Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 10:39 PM
BMWM1 BMWM1 is offline
2003 Ford F-Super Duty
BMWM1 is starting off with a positive reputation.
Where to mount air horns
Whats the best location to install my new horns?
__________________
  #2 (permalink)
Old 07-03-2009, 12:15 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
2008 Ford F-250
TexasRebel is gaining momentum as a positive member of FTE. TexasRebel is gaining momentum as a positive member of FTE.
1) same place they are mounted on an ambulance frame...
2) underneath the bed on the side without the fuel tank...
3) on the roof!
__________________
2008 F-250 5.4L Reg. 4x2 6-spd 4.10
DIY Factory Upgrades: Installed TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, B&W "Turnoverball"
1977 C-10 Silverado
2002 1500 Silverado (sold )
  #3 (permalink)
Old 07-03-2009, 01:07 AM
Quote:
Originally Posted by TexasRebel View Post
1) same place they are mounted on an ambulance frame... Front somewhere ?
2) underneath the bed on the side without the fuel tank... Sounds the best
3) on the roof!
NO not a option
Thanks for the input
__________________
  #4 (permalink)
Old 07-03-2009, 01:45 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian is gaining momentum as a positive member of FTE. Furian is gaining momentum as a positive member of FTE.
I would mount them next to the spare tire on the outside of the frame.
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
  #5 (permalink)
Old 07-03-2009, 01:48 AM
TexasRebel's Avatar
2008 Ford F-250
why kind of air horns are they? Is there a manifold, or are they independent?
__________________
1977 C-10 Silverado
  #6 (permalink)
Old 07-03-2009, 01:54 AM
Quote:
That far back ? huh...what am I missing? I figured closer to the front would be better ? Maybe not I guess thats why I'm asking.
__________________
  #7 (permalink)
Old 07-03-2009, 01:57 AM
Its a very large air horn I got from the 18 wheeler salvage yard. Im hooking up a separate air system right now
__________________
  #8 (permalink)
Old 07-03-2009, 05:46 AM
Laynlowf250 Laynlowf250 is offline
Laynlowf250 is starting off with a positive reputation.
I'll take some pictures of my setup. It's a horn blaster kit with 4 horns. I have 2 mounted on each side of the cab right under the front. The valve is in the middle of the truck and the tank and comp are mounted to the paasenger frame rail just in front of the rear wheel well.
  #9 (permalink)
Old 07-03-2009, 07:03 AM
Furian's Avatar
Quote:
The horns will be more than loud enough regardless of where you mount them... there's just lots of room at the rear of the truck frame. You'll likely need a large air tank, which can be mounted there as well.
__________________
Andrew
  #10 (permalink)
Old 07-03-2009, 07:58 AM
Comp and Tank Mounted under bed passenger side infront of rear well
Passenger side horns mounted right under front door
Driver side horns mounted right under front door
Best thing about the horns is when you get a group of unsuspecting people and they jump also train tracks and tunnels are great...But that guy sleeping at the traffic light and granny trying to merge on you. One little toot toot demands there attention quick.
  #11 (permalink)
Old 07-03-2009, 10:54 AM
Furian's Avatar
I'm sure that you've seen this video but it's a "blast" to watch!
__________________
Andrew
  #12 (permalink)
Old 07-03-2009, 01:05 PM
NorCalBusa NorCalBusa is offline
NorCalBusa is starting off with a positive reputation.
I like to mount them under the dash- they're louder that way...
  #13 (permalink)
Old 07-03-2009, 01:10 PM
Here's a tip- use a plastic battery box (Walmart/West Marine/Bass Pro) and mount your compressor inside that, then mount the box to the rail. Keeps it clean and it will be much more quiet when it runs.
  #14 (permalink)
Old 07-03-2009, 02:06 PM
conifers4's Avatar
conifers4 conifers4 is offline
conifers4 is starting off with a positive reputation.
Thanks for the pics Laynlow! Is the bracket holding the compressor to the frame a custom piece or is it part of the compressor? I can't tell from the pics.
__________________
2003 6.0 PSD Lund Visor,Billet Grille,Diamond tread toolbox....much more to come
  #15 (permalink)
Old 07-03-2009, 02:44 PM
Part of the comp, which is a viair 450. One of the best comp companies in my opinion.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
