Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 09:19 PM
abe's Avatar
abe abe is offline
1953 Ford F-100
abe is starting off with a positive reputation.
tips on rebuilding master cylinder
My master cylinder was leaking at the boot at the plunger end. I bought a rebuild kit from Job Lot. Took the master cylinder off tonight. Took it apart. The cylinder bore looks OK on the inside. No sign of pitting that I can see.
I read the brief shop manual instructions. Any other tips or advice, for this my first MC rebuild attempt.
Thanks!
__________________
abe
'54 F-100
bought from Grandpa in 1977 for $200
  #2 (permalink)
Old 07-02-2009, 10:30 PM
gdgerland gdgerland is online now
gdgerland is starting off with a positive reputation.
Abe, if the only problem was the leak at the plunger, the cylinder is probably OK. It would still be a good idea to hone the cylinder anyway to make sure it is not egg shaped and to break off any glaze on the inside. Be sure that you check for wear in the plunger shaft. Clean the shaft with a fine grit sandpaper. Work your sandpaper around the shaft of the plunger, not length wise. This will prevent linear scratches on the rod that will allow fluid to leak through the shaft seal (I'm assuming your master cyl. has a shaft seal). If the shaft is worn too badly, it may need to be replaced. If your cyl. has no shaft seal, then don't worry about the shaft. Make sure everything is cleaned and lubricate all surfaces and seals prior to assembly with brake fluid. You can bench bleed the master cylinder prior to installation by filling it with fluid and allowing the fluid to drip out the outlet ports until all the air is out of it. This will make the system easy to bleed. Hope this helps.
Gil
__________________
1950 F-1, Flathead V-8
1950 F-1, Flathead I-6
1950 F-2, Flathead I-6
1980 F-150 S/B S/S
2001 Yamaha V- Star, 1100
  #3 (permalink)
Old 07-03-2009, 02:38 AM
Julies Cool F1's Avatar
Julies Cool F1 Julies Cool F1 is online now
Posting Princess
1951 Ford F-100
Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE.
The rebuilding must be done under absolutely clean conditions. I did my honing and sanded off any burrs with 400 wet/dry, then cleaned the entire cylinder and all metal parts in clean diesel fuel. Then I washed them with Dawn dish soap and water, towel dried them, blew it ou twith compressed air, and gave the inside a light coat of NEW brake fluid to prevent flash rust. Perform the rebuild in a CLEAN metal pan, and only use NEW CLEAN brake fluid to lubricate surfaces an drubber parts during assembly.
Clean Clean Clean!
__________________
Best wishes
Julie!
  #4 (permalink)
Old 07-03-2009, 11:00 AM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
1953 Ford F-750
wmjoe1953 is gaining momentum as a positive member of FTE.
I'm gonna second both Gil, and Julie. Keep it clean. Run a hone through it. If it's a ball hone, start your drill before inserting it into the cylinder bore. When we hone cylinders at work, we use warm soapy water, then spray some wd-40 in it to prevent the flash rust Julie's talking about. Then, we clean the cylinders out with brake clean and compressed air prior to reassembly to make sure they are free of any contaminents, uncluding the wd-40. You can also, to make sure it's good and clean, boil the master cylinder. Put it in a pot that will hold it, and boil it in ordinary water. The aggitation of the water, and the heat, will clean any crap off it you can't see. Roll it around every so often in the water, and you should put it in like a steamer tray to keep it off the pan bottom. I would actually boil it AFTER honing it, to remove anything you may have missed. Then, proceed with reassembly. Make sure to use only clean brake fluid from a new container. Poor some in a small dish, and let everything but the end boot sit in it while you rassemble the cylinder. DON'T FORGET THE SNAP RING, and make sure it's good, or replace it. I've seen people forget the snap ring and get the plunger cocked in enough to hold it in place, and wonder why it keeps coming apart. Fill it up. Now, these old units don't have to actually be bench bled, because it's a single line out, and no proportioning valves. It WILL make bleeding it a lot faster once installed though. Ever notice how on these old trucks, you can poor in fluid and just pump the pedal 'til it gets hard? That's because it's a single port system, and has a weak check valve, and no proportioning valve. Go to it, and let us know.
__________________
Check out my gallery
If Ford trucks are an addiction, then this must be the support group.
More pics of the Big Job can be seen here:
http://s248.photobucket.com/albums/g.../1954%20F-800/
  #5 (permalink)
Old 07-03-2009, 10:23 PM
abe's Avatar
abe abe is offline
1953 Ford F-100
One guy who looked at it thought the cylinder bore looked pretty good. He told me to clean it up with steel wool or fine 400 grit paper. I did that and once I cleaned it up it looked worse. Some "unsmoothness" in the bore, not exactly what I would call pitting or grooves but not smooth when I run my finger over it. Took it to the garage that does a lot of work on my truck and he said it should be honed, so I ran it up to a guy that rebuilds a lot of engines and does machine work but by 12:30 today he was closed and tomorrow is the 4th and then Sunday so I won't be able to get it honed by at least Monday.... And my wife still has stuff in our garage from the yard sale she had last weekend so the truck is sitting in the driveway!
Oh well! Happy Fourth of July!!
__________________
abe
'54 F-100
  #6 (permalink)
Old 07-04-2009, 12:39 AM
gearhead1952's Avatar
gearhead1952 gearhead1952 is offline
gearhead1952 is starting off with a positive reputation.
You can buy a brake cylinder hone to fit your drill from napa and most auto parts stores. Cheaper than having someone else do it then you will have one for next time.
  #7 (permalink)
Old 07-04-2009, 10:47 AM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
julie, julie, julie--- dawn soap?? what will madge say???????
__________________
42 1.5 ton marmon herrington all wheel drive
  #8 (permalink)
Old 07-04-2009, 12:19 PM
Posting Princess
1951 Ford F-100
Quote:
I know, what a traitor - shhh!
Dawn is pretty amazing stuff when talking about cutting grease on parts (and your hands). I haven't found anything else (soap wise) that does that!
__________________
Best wishes
Julie!
Tags
cylinder , f150 , ford , kit , master , rebuild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
