Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 07-13-2009, 03:21 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
The only time I've ever gone over 1000° is pulling a loaded horse trailer up a grade and letting the cruise try to hold at 65mph... got up to 1050° when I tapped the brake, held the speed to 62 or something and EGT's went way down. Sure do love these baby injectors of mine
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #62 (permalink)
Old 07-13-2009, 03:37 PM
fordf350crazy fordf350crazy is offline
fordf350crazy is starting off with a positive reputation.
Quote:
Do you have an early 99 with stock injectors? I assume that your sensor is post turbo??? Mine is pre turbo and I am hitting 1300 pretty easily.
__________________
Early 1999 F350 PSD: CC, longbed, 4X4. 6 spd. Mods: DP Tuner 40tow/60tow/80econ, Pilar Gauges, 6637 Air Filter, 4 inch exhaust, Late 99-03 upgraded turbo setup with an ATS 1.0 AR exhaust housing, EBPV and AIH delete, 6.0 IC, Adrenaline HPOP
  #63 (permalink)
Old 07-13-2009, 03:52 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is gaining momentum as a positive member of FTE. CSIPSD is gaining momentum as a positive member of FTE.
Quote:
He does, and his probe is in the manifold...
You have drive pressure leaks. Fix them and you will be fine.
__________________
01 F-250 SC PSD,170k,17 Isspro Gauges,AFE-2,CCV Mod,IAH delete,map reg,Modded H2e,6.0IC,GTS Hybrids,Studs, Forged Rods,Water injection,Swamps Tunes,4" duals,Aero,6" tip's,100 axl tank,4" Revtek lift,37" TOYO MT's 467hp-1066tq
Isspro Performax Gauges
  #64 (permalink)
Old 07-13-2009, 04:03 PM
1999 Ford F-250
Joe is right- early 99, stock turbo and sticks, 6637 in and 4" duals out, probe in the up-pipe where it should be. I can pull 25 psi boost all day long no problems, I've buried the needle on my 30psi gauge a few times unintentionally (even with defueling from overboost). I've even got a small up-pipe leak but it always goes away when the motor is warm.
__________________
Chase
PAA Member #2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
