Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 10:51 PM
billy150 billy150 is offline
billy150 is starting off with a positive reputation.
Add A/C?????
Just wondering how easy it would be to add a/c to a used 06 XL f-150? Thanks Bill
  #2 (permalink)
Old 07-02-2009, 11:01 PM
Ford Fx4's Avatar
Ford Fx4 Ford Fx4 is offline
Ford Fx4 is gaining momentum as a positive member of FTE.
Most likely a major PITA at minimum.
__________________
2009 F-150 Fx4 SuperCrew 6.5' bed
Luxury Package-Navigation-Moon roof-Heated Leather Captions chairs-20's- Max Trailer tow
  #3 (permalink)
Old 07-02-2009, 11:11 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all
Wow! I thought they all came with a/c!
I know my stripped down XL came with it.
I'd start pounding the pavement at junk yards even maybe go as far as finding a "front-clip". Then move the relevant components and instrumentation over to your rig.
Just keep in mind a front clip of a car doesn't exactly mean the same thing to a p/u truck.
So you may have to explain that to the boneyard.
On Edit: Don't forget to have the donor system vacuumed down...
__________________
-Rich
Chapters / 2004-2010 F150 / 2011 F100 Moderator
****Join the South Carolina Chapter here!!!***
..Or your own state chapter Here
  #4 (permalink)
Old 07-02-2009, 11:50 PM
WhëëlMå1's Avatar
WhëëlMå1 WhëëlMå1 is offline
WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of
Um... I figure you need the special bracket, AC compressor, and all applicable wiring and tubing. I dont think it would be that big of a deal. Oh, you will probably also need a new serpentine belt, as it will be longer with the AC in line.
__________________
Rich
FTE Guidelines
Support American Manufacturing!
"The next time some actor or rock star tells you what to think, tell them to **** off." - Dennis DeYoung
  #5 (permalink)
Old 07-03-2009, 01:47 AM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
also need to get the Inst. Cluster programmed.
the cluster runs all the electronics in the truck.
might be easier to just find a Custom A/C unit. My old 1971 Chevy had a aftermarket A/C unit. looked decent, and blew ice cold.
otherwise, you are probably going to need an entire donor truck. Major PITA IMO
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #6 (permalink)
Old 07-03-2009, 08:00 AM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO is starting off with a positive reputation.
go with the aftermarket....A/C is put in before the engine is at the factory.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
