Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 11:14 PM
john griffin's Avatar
john griffin john griffin is offline
john griffin is starting off with a positive reputation.
Cool Wet cold
Just put new orfice tube and drier on my 1988 F-150, put in r134a, not cooling very good, got new fan-clutch, my compressor is cold and wet so is my drier, the pressure is 45 psi low 250 on hi side, why is compressor sweating and cold.
  #2 (permalink)
Old 07-03-2009, 07:03 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Hit the condenser with the cold spray of a garden hose while watching the pressures.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 07-03-2009, 08:39 AM
Cool
Yep, I know it will go down a lot thats how I get the last bit of freon in, I don't know if it is overcharged or not, temp through vents goes up and down, with the compressor not cycling, got almost 3 # of freon in.
  #4 (permalink)
Old 07-04-2009, 12:20 AM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
It sounds like your evaporator is plugged externally.
Not much heat is being removed from the Evap, so everything after it is soaking up heat. The Suction line from the Evap should be "cool" but not cool enough for the compressor to also be cold and sweaty.
Your refrigerant loop is working as it's supposed to, it's just looking for air to cool. Clean the mouse nest out of the evaporator case and detergent/surfactant (Dawn Dish Soap and water) flush the evaporator. You'll be good to go.
Frickin mice! I've had about 8 systems so far this season that needed a nest cleaned out of the evap case, along with their crap in the evaporator!!
Those repairs pay good money, but they sure are a PITA. The instrument panel often has to come out to expose the evap for cleaning.
I'd rather sell and explain a Black Death compressor failure to a customer.
How do you explain to a customer that his AC system, that makes nice cold air but just not enough of it, needs a ~$500-1200 repair??
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #5 (permalink)
Old 07-04-2009, 08:38 AM
Hey, thanks for the replys, it blows plenty of air and on fresh air I get a lot of water draining out of the evap. I am going to put the gauges back on, now that is has ran a few days and see what it shows, hey thanks need all the help I can get.
  #6 (permalink)
Old 07-05-2009, 10:43 AM
Take your pressure readings with the engine at 1500 rpm, Max AC, High Blower, doors open. Give the system about 5 minutes under those conditions to stabilize.
If you charged 3# of refrigerant into the system, you're overcharged. Your original pressures don't seem to reflect that though, unless the engine was at idle.
__________________
  #7 (permalink)
Old 07-05-2009, 12:20 PM
Thumbs up
OK,101, did what you said ran rpms up to 1500 for about 5 min. pressure went way up 325 hi side, and 55 low side, then the fan clutch kicked in and pulled the pressure down to 275 hi, and 45 low, over charged rite, got it down to 225 hi and 35 low, out side temp was 91, temp on vents was 48 on hi max with the doors closed. I put a new fan clutch on in March but don't remember what brand, it really changes rpms when you hold the engine rpms up does yours? Well I guess it is about all a 22 yr old truck with 437,000 miles can do thanks for your help.
John
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
