C6 torque converter lockup - Ford Truck Enthusiasts Forums
Old 08-07-2001, 11:52 PM
farmpaw farmpaw is offline
farmpaw is starting off with a positive reputation.
I have an 81 F250 with 400 against a freshly rebuilt C6 with a "heavy duty" (whatever that means) converter. I didn't notice before the rebuild whether it locked up or not but now there doesn't seem to be a torque converter lock up. Does the vintage C6 converter lockup? At what speed should it lockup if it does?Is a lockup converter available?
Old 08-11-2001, 08:40 PM
f350brocno f350brocno is offline
f350brocno is starting off with a positive reputation.
The C-6 never had a lockup converter from the factory. The new revised C-6 is the E40D. They actually share many parts. The E40D has the lock up converter, overdrive(4 speeds), and computer control going for it. The old C-6 only has dependability going for it :^)
John
PS the new 4R100 is the revised E40D
Old 08-12-2001, 05:19 PM
Thanks for the info, f350bronco. I was afraid that there was no help for the old box and you confirmed it. Rats!
farmpaw
Old 08-12-2001, 07:39 PM
orangeford's Avatar
orangeford orangeford is offline
orangeford is starting off with a positive reputation.
Torque Converter and Rear Main Seal Questions jhl3 1999 - 2003 7.3L Power Stroke Diesel 7 02-11-2017 10:23 AM
Torque converter lock up question Ron94150 1999 to 2016 Super Duty 2 11-20-2016 09:56 PM
Lock-up converter function - AOD rivermobster Clutch, Transmission, Differential, Axle & Transfer Case 12 12-05-2015 01:12 PM
Splining a torque converter Willz74 1987 - 1996 F150 & Larger F-Series Trucks 3 11-20-2015 10:29 PM
Is The Torque Converter Lockup Mod Worth It? brian42 1999 - 2003 7.3L Power Stroke Diesel 7 05-01-2015 12:43 AM
Tags
auto, c6, clutch, convert, converter, converters, ford, lock, locking, lockup, non, nonlockup, torque, transmision, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
