Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 06:45 PM
fordf350crazy fordf350crazy is offline
fordf350crazy is starting off with a positive reputation.
Upgraded my early 99! Not what I expected...
Well I ended up taking the plunge and upgraded the turbo to a 4 inch ported compressor housing with the 4 inch compressor wheel and 1.0 AR exhaust housing, and got a DP Tuner. It is a lot smoother at idle, and it runs stronger but the turbo does not spool up until around 2,000 RPMS and I am getting a lot of black smoke on all tunes. I got the 40tow, 60tow and 80econ. Would an adrenaline pump help cure the smoke issue as well as helping the turbo spool sooner? I am concerened when I tow my 17,000 pound trailer that I will be struggling to get the turbo to wind up. Am I stuck having to buy bigger injectors as well as a bigger HPOP now?
__________________
Early 1999 F350 PSD: CC, longbed, 4X4. 6 spd. Mods: DP Tuner 40tow/60tow/80econ, Pilar Gauges, 6637 Air Filter, 4 inch exhaust, Late 99-03 upgraded turbo setup with an ATS 1.0 AR exhaust housing, EBPV and AIH delete, 6.0 IC, Adrenaline HPOP
  #2 (permalink)
Old 07-02-2009, 06:53 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD PETE'S_6.0PSD is offline
electric chair --->
2005 Ford F-350
PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE.
black smoke indicates that you have a lot of fuel, and your turbo is not spuling fast enough, maybe upgrading to a bigger housing was a mistake.. whet turbo did you install ?
stock 99.5?
BTW if i were you i would check the install once again, cause you might just have boost leak too, the back of the turbo, which is a common problem.
and dont waist you money on adrenaline for sure...
take flashlight and look for soot marks somwhere around up pipes, and back of the turbo.
__________________
2005 F350 KR dually
SCT X3 with Spartan tunes,Magnaflow SS duals with 5" AFE tips.Headstuds in the box. Where did the EGR go? It was there yesterday
2002 VW Jetta TDI stock - 53.3mpg
  #3 (permalink)
dpwilson's Avatar
dpwilson dpwilson is offline
dpwilson is gaining momentum as a positive member of FTE. dpwilson is gaining momentum as a positive member of FTE.
Bigger injectors would come hand in hand with higher EGT's. If you thought the smoke was bad now, that turbo with bigger injectors will fog for mesquitos in two seperate counties at one time. Forgot to mention your clutch would be quivering in it's pressure plate. Sorry man, all in fun.
If you're looking for suggestions I would suggest a bigger truck or smaller trailer. You're gonna sink alot of money into a truck that shouldn't pull that load.
__________________
Derek
Early 99 6spd: Valair ceramic/kevlar clutch, DI intercooler, 6637 filter, exhaust brake, Isspro gauges, DP tuner no start, stock, 40 tow, 60 tow, 80 econo and 120 race, 5" exhaust, 2.5 in leveling kit with 285/75/16.
  #4 (permalink)
Old 07-02-2009, 06:56 PM
How can I check for boost leaks?
__________________
  #5 (permalink)
Old 07-02-2009, 06:59 PM
Quote:
stock 99.5?
Ron's turbo service took a 2003 turbo and put a bigger compressor housing and bigger exhaust housing on it. I liked the way my early 99 turbo spooled up quickly.
__________________
  #6 (permalink)
Old 07-02-2009, 07:27 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Check for and eliminate all sources of exhaust and/or boost leaks before considering anything more.
I think with your setup you should be able to spool up pretty quickly if everything is tight.
But you do have to give it a little time to spool.
If everything is tight, with that trailer on there it will be a very nice setup, IMO.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #7 (permalink)
Old 07-02-2009, 07:34 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
2001 Ford F-250
jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE.
I have that same setup and no smoke problem. I would definitely check for boost leaks before buying anything else.
__________________
Jeffrey
2001 Ford F-250 Lariat CC SB 4x4 7.3 Powerstroke
Dipricol Gauges For Sale:
http://www.ford-trucks.com/forums/89...ure-gauge.html
  #8 (permalink)
Old 07-02-2009, 07:40 PM
I think it might be the driver side up pipe. I can twist the pipe. Would one leaking up pipe make that much difference in boost?
__________________
  #9 (permalink)
Old 07-02-2009, 07:43 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a good reputation on FTE. strokersace has a good reputation on FTE. strokersace has a good reputation on FTE.
Check the new intake runners too cause if they didn't get sealed properly then you could be loosing boost there. Very hard to find those though cause you don't have the soot like on the exhaust side. Check all clamps and boots to make sure nothing's loose too.
__________________
02 F350 CC Dually 4x4 118K; Forged rods; headstuds; Tymar; coolant filter; 200 Amp alt; AIH Delete; Prepump/tank mods; 5" exhaust; IDM-140; x-monitor; Leveling kit; 06 leather seats f/r; 07 upfitters; custom dash; KR boards; rhinoed
95 F350 CC Dually psd auto; Tymar Intake; 3" DP; Straight piped; Western Hauler - soon to be worked over...
96 F350 CC Dually psd auto; Stock - FOR SALE!!!
  #10 (permalink)
Old 07-02-2009, 07:55 PM
cjfarm11 cjfarm11 is offline
cjfarm11 is starting off with a positive reputation.
Fordf350 did you install the bellowed up pipes? I would highly recommend doing so. I just resently updated mine as well and im running the stock compressor housing with a 1.0 exhaust housing and compared to stock 99 it takes only a fraction of a second longer to spool. But power is good and continues to pull throughtout the rpm range.
__________________
Curtsey!
Early 99 F-350 Lariat 4DR, LB, DP Tuner, 17* HPOP, 4" Magnaflow exhaust, 6637 Mod, Late Model Turbo with 1.0 Exhaust housing, Bellowed Up-pipes, HPX, CCV Mod, OBA, Shift Kit and Billet Convertor, 6.0 Tranny Cooler.
  #11 (permalink)
Old 07-02-2009, 08:08 PM
papadelogan's Avatar
papadelogan papadelogan is offline
of Brent's moral decline
papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE.
Why would you say this? I have an Adrenaline pump on my truck with stock turbo & injectors. She pulls more consistently through the RPM range and smoke is down, both of which I would say are benefits. Plus, when I go to single shots & a slightly bigger turbo, I'll have the volume from my HPOP to maintain higher pressures and take better advantage of the added fuel. I know my tuning will need to be changed but I plan on going to single-shots anyway. I don't think the Adrenaline is the solution to the issue he's having, but it is a very good product. So again... I'm curious why you say this.
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;Adrenaline HPOP;UnderCover tonneau cover;05 headlights
  #12 (permalink)
Old 07-02-2009, 08:11 PM
Jesus spoke a lot
1999 Ford F-550
Quote:
Throwing an Adrenaline pump at this problem to cure smoke would be a waste of money - the smoke would not go away until the real cause is found and fixed.
The fact that one of the up-pipes is loose enough to twist in your hand is proof enough of needing to address boost problems before proceeding to anything else.
__________________
Dan
God and Dog
  #13 (permalink)
Old 07-02-2009, 08:13 PM
I think he was meaning, "Don't go spending your money on something else when you don't know that is the issue at hand." At least that's the way I took it. Don't waste your money on something you probably don't need right now.
__________________
  #14 (permalink)
Old 07-02-2009, 08:14 PM
Jesus spoke a lot
1999 Ford F-550
Quote:
ABSOLUTELY!
For good boost, you have to have good drive pressure and the best drive pressure is generated by an exhaust that is close to being hermetically sealed.
FWIW, I have a stock setup with the bellowed up-pipes and I can make the smoke bellow out if I lug the engine, but as soon as the turbo hits, the smoke completely dissappears, even on the 80hp tune.
Truck takes off like a scalded dog too.
__________________
Dan
God and Dog
  #15 (permalink)
Old 07-02-2009, 08:17 PM
Good points to look for. I did not know that a small leak like that would limit boost that much!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
