Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 10:51 PM
99 F-250's Avatar
99 F-250 99 F-250 is offline
99 F-250 is starting off with a positive reputation.
Check engine light
My 99 F-250's coils have been going out and everytime they go out my check engine light does NOT come on but this last time it did. I took it to get checked out at autozone and they said it was the coils. I bought new ones and put them on went back down to autozone to get the codes cleared and they said it was aginst state law. so how do i clear the codes and why did my check egine light come on this time?
Thanks for any help.
__________________
99 F-250 superduty 5.4 with K&N cold air, exhaust.
  #2 (permalink)
Old 07-03-2009, 10:25 AM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
Never heard of that before. (guess I'm a criminal then)
Take it to a local shop and ask them,shouldn't be much $ just to clear codes.
Or for about $60 you can buy a "code reader" and do it yourself.
It is not a "scanner", but will simply read and clear codes.
Then you would always have your own.
  #3 (permalink)
Old 07-03-2009, 07:14 PM
kjf-250 kjf-250 is offline
kjf-250 is starting off with a positive reputation.
Take all the battery cables off for a minute or so an it'll go off
  #4 (permalink)
Old 07-03-2009, 09:19 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
i'd take the batteries off too and try that. Also if the light is on still when hooking up the batteries try driving for a couple of cycles, getting the motor hot and then letting it sit long enough to cool like over night.
A couple of thoses cycles may clear the light as well.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #5 (permalink)
Old 07-05-2009, 02:20 PM
99 F-250's Avatar
Ok thanks i will give that a try.
__________________
  #6 (permalink)
Old 07-05-2009, 07:43 PM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
With things like misfires, the code will clear itself after the issue has been corrected.
  #7 (permalink)
Old 07-05-2009, 08:15 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Take a copy of this to them and tell them that they are not lawers.
http://www.michie.com/colorado/lpext...main-h.htm&cp=
Colorado
toc-indent.gif Colorado Revised Statutes
toc-indent.giftoc-indent.gif Colorado Revised Statutes
toc-indent.giftoc-indent.giftoc-indent.gif TITLE 42 VEHICLES AND TRAFFIC
toc-indent.giftoc-indent.giftoc-indent.giftoc-indent.gif MOTOR VEHICLE REPAIRS
toc-indent.giftoc-indent.giftoc-indent.giftoc-indent.giftoc-indent.gif ARTICLE 9 MOTOR VEHICLE REPAIR ACT
toc-indent.giftoc-indent.giftoc-indent.giftoc-indent.giftoc-indent.giftoc-indent.gif 42-9-111. Prohibited acts.
Go to someone else and have them clear them. If you lived near me I would clear them for you using my Superchips tuner.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #8 (permalink)
Old 07-09-2009, 01:41 AM
99 F-250's Avatar
Ok thank you guys for all your help.
__________________
  #9 (permalink)
Old 07-12-2009, 07:08 PM
99 F-250's Avatar
I'm so lost right now i took my truck to my friends shop and we hooked my truck up to his computer and it said the only thing it was doing was adding 20% more fuel on the left bank. all the coils are new the spark plugs have less than 10,000 miles on them and i pulled them and they look fine. does any one have any ideas on where i should go from here? I'm going to check the o2 sensor and a few other sensor but im not really sure why its doing this.
__________________
  #10 (permalink)
Old 07-13-2009, 10:28 AM
Former Vendor
The computer uses data such as airflow, air temperature, throttle position, rpm, and a couple other inputs to determine how much fuel the engine needs. The value it calculates is always the base reference. For this part to work, it assumes all the sensors needed for this data to be accurate. Most of these sensors will affect both banks fairly equally. So if you have a very different readings between bank#1 and bank#2 then suspect that it is not one of the above listed sensors. The above calculation can be thrown off by vacuum leaks. If the leak is unique to one side of the engine, then that side will show a LTFT on that side to correlate it.
All the above is only one part of how fuel trim is calculated. The other part has to do with the O2 sensors themselves. The O2 sensors act as an override. The computer does its calculations, and the O2 sensor monitors the result. If the result is not what was expected, the computer will then adjust the injector pulse width the required amount to correct it. If the sensors are not accurate, they will trigger corrections that are not valid. The O2 sensors can also be deceived by anything that increases the oxygen content of the exhaust, such as exhaust leaks, vacuum leaks, incomplete combustion, etc.
Tags
2009 , 99 , check , clear , cycle , engine , f150 , f250 , ford , light , superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
