Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 05:38 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3 Powerstroke-7.3 is offline
Powerstroke-7.3 is starting off with a positive reputation.
Need electrical help
I have had to hard wire in both headlight sockets. The passenger one went good. Did the driver side and now I have no low beams on just the driver side. I do know that both bulbs are fine and that the new socket is fine. I believe that I have a problem with the blue (power) on the driver side because it is not getting full voltage. Its getting only 5 volts at the most. I was wondering if anyone has had this problem before and if anyone has any ideas? Thank you
P.S. the truck is an early 99 f250 crew cab 4x4 if that makes a difference.
__________________
ALEX
1999 F-250 Crew Cab short bed 4x4, 2" lift, 5" straight pipe, K&N cold air intake, Autometer gauges, foil delete, Edge Evolution
1979 F-250 Ranger 4x4
  #2 (permalink)
Old 07-02-2009, 05:50 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Not an electrical type guy at all, but it sounds like you may have bypassed a relay somehow.
  #3 (permalink)
Old 07-02-2009, 09:02 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
Fuse#11 under hood 10A* Right Headlamp (Low Beam)
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #4 (permalink)
Old 07-03-2009, 03:28 PM
rbaker6336 thank you so much. Your a life saver. Many people have told me that they were not on seperate fuses. I thought I was going to have to rip into my wiring harness. Thanks so much again.
__________________
ALEX
  #5 (permalink)
Old 07-03-2009, 03:35 PM
RussB's Avatar
RussB RussB is offline
RussB is gaining momentum as a positive member of FTE.
Have you had a chance to see if that was indeed the problem ??? Did you get it fixed ??
__________________
Russ PAA# 25
03, 350 Lariet, 315 Toyo M/T's, 9000lb Warn winch frnt/rear recv mount, 4 ProComp halo's (frt bump), Warn man hubs, 6637 / Pete's cover, CCV, Gauges, 4" ProComp Lift, 4" SS Magnaflow , GPR LED, SS HPX, DP Tuner NS,STK,HIGH IDLE,40T,DECEL,80T,80ECO,120/ gauge switch, Overboost, Avic D3, F650 dash, Aeroforce scan gauge !
  #6 (permalink)
Old 07-03-2009, 04:48 PM
Yes that was the problem. There is a fuse for the right and the left headlight low beams
__________________
ALEX
  #7 (permalink)
Old 07-03-2009, 06:19 PM
RussB's Avatar
Quote:
Glad you got it fixed !
__________________
Russ PAA# 25
  #8 (permalink)
Old 07-04-2009, 06:30 PM
I am too. Thought it would be one of those annoying electrical problems.
__________________
ALEX
  #9 (permalink)
Old 07-04-2009, 06:59 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
Quote:
Nice job !
Reps sent.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
