Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 07:59 PM
scottf250us scottf250us is offline
scottf250us is starting off with a positive reputation.
1/2 ton dana 44 to 3/4 ton dana 44 parts interchange???
Will the gears or carrier from a 1/2 ton 44 fit a 3/4 ton 44? Both r ford hp axles
  #2 (permalink)
Old 07-03-2009, 05:28 AM
1969Highboy 1969Highboy is offline
1969 Ford F-250
1969Highboy is starting off with a positive reputation.
Quote:
All the internals should match right up however the U-joint yoke may be different, but i dont think you have to worry about that. The only difference between the 1/2 ton and 3/4 ton is the 3/4 ton is built up stronger on the outside.
  #3 (permalink)
Old 07-03-2009, 06:58 AM
thanks for the info. I can get my weekend project done now
  #4 (permalink)
Old 07-03-2009, 09:45 PM
Stickz Stickz is offline
2000 Ford F-350
Stickz is starting off with a positive reputation.
Yes they will work fine (the HP uses reverse cut gears, the carrier will work for hp or lp). Keep in mind there are 2 different size carriers tho... 3.73 and down... and 3.92 and up
  #5 (permalink)
Old 07-05-2009, 10:49 PM
SoupCan™'s Avatar
SoupCan™ SoupCan™ is offline
SoupCan™ is starting off with a positive reputation.
a related question...what parts are compatable to convert my 78 hp d44 5 lug to 8 lug? thanks
Rich
  #6 (permalink)
Old 07-06-2009, 06:20 PM
Quote:
Rich
I think u will need everything from the spindles out. and any 8 lug dana 44 will work or 8 lug chevy 10 bolt. just what I've been told so u might want to double check
  #7 (permalink)
Old 07-06-2009, 09:39 PM
SoupCan™'s Avatar
thanks alot im keeping my eye open for a 8 lug d44
Rich
  #8 (permalink)
Old 07-08-2009, 11:03 PM
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is starting off with a positive reputation.
Everything from the brake calipers out will fit. Also the dana 44 3/4 ton has thicker tubes than 1/2 ton dana 44. Been a long time since I converted my 5 lug to 8 lug but remember something with the stub shafts on the snap ring grooves being different if this is a issue for you. Be sure to take a measurement on the stub shaft. I still have this axle assembly on stand by for light weight vehicle. Switched to dana 60 got tired of busting ring and pinion and carriers once I went to big block world and hrspwr. hope this helps and good luck.
  #9 (permalink)
Old 07-15-2009, 07:01 AM
Bender99's Avatar
Bender99 Bender99 is offline
1991 Ford F-150
Bender99 is starting off with a positive reputation.
I'm pretty sure the nuckles are the same but i know for sure,the spindles and out are different besides the lockouts. So caliper bracket (for dual piston calipers) spindel, bearings, (roter of coarse) dual piston calipers, outer axle shafts are 3/4 of an inch longer because of the spindle and roter so you need to get those from an f250. lockouts will work. Carrier will work form any d44
__________________
91 Shortbox F-150, 302, ZF 5 speed, Dana 44HD SAS, Dana 60 rear, 8'' Suspension Lift and 38'' TSL's.
Mustang lx, 2.3, 5 speed. Nothing cool except gas mileage!
  #10 (permalink)
Old 07-15-2009, 07:14 AM
teds74ford teds74ford is online now
teds74ford is gaining momentum as a positive member of FTE. teds74ford is gaining momentum as a positive member of FTE.
When I put 8 lugs on my 44, I used everything outside of the knuckles-caliper brackets, spindles, hubs and brakes. The lockout is the same and the stubs are the same. As far as the half ton 44 being weaker, not necessarily so. It depends on what year/model. Here's a website which will give you loads of D44 info:
http://77cj.littlekeylime.com/Dana44.htm
  #11 (permalink)
Old 07-15-2009, 09:09 PM
scottfreeman's Avatar
scottfreeman scottfreeman is offline
scottfreeman is starting off with a positive reputation.
knuckles out
I used the F250 knuckles to do mine, I got a flat top knuckle on the passengers side for my crossover steering conversion. The inner axles are different lengths between the F100 and F250 D44s. The F250 knuckles don't turn as sharp as the F100s do.
__________________
"Its not what You know, but Who you know...."
Tags
10 , 44 , bolt , bracket , caliper , convert , d44 , dana , difference , ford , fr , hp , lug , parts , spindle , thing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
