How long does it take to fill up the DPF? I am thinking about deleting the DPF on this because I don't want fill it up and have to replace a 3 grand part for nothing. Who makes a good kit to do it?
Thanks,
Nick
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE, RR Boots
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
You shouldn't have to worry about filling up the DPF if the truck is running good and the DPF is working properly. That being said there are kits out there to replace the DPF, but you can't just take the DPF off without reprogramming the ECM. You need to buy a tuner and DPF delete pipe to get the job done right. I highly recommend Spartan but do some research on this site and you will see there are a few options. Good Luck
__________________
2008 F350 CC FX4 6.4 PSD
3.73, 20" factory rubber
S&B CAI, Pro Flo Exhaust, 275 & 310hp Spartan Tunes, T-Rex Billet Grille, Billet Side Vent Inserts, 50 Gal Titan Tank, 100 Gal slip tank/tool box combo
plus keep in mind if you live in Calif it wont pass the visual insp for emissions
__________________
08 job 1 F350 4x4 CC/LB King ranch 35"s 4.10's 60 gal fuel tank
71 Mach 1 with 1990 FI/AOD 5.0 HO motor
96 Bronco XLT 5.8 32's
85 Toyota PU rock krawler with dual cases, detroits
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
Well I think mine might be clogged because when I floor it from the line its a dog for about 2 seconds and I think that the turbos are not getting enough flow right off the line. When I have to smog it I will just throw it back on and I don't care about the warrantee because it does not have one I bought it used with 85,000 miles on it.
__________________
Nick PAA#9
95 F-250 7.3, 6637
Which is no big deal if you plan to restore it to stock prior to any smog testing and warranty work. What is a big deal is whether they are going to do any road side visuals.
__________________
Shaun
Quote:
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
I honestly think your line of thinking is a bit off on this one.
If the DPF were clogged, you would certainly see a trouble code, as the back pressure sensors would detect a problem. I believe there is a light on your instrument panel that is supposed to come on to indicate the DPF needing service.
Also, if the DPF were clogged you wouldn't have the problems you're mentioning now. You'd be losing power at high-boost, high RPM range, as that's when the most exhaust is being forced through the DPF. This is also the point when the back pressure is the greatest, which would really rob you of power if it were truly clogged.
My '08 has 1200 miles on it, and has the exact same lag you do from a stop. I can floor it and the thing just sits there for a couple seconds until it decides to get moving. This is a PITA especially when making a turn with people coming at you...I think I have plenty of time until the darn thing doesn't want to move. Then I panic, hit the pedal harder just as the power comes on and I fishtail...
The engine produces the most soot when it's running rich, which happens when it dumps lots of fuel into the cylinders before the turbos supply the necessary boost to burn the fuel correctly. To avoid that from prematurely clogging the DPF the PCM won't let the injectors supply that much fuel until the boost is there.
It's NORMAL!
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
It's NORMAL!
Well also the main thing behind doing this is the MPG just SUCKS so I am doing this to gain some MPG.
__________________
Nick PAA#9
95 F-250 7.3, 6637
nick. first thins first. your dpf will never fill up. your truck goes into regen mode to clean it out so that it will never fill up. but if u want to do it for gas milage then go for it. u will need the dpf delete pipe and a tuner to reprogram the truck so it doesnt throw codes. several companies offer these pipes and tuners. spartan diesel, sct.. ect..... just make sure u dont drive it with out that tuner. otherwise your trucks sesors will see all the soot going by and keep your truck in constant regen. and u will be getting about 4mpg haha good luck buddy. also your problem doesnt sound like a dpf issue. more like a turbo or injector issue.
__________________
http://www.ford-trucks.com/forums/members/gopedoligist.html
keep it ford
Um..... need 10 characters to post....
Quote:
Originally Posted by 2008 6.4L Diesel Supplement
Filter service/maintenance
Over time a slight amount of ash will build up in the DPF which is not
removed during the regeneration process. The DPF may need to be
removed for ash cleaning at approximately 120,000 miles (193,000 km)
or greater (actual mileage can vary greatly depending upon
engine/vehicle operating conditions) and replaced with a new or
remanufactured (ash cleaned) part. The filter may need to be replaced
at approximately 250,000 miles (400,000 km) depending upon
engine/vehicle operating conditions. In both cases the engine control
system will set a service light to inform you to bring the vehicle
to the dealer for service.
If there are any issues with the oxidation catalyst/DPF system a service
light or will be set by the engine control system to inform
you to bring the vehicle into a dealership for service.
__________________
Tom,
Previous Fords:
2007 F150 Screw 4x4
there is no problem with your truck, until you put an intake or exhaust on there and even then they lag a lil bit. they are right you have to run a tuner when u delete dpf which you will like alot with the increased mpg, power, and it will get rid of the lag too.
I have heard that the lag on takeoff has somthing to do with emissions, and if you get a tune you can get rid of the lag and gain some mileage, not to mention a bunch more power. I haven't tried myself, my PSD is a company truck, not mine personally.
My '09 6.4 has the same hesitation from a stop. I've put it down to turbo lag and the emissions controls. With the Smog goons here in CA, plus getting the Extended Warranty for the power train when I bought the truck, I'll just live with it.
With a 6.4, any visible smoke is enough reason for the CHP to check you out, or Joe Citizen to call the 1-800 smog number to report you.
