Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 11:08 PM
fenix1 fenix1 is offline
fenix1 is starting off with a positive reputation.
Scary front end!
Have a 88' Bronco II 4X4 with a Dana 28 front end. Front tires have been wearing really bad past few months. Figured just needed alignment. On a VA disability pension so money is really tight. Anyways, was walking toward it the other day on a parking lot and and looked at it and i couldn't believe it. No wonder the tires are wearing. They're both leaning INWARD at the top really bad...looks like an upside down V. Never seen tires leaning inward like that. Ya thing maybe LOWER BALL JOINTS?
  #2 (permalink)
Old 07-03-2009, 11:25 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Could be ball joints, could be wheel bearings, could be the camber needs adjustment. Easiest way to tell is jack one side up at a time with the jack under the axle beam and try to move the tire/wheel with your hands both 'front' and 'rear' of tire and 'top' and 'bottom' of tire. If the latter of the two shows more movement, then more than likely it's a ball joint - probably upper, but I personally would replace all of them. The stock parts on these things aren't greaseable and they eventually wear out. Usually, the drag link is the first thing to go, and it's usually the end that connects to the pitman arm on the steering box. I had to completely rebuild the front end on my '86 Ranger I used to own, and a previous owner had already replaced the drag link on my BII.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 07-05-2009, 12:58 AM
rebocardo rebocardo is online now
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Once your lower ball joints go that bad, it will be visible with about 1/4" gap between the rubber and metal. You might want to check the radius arm bushings too.
Jack it up as previously mentioned and if you have a friend to help, one can lie under the vehicle while the other lifts up on the tire with a long pry bar. Ball joint movement will be obvious.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
