a positive reputation.
That description sounds like an injector failed and dumped fuel into that cylinder, which if you kept running it, could have caused hydrolock; that'll damage a piston like that. Or it could have been a combination of an injector and COP failure all at once.
__________________
2000 Expedition EB 4X4/5.4 2V, hit 105k on 10 July 09, still goin' strong
  #6 (permalink)
Old 07-04-2009, 10:49 AM
Just depends on you, how deep are your pockets. A pro long block
will pop you about 2,800. you can go cheap or good.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
