Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 07-12-2009, 05:52 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is online now
schlepprock250 is gaining momentum as a positive member of FTE.
I have to agree with Kwik on this one,if you can "twist" one up-pipe,IMHO,that will definately take some exhaust drive pressure from the turbo.I have a 99.5,I know thats a different set up,but when I went with the bellowed uppipes,I didnt get one side tight(where it connects to the babies butt I guess is what you call it),I could only make about 18.lbs of boost.Now givin,Im not an expert,just my.02 worth.
Phil
__________________
Phil '99.5 F-250 SuperDuty 4x4 CrewCab/7.3 PowerStroke Magnaflow4"TurboBack SS Exhaust 5"Tip DP-Tuner:Stock,High Idle,Lope Idle,60Tow, 80Econo,120Race AIH Delete OverBoost Annihilator AutoMeter UltraLite Series Gauges Boost/Trans/Pyro BTS ValveBody Spicer/Custom Driveline ATS Housing HPX Crossover DIY Tymar 6637 6.0 Trans.cooler Bellowed Up Pipes PAA Member # 34
  #47 (permalink)
Old 07-12-2009, 06:28 PM
fordf350crazy fordf350crazy is offline
fordf350crazy is starting off with a positive reputation.
I think I have. I cant twist it anymore. Would a leaky up pipe cause that much heat and smoke?
__________________
Early 1999 F350 PSD: CC, longbed, 4X4. 6 spd. Mods: DP Tuner 40tow/60tow/80econ, Pilar Gauges, 6637 Air Filter, 4 inch exhaust, Late 99-03 upgraded turbo setup with an ATS 1.0 AR exhaust housing, EBPV and AIH delete, 6.0 IC, Adrenaline HPOP
  #48 (permalink)
Old 07-12-2009, 06:36 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD PETE'S_6.0PSD is offline
electric chair --->
2005 Ford F-350
PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE. PETE'S_6.0PSD has a great reputation on FTE.
yes it would . so would a leaky IC boot, or cracked one . inspect everything, black smoke indicates that you still have a lot of boost leak or that turbo you just installed is shot....
__________________
2005 F350 KR dually
SCT X3 with Spartan tunes,Magnaflow SS duals with 5" AFE tips.Headstuds in the box. Where did the EGR go? It was there yesterday
2002 VW Jetta TDI stock - 53.3mpg
  #49 (permalink)
Old 07-12-2009, 07:01 PM
But, would it boost up to 20 lbs if it was leaking?
__________________
  #50 (permalink)
Old 07-12-2009, 11:21 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
It should boost to at least 25 with no leaks... you gots a leak somewhere mang.
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #51 (permalink)
Old 07-13-2009, 12:52 AM
Bird Dog's Avatar
Bird Dog Bird Dog is offline
Bird Dog is starting off with a positive reputation.
Quote:
Originally Posted by superduty4x4 View Post
FYI, you can get a modded 17° HPOP from Joey at Terminator Engineering for about 1/2 of what the Adrenaline costs.
An Adrenaline is only $469. Terminators are $2095. I don't get where you come up with 1/2 the price? Is there somthing I'm missing?
__________________
Rhett
Early 99 F350 Lariat 4x4 CCLB 7.3 PSD,DP Tuner F5 switch,ITP Overboost Annihilator,Power Braker, Triple Gauges,kwikfilter,4"Turbo Back Exhaust, Muffler Delete,Transgo Shift Kit,Air Lift,CCV Mod, Prodigy Trailer Brake,Skyjacker 7000's,2 Interstate Megatron-Plus Batteries,19.5" Visions with 265/70's load range G Yokohama TY 303.
If it don't blow black take it back!!
  #52 (permalink)
Old 07-13-2009, 01:16 AM
Az.scarecrow's Avatar
Az.scarecrow Az.scarecrow is offline
Az.scarecrow is starting off with a positive reputation.
........ You guys r koo- ko.......
__________________
00 F250 PS 4x4 CrewCab Shortbox XLT
Aluminum MB Motoring-285/75-16 BFG A/T's
Rhino Hardlined with UnderCover Bed Cover
Autometer 3 pod pillar, AFE 6637 intake & 4" exhaust with muffler delete. DP Tuner from ITP - 40t+80e+140+drive-thru+high idle, JW Valve Body, HPX, OBAnni, CCV Bypass, Foil Delete, AIH Delete, & Ported Turbo Shroud.
  #53 (permalink)
Old 07-13-2009, 01:20 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Quote:
The $2095 is for dual termninator HPOPs. Joey also sells a single modded HPOP. Not found on his website. If interested you should call him.
  #54 (permalink)
Old 07-13-2009, 09:24 AM
I dont know where it could be. I have pressure tested the system up to 30 lbs and it is holding. I found a small leak around the temp sensor on the spyder, and that is it. I did not spray soapy water around the up pipes. Would the up-pipes be pressurized when doing the pressure check using a 3 inch PVC cap and valve stem?
__________________
  #55 (permalink)
Old 07-13-2009, 10:17 AM
1999 Ford F-250
What Robin said. Call or email Joey.
__________________
Chase
PAA Member #2
  #56 (permalink)
Old 07-13-2009, 11:08 AM
PaysonPSD's Avatar
Support FTE
Quote:
You cannot pressurize the up-pipes via the intake. Look for soot streaks near the baby's butt. I had a leak that didn't leave streaks but caused the whole circumfrence of the top of the passenger side up-pipe to be solid black.
  #57 (permalink)
Old 07-13-2009, 12:21 PM
mongo75's Avatar
mongo75 mongo75 is offline
Marine Lifer
mongo75 has a great reputation on FTE. mongo75 has a great reputation on FTE. mongo75 has a great reputation on FTE. mongo75 has a great reputation on FTE. mongo75 has a great reputation on FTE.
Or have someone mash the go pedal with your tuner set on the highest setting. If your up pipes are leaking (like mine) YOU WILL see black smoke from them, in the engine compartment, but more so under the truck. Give it a shot.
__________________
Danny PAA member #12
SoCal Chapter Member
Early 99 F-350 Lariat Dually 4x4 CC LB 7.3L, AFE Stage I, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ITP Ovrbst, CCV mod, SS HPX, Cackle-cure, Foil Del, ZooDad, Air Horns 320hp/704tq
I fight for America so I buy from America- who are you fighting for?
  #58 (permalink)
Old 07-13-2009, 02:25 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is gaining momentum as a positive member of FTE. CSIPSD is gaining momentum as a positive member of FTE.
Okay I just got back from a test drive after I tightened the wastegate actuator rod. It is boosting up to 20 lbs now, but I am still have high EGT's and a lot of black smoke. I am starting to wonder if the 4 inch compressor housing and compressor wheel is too big for my stock injectors to spool. Any ideas? I did have Jody tune my tuner for the adrenaline, so is the high EGT's and black smoke due to the 15* HPOP and tunes set for the adrenaline? I have not put the adrenaline in yet. I figured I better figure this problem out first.
The ATS housing does NOTHING, I repeat NOTHING for performance. It stops surge and nothing else.
The symple answer is you have a drive pressure leak. Fix your up pipes, and tighten your wastegate. Your problem will go away.
The best set up I ran ever was a 1.00/ATS/WW and stock injectors. NO egt issues ever when I ran that set up.
__________________
01 F-250 SC PSD,170k,17 Isspro Gauges,AFE-2,CCV Mod,IAH delete,map reg,Modded H2e,6.0IC,GTS Hybrids,Studs, Forged Rods,Water injection,Swamps Tunes,4" duals,Aero,6" tip's,100 axl tank,4" Revtek lift,37" TOYO MT's 467hp-1066tq
Isspro Performax Gauges
  #59 (permalink)
Old 07-13-2009, 02:28 PM
1999 Ford F-250
My early turd with stock sticks and turbo, 4" exhaust and 6637 intake never has EGT issues either. I even pulled about a 5-6k load in 80E and never even touched 1000°.
__________________
Chase
PAA Member #2
  #60 (permalink)
Old 07-13-2009, 02:43 PM
CSIPSD's Avatar
Hell I pulled 12k with a TS 100hp setting over santiam with no egt issues...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
