Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 06:31 PM
leesmythe leesmythe is offline
leesmythe is starting off with a positive reputation.
glow plug question
first off, hello all...
i just joined today, although ive had my 90 7.3L diesel for two years now.
so thank you in advance to all you guys.. im pretty aware of forums and how usefull they are, i am also a member of the jeepwrangler.com forum.
anyways...
i am repplacing all my glow plugs, and injector seals(o rings, fuel t's, hoses etc)
and i was wondering if there is any special thing i need to keep in mind when installing the new ones (or removing the old ones).
i.e...
do the glow plugs need to go in a certain order?
do the injectors need to be set to the computer?
do the glow plugs??
or do i just take em out, and screw in the new onnes??
one other thing... mind you its pre power stroke..
but the guy before me put a ATS turbo in it.. and i need to take the turbo off to get to all the plugs and injectors..
is there any special thing for the turbo too??
thanks again
  #2 (permalink)
Old 07-02-2009, 07:00 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Quote:
Nope! Use Motorcraft/Beru ZD 9.
There is no computer!
Are you replacing the Injectors??
do the glow plugs??
Like changing spark plugs without the firing order concern.
A Injector Return Line Replacement thread.
Someone else is better suited for this answer.
However I don't believe you need to remove the Turbo just to do Glow Plugs and Return Lines, Injectors themselves possibly.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #3 (permalink)
Old 07-02-2009, 07:21 PM
i am not replacing the injectors themselves..
just the o rings on the injectors.
and i do need somehow to get the turbo off to get to the last two plugs on the left side.
it is a ats turbo torque pro 2000
  #4 (permalink)
Old 07-02-2009, 11:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
leesmythe,
Welcome to FTE and the IDI diesel forum.
I use a pair of bent nose needle nose pliers to remove the glow plug connectors for the glow plugs under the turbo.
1/4" drive deep socket with a universal and long extension will get the on in front of the turbo.
The one under the turbo, I use an open end wrench.
Real pain, but it can be changed.
Also the bent nose pliers are how you get the glow plug out of the hole and the new one back in.
Removing and replacing the turbo is a project in itself with the engine still in the truck.
I have the 093 turbo, the model before yours.
I have never worked on an engine with the Aurora turbo installed, but it should be close to the same setup.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 07-03-2009, 01:10 PM
ok.
thanks for the info guys.
i now have all the plugs replaced (didnt have to take off turbo)
and am working on the return lines and o rings on the injectors...
should i lube the o rings????
Ford dealership parts department here in PX says not to lube at all; just roll em on..
but another thread i was reading on here the guy was saying to lube them,,
so what do i do? trust ford? or the forum?
PLEASE ADVISE
  #6 (permalink)
Old 07-03-2009, 01:17 PM
That will depend on whom you talk to...
Some use vaseline, Some use regular grease, some go dry!
Personally, I do perfectly clean and dry as I do with all rubber type seals that are stationary, especially in hot areas.
-Enjoy
fh : )_~
__________________
  #7 (permalink)
Old 07-03-2009, 07:06 PM
1986 Ford F-250
I use grease on mine, that lets the return cap slide on easier with no chance of rolling the O ring pinching it.
I lube mine before I try to install them.
Roll the first one in the top groove, then roll the bottom one across it.
Dab of grease smeared around the O rings and a bit more smeared on the bottom of the return tee right before I install it.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #8 (permalink)
Old 07-04-2009, 06:09 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
I've seen the caps split up the side when pushing them over dry seals. The seal rolls, guy keeps shoving on the cap and then it snaps into place with a nice big crack in the side.
I always lube the O rings also, easier install and no cracked caps.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #9 (permalink)
Old 07-04-2009, 12:39 PM
so now i have all the new plugs in.
i started it this morning (it was fairly cold actually it rained)
and i had to crank it for a while....
what do i do next? if the plugs themselves dont make a difference then what in the plug system do i check?
  #10 (permalink)
Old 07-04-2009, 12:53 PM
1986 Ford F-250
How long does the wait to start light come on for now?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #11 (permalink)
Old 07-04-2009, 01:02 PM
it doesnt come on.. never has i think something is wrong with the light.
Tags
73 , diesel , glow , idi , install , plugs , remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
