Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 08:27 PM
nikwave nikwave is offline
nikwave is starting off with a positive reputation.
screw-in oil galley plugs
i just bought a kit of srew-in plugs and i need to extract the old press in plugs.i guess they should come back out ,not in,but how do you grab them?they also have a 4 notch mark on the exit hole like a safety thing.any advice would be appreciated!
__________________
1972 f250 4x4 ,390 .030 over,np205,np435 4 speed,dana 44/60,35'' bfg m/t.
More info in my Gallery
1997 f350 4x4,7.3 powerstroke,5 speed,south bend con-o,dieselsite coolant filter,amsoil by pass oil filter..
  #2 (permalink)
Old 07-03-2009, 08:20 AM
Argess Argess is offline
Argess is starting off with a positive reputation.
I drill a small (1/16") hole through the plug, then use a sheet-metal screw on the end of a slide hammer to remove them. You might be able to drill a bigger hole and pry them out with a sharpened screwdriver.
Not sure what you mean by "notches" unless the cast iron around the plugs was "staked" to make sure they didn't come out.
Seems to be the thread for your new plugs is a pipe thread (tapered), so you have to stop threading every so often and check the fit of your new plug. Otherwise, it may thread in too far, or not far enough.
  #3 (permalink)
Old 07-03-2009, 01:39 PM
thanks for the advice!
__________________
Tags
360 , ford , galley , location , oil , plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
