Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 11:25 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
Question interstate speed/temp/boost?
went on a trip on I-35 going about 75MPH running about 2400 RPM boosting anywhere from about 4 to 9 psi staying at about 6-7 most the trip is this common? also my tranny temp was steady at 210 degree F, normal? i got 12.7 mpg on the 225 mile round trip had a four wheeler in the bed on the way back. was fighting a side wind of 20-30 mph outside temp of about 80. 1994 f250 stock turbo idi LT265/75R16 tires auto 4x4 supercab crew of 4 stock intake exhaust except muffler delete. whats anyones thoughts on these readings normal? thanks for any input!
__________________
1994 F-250 SuperCab 4x4 A4OD 7.3L Turbo IDI 172,000miles STOCK!! LOOKING 4 BEST UPGRADES?!?!
  #2 (permalink)
Old 07-03-2009, 05:49 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
Everything seems about the same as My 93. Except I get a little better fuel mileage. Around 16-17 MPG.
The 210 tranny temp seems about 10-20 high. Same as the coolant temp? Might want to get a big external tranny cooler?
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #3 (permalink)
Old 07-03-2009, 06:51 PM
GHeTTo JOe's Avatar
that sounds right for not pulling a loaded trailer? coolant temp was below half on normal but cant really trust it needle does not move very smoothly
__________________
  #4 (permalink)
Old 07-04-2009, 01:34 AM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
MPGs are a little on the low side, and trans temp could also be better.
210 is not dangerous, but considering the truck was essentially empty, that is kinda high. Where is your sensor?
Driving my truck like I stole it, I measured 180F peak at the valve body sensor.
I wonder if your torque converter is locking. I also wonder what gearing you have to run RPMs that high with an E4OD transmission.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #5 (permalink)
Old 07-04-2009, 01:47 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Without knowing the OD ratio, I'd say 4.10!
Just did a quick calc. 3.958 = (2400*31.6)/(336.13552*.76)/75
R-gear = (rpm*tiredia)/(336.13552*T-ratio)/MPH
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #6 (permalink)
Old 07-04-2009, 05:49 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
The tire height may be the cause of the somewhat lower mpg. Taller tire without correction is going to show less mileage on the odometer.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #7 (permalink)
Old 07-04-2009, 10:44 AM
JesterPgh's Avatar
JesterPgh JesterPgh is online now
1987 Ford F-250
My Garage
JesterPgh is starting off with a positive reputation.
If the stock tire was originally a 235-85/16, believe it or not, the 265-75/16 is almost identical in "height", and actually, slightly shorter; the first (235-85) converting to 31.7, the second (267-75) converting to 31.6
__________________
Jim
____________________________________
1987 F-250 4x4, 6.9 ATS turbo, 4 spd
1993 Lincoln Mk VIII, coil spring conversion, 4.6l of fun
  #8 (permalink)
Old 07-04-2009, 12:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
With 31" tires a 4.10 gear and an E4OD would cruise at 2400 at 76 MPH.
Wider tires = more wind resistance and more rolling resistance.
More resistance = lower MPG numbers.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
