Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 09:46 PM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS is gaining momentum as a positive member of FTE.
BALL JOINTS - My turn - HELPFUL HINTS/LINKS
The squeeking was driving me crazy!!! My X has 69K miles and I knew it was time to change the ball joints. I spent the last two days (15 hours) doing the job... time would have been much shorter if it wasn't for my OCD .
With the right tools, and the internet almost anything can be accomplished if you have the confidence to tackle the job!! .
I did not realize how bad the ball joints actually were. When I did the "test" I could move what wheels what seemed like at least 1/4 inch up & down... way too much play.
Here's some helpful hints and the links to into I used.
1.) Racerguy's thread was what gave me the confidence to do the job.
How to replace your Super Duty Ball Joints - Page 4 - Ford Truck Enthusiasts F
...and yes, I read each and every post.
2.) This write up was the BEST... lots of pics and info.
2004 F250 Ball Joint Replacement
3.) Another "how to"...
TheDieselStop.Com - www.thedieselstop.com
4.) Mercury45 did a write up too...
http://www.angelfire.com/fang/mercury/ball.pdf
5.) SUPERDUTYPSD did a write up worth reading too...
Ball Joint Replacement Write-Up For Ford F250 F350 Superduty
6.) And finally, Guzzle's needle bearing lube site was copied "just in case".
Guzzle's 4x4 Needle Bearing Maintenance Web Page
7.) Here's where I got the knuckle seal driver (a decent price-$60) It's steel and it worked like a charm.
OTC 6695 Vacuum Seal Installer OTC6695
8.) Some good answers to questions that reinforced info from other sites...
Tight Ball Joints? - Diesel Forum - The Diesel Stop.com
I got my "rental" tools from Advance Auto. The Ball Joint kit is the heavy duty type with a retail value of $169... it had all the parts needed... it was extra-heavy duty. I got the 2 / 3 Clawed puller too... I used the 3 inch and 2 claws for the tie-rod ends and the 3 clawed 6 inch parts to pull the hubs. GET THIS... without it, I know it would have been a itch to get them off.
To pound off the knuckle I went to Autozone and got the #27021 Pitman Arm Puller. It was wide enough and took the punishment of my 8 pound BFH like a trooper. This tool was a "free rental" too.
I got my Moog greaseable Ball joints here:
Powerstrokeshop.com
The kit does not include the autohub O-rings so I went to my local FoMoGuy and got them for 12 bucks.
I went to Sears and got the 1 1/8 socket for the upper and got the 33mm socket for the lower nut at Autozone... BTW... the Moogs upper and lower nuts are both 33mm.
While I was at Sears I picked up their biggest 1/2 inch drive breaker bar and their best snap-ring plyers. (both were around 26 bucks each).
You can never have enough tools in the tool cabinet!!!
Of course... I have a big air-compressor and air tools (a must to use the ball-joint press.)
So... right now I am basking in an overwhelming glow of self accomplishment... the most important thing was I saved at least one travel hockey (Mite A / son Bryant) season's fees doing it myself.
__________________
BOB Spelled backwards is BOB.
2005 EXCURSION--Eddie Bauer--4x4--V-10
Dale Jarrett FORD / NASCAR Special Edition
  #2 (permalink)
Old 07-02-2009, 10:23 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is online now
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
Thanks
Great thread! Good job combining all the useful info and links into one post! Reps sent!
  #3 (permalink)
Old 07-03-2009, 08:57 AM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 is starting off with a positive reputation.
Good job. Feels good doesn't it? How did you drive the new seals in, did you make the 'custom' tool from a 4" pipe flange? It works well.
__________________
2000 Excursion Limited PSD- DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N Filtercharger, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, 315/75/16's
  #4 (permalink)
Old 07-03-2009, 09:20 PM
71-4R3SONS's Avatar
Quote:
Yep... It feels grrreat!
I was going to make the driver... but during my "research" for the job I read that a couple of guys who made the seal driver had to fabricate their home made driver... I felt 60 bucks was well worth it.
__________________
  #5 (permalink)
Old 07-13-2009, 12:35 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
I made the special tool and it worked like a charm!
Just did mine this past weekend. 15 hours to do the job, plus replace both tie rods and drag links. It's the largest job I've tackled, but not the most difficult. I would definitely set aside a couple of days (unless you've done it before or are just that good) so that you don't feel rushed. It is not a quick (or easy) task to go back in to do something you forgot. Not to mention all of the seals to make sure your ESOF system continues to work (if you have it).
It still has a little bit of play in the center, but expect that to be from the steering box (the redhead gearbox wasn't in the budget this time).
With all new joints, it drives SO much better! It pretty much eliminated the wander and almost all of the slop in the steering.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #6 (permalink)
Old 07-16-2009, 04:59 PM
kitebuz kitebuz is offline
kitebuz is starting off with a positive reputation.
You should feel great about doing it yourself! I am getting hit up for $925 to have the local Ford dealership do my front upper & lowers & seals. I don't have the time to even think about doing it myself right now, but wish I did. Nicely done.
  #7 (permalink)
Old 07-16-2009, 11:28 PM
Pocketrocketz1 Pocketrocketz1 is offline
Pocketrocketz1 is starting off with a positive reputation.
Felt good getting it done myself...it was nerve racking putting it all back together....i put the dust cover on the wrong way three times on the first side, but you better believe i won't make that mistake again......what a relief when i was done and had no extra parts.
the only issue i had was loosing the nut the held the tie rod on....my air wrench pulled that sucker off so fast that it went zipping on to oblivian and luckily my buddy let me do the job at his body shop on his lift and he just so happened to have a wrecked F250 in the lot that i was able to grab the nut from on Sat night when i knew i would have to wait till mon. to get another one.
  #8 (permalink)
Old 07-17-2009, 09:16 AM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.
Question, how do you "test" to see if your ball joints are bad? I had the front end lifted on jack stands to install my new Rancho Steering Stabilizer and tried to move the front tires up and down and I did not experience any play at all.
__________________
Rob
2001 Excursion
4x4 V10
  #9 (permalink)
Old 07-17-2009, 09:20 AM
That's how. Same as wheel bearings but it helps to have a second set of eyes to isolate the movement. Sounds like you're in good shape.
__________________
  #10 (permalink)
Old 07-17-2009, 09:34 AM
rlh68050's Avatar
Yes, thanks. I really put some muscle in trying to get some movement, but there was none.
__________________
Rob
2001 Excursion
4x4 V10
  #11 (permalink)
Old 07-17-2009, 09:35 AM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
This is a great write up.If anyone would like to repair their ball joints we do carry the Moogs and a very good alternative.I'd be happy to help answer any questions you may have.
Here's a link to the Ford Excursion ones on our site.
Ford Excursion Ball Joints
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
  #12 (permalink)
Old 07-17-2009, 10:38 AM
71-4R3SONS's Avatar
Quote:
Thanks!
"An ounce of prevention is worth a pound of cure"
Before I disassembled the rotor/hub/knuckle I took a quick pic of it and printed a 8 x 10 on the printer and taped it to the fender...
My best piece of advice... Don't rush yourself.
__________________
  #13 (permalink)
Old 07-17-2009, 11:57 AM
brian42's Avatar
Thanks!
I set everything besides itself, but didn't do the picture trick. Combine that with rushing to finish at the end and I had to take my hub off 2 extra times (once to put the dust shield on and another to put the dust shield on correctly ).
I got my ball joints from http://www.rockauto.com/. They were a great price (I think they were the least expensive) and shipping was like $7. I highly recommend them.
I got everything else from a local Ford dealership (they are not near me, but give me a discount because I'm in the military...and buy a lot of parts). I walked in with my list and asked what they could do for me. Between the amount of stuff I was buying and my military affiliation, they were pretty close to fleet price on everything. Take into account the shipping for some of the bigger stuff and I saved a TON of money.
Just throwing that out there. Sometimes it's worth the drive to find a friendly parts counter guy...
__________________
THE MOOSE
  #14 (permalink)
Old 07-20-2009, 10:50 PM
71-4R3SONS's Avatar
Hey Jay... read above!
__________________
  #15 (permalink)
Old 07-31-2009, 07:45 AM
Ex Factor's Avatar
Ex Factor Ex Factor is offline
Ex Factor is starting off with a positive reputation.
I've got the "squeeks". 80,000 on my '04 Ex.
I did'nt yet have time to look thru all the threads. But can you guys ball park, what parts/special tools might cost vs. what I should expect a good shop to charge?
thnks!
Tags
2004 , 3304 , 8c3z , 99 , ball , balljoint , bottem , depot , diesle , f250 , ford , home , joint , remove , replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
